I purchased the E3372 from Ebay as unlocked and it does work with a 3 sim (UK) as well as a Bouygues Tel sim (France) both into a MacBookPro and into a TP-Link VR600V into the USB socket.
I’ve attached two screen shots of the device info from the E3372 for your information.
Another thought, if the Huawei E3372 is going to be problematic would a ZTE MF823 be a better bet?
I do have a 35 dBi gain attached to give me a signal because I am in a patchy rural area in France!
Having said that I have found that the Huawei is a good modem with a very good receiver front end. I find that I can hang onto a weak 4G signal with the E3372 which is not the case with a TP-Link MR200 that drops the signal at any excuse! (Both connected to the high gain antenna)
How does the ZTE ME823 compare to the Huawei E3372 in your experience?
I don’t see why not! I am in France until the middle of next month and need the E3372 while I am here, but when I am back in the UK I have no need for it so can send it to you. Where are you? The UK has far more cheap postage options than France does!
Photo attached. It is an Ebay purchase from a Polish guy based in the UK who gets them made in Poland!
I don’t have any specific details which is a shame, but it does work!
Twin downlead by the way.
I ‘think’ I am about 6kms from the mast, but as this is France I can’t be sure exactly where the mast is!
I have been trying to find a program to show the signal strength in real time on either a Mac or PC but sadly can’t find anything useful.
So tweaking the antenna to get the best signal isn’t easy!
The Huawei is much more ‘open’ when it comes to seeing signal strength, the TP-Link was impossible, as TP-Link don’t let you get to the inner workings of the chipset!
The antenna is terminated with two FME Female connectors about a metre from the antenna.
I took the option of the longest feeder cable - 15 metres - (Every metre of cable drops the signal level and 15 metres is considered the maximum length.) At the same time I ordered two FME Male to TS9 cables as well as a couple CRC9 to FME Male and two FME Male to SMA cables. All are ‘jumper’ cables and are about 30cms long.
The CRC9 converts to the Huawei E3372, the TS9 ones are for my Huawei E5573 and the SMA set is for my somewhat useless TP-Link MR200!
<span id=“result_box” lang=“en”>hello all, the same problem, I bought a usb lte huawei E3372 key but my mt300a does not recognize it, the latest firmware installed on the 2.261.
Who would be the person who tested this E3372?
Is it useless to try out the latest firmware versions?
What alternative can you point to instead of the E3372</span><span id=“t-served-community-button” class=“trans-verified-button goog-toolbar-button” style=“display: none;”></span>
There is no connection to the internet by the way!
Looking at the dongle, be it the Huawei or the ZTE, it shows that a 4G connection is made but doesn’t get through the GL-AR300 router to my MacBookPro!
I have an identical problem with the Huawei E3372 and the gl-ar300m.
In fact exactly similar down to connecting to “3” in the UK, and similar in France.
All the screenshots would be exactly the same too!
Has the problem been solved? And how?
Thanks, Barry
