i face this issue from the day i have buy my Flint 2 router. on wifi 5ghz my download speed is not more then 750mbps ( is like limited want to go up and drop down again ).
I will attach some screenshots with speedtest directly on Flint2 cli and speedtest from laptop with 2401 mbps wifi connection to route.
Can be a driver limitation? Wifi is set to Max.
Also do anyone achieve more then 800mbps on wifi? on speedtests . Also i can confirm is a wifi issue because via lan cable i have 930mbps download and around 300 mbps upload.
@ywp or @bruce any of you guys can help with this issue? Or any developer....
Sorry to bring this to discussion but with my Xiaomi AX3600 i can achieve around 900mbps also with openwrt snapshot installed
I can confirm the wifi is faster with around 50 to 100mbps : 800mbps to 850mbps. But the wire guard client is broken. its connecting but not forwarding traffic
May I know what VPN server do you use? User own deployment or subscribe a VPN provider?
Please ensure the VPN server works, lets say can try it connect on the WG Client of the PC to check if the connectivity of the server <-> client works.
