I have a GL-AR750 which I want to attach to another router which is wired only, and use the GL-AR750 to connect to a wifi network and act as the WAN link for the other router.
I want the other router to be the DHCP Server.
So I want to disable the DHCP Server on the GL-AR750.
My scenario is similar to this post
However when I look at changing the router mode from router to access-point, there is a warning in the admin portal that having done this: “you may not connect to this UI again”.
So I’m not sure if this is what I should be doing. If I change to access point, how do I then configure the GL-AR750?
I will need to configure it to join a specific wifi network.
Thanks
VW
