GL-AR300M port forwarding NOT saved and applied
#1
Hello, in my GL-AR300M I try to forward a port, but when I click “save and apply” nothing is saved. Could someone suggest sth? (VPN is enabled)
#2
Can’t it work, or just you fail to add a port forwarding rule.
#3
Failed to add a port forwarding rule. It says “configuration applied” for a few seconds, but then nothing is added.
#4
Could you please upgrade to the latest testing firmware? We had added port forwarding on our webui. Download from here, please untick “keep settings” when upgrading.
#5
How can I downgrade to 2.26 in case something goes wrong? which file do I have to install?
#6
Something goes wrong as in?
Flashing firmware, upgrade and downgrade, is done through the Web UI.
