I’ve a GL-AR750S-Ext router and a Huawei E3276s-150 LTE modem.
I’m trying to connect to Internet via the LTE modem but I cannot.
The router seems to recognize the modem well (some outputs)
dmesg
[ 516.401995] usb 1-1.1: new high-speed USB device number 9 using ehci-platform
[ 516.560231] usb 1-1.1: New USB device found, idVendor=12d1, idProduct=157c
[ 516.567398] usb 1-1.1: New USB device strings: Mfr=5, Product=4, SerialNumber=7
[ 516.574972] usb 1-1.1: Product: HUAWEI Mobile
[ 516.579483] usb 1-1.1: Manufacturer: HUAWEI Technology
[ 516.584816] usb 1-1.1: SerialNumber: FFFFFFFFFFFFFFFF
[ 516.628063] usb-storage 1-1.1:1.0: USB Mass Storage device detected
[ 516.646802] scsi host0: usb-storage 1-1.1:1.0
[ 516.652074] usb-storage 1-1.1:1.1: USB Mass Storage device detected
[ 516.669957] scsi host1: usb-storage 1-1.1:1.1
[ 517.282624] usb 1-1.1: USB disconnect, device number 9
[ 517.642154] usb 1-1.1: new high-speed USB device number 10 using ehci-platform
[ 517.823825] usb 1-1.1: New USB device found, idVendor=12d1, idProduct=1506
[ 517.830989] usb 1-1.1: New USB device strings: Mfr=5, Product=4, SerialNumber=0
[ 517.838671] usb 1-1.1: Product: HUAWEI Mobile
[ 517.843200] usb 1-1.1: Manufacturer: HUAWEI Technology
[ 517.963187] option 1-1.1:1.0: GSM modem (1-port) converter detected
[ 517.969952] usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB0
[ 517.977946] option 1-1.1:1.1: GSM modem (1-port) converter detected
[ 517.984820] usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB1
[ 518.134594] huawei_cdc_ncm 1-1.1:1.2: MAC-Address: 0c:5b:8f:27:9a:64
[ 518.141223] huawei_cdc_ncm 1-1.1:1.2: setting rx_max = 16384
[ 518.178542] huawei_cdc_ncm 1-1.1:1.2: setting tx_max = 16384
[ 518.203544] huawei_cdc_ncm 1-1.1:1.2: NDP will be placed at end of frame for this device.
[ 518.212281] huawei_cdc_ncm 1-1.1:1.2: cdc-wdm0: USB WDM device
[ 518.219327] huawei_cdc_ncm 1-1.1:1.2 wwan0: register 'huawei_cdc_ncm' at usb-ehci-platform.0-1.1, Huawei CDC NCM device, 0c:5b:8f:27:9a:64
[ 518.232967] usb-storage 1-1.1:1.3: USB Mass Storage device detected
[ 518.422082] scsi host0: usb-storage 1-1.1:1.3
[ 518.427417] usb-storage 1-1.1:1.4: USB Mass Storage device detected
[ 518.494020] scsi host1: usb-storage 1-1.1:1.4
[ 519.512761] scsi 1:0:0:0: Direct-Access HUAWEI TF CARD Storage 2.31 PQ: 0 ANSI: 2
[ 519.523407] scsi 0:0:0:0: CD-ROM HUAWEI Mass Storage 2.31 PQ: 0 ANSI: 2
[ 519.535819] sd 1:0:0:0: [sda] Attached SCSI removable disk
[ 524.596623] 3g-modem_1_1: renamed from ppp0
cat /sys/kernel/debug/usb/devices
T: Bus=01 Lev=02 Prnt=08 Port=00 Cnt=01 Dev#= 10 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=ff MxPS=64 #Cfgs= 1
P: Vendor=12d1 ProdID=1506 Rev= 1.02
S: Manufacturer=HUAWEI Technology
S: Product=HUAWEI Mobile
C:* #Ifs= 5 Cfg#= 1 Atr=80 MxPwr=500mA
I:* If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=02 Prot=10 Driver=option
E: Ad=81(I) Atr=03(Int.) MxPS= 64 Ivl=2ms
E: Ad=82(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=01(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
I:* If#= 1 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=02 Prot=12 Driver=option
E: Ad=83(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
I: If#= 2 Alt= 0 #EPs= 1 Cls=ff(vend.) Sub=02 Prot=16 Driver=huawei_cdc_ncm
E: Ad=85(I) Atr=03(Int.) MxPS= 64 Ivl=2ms
I:* If#= 2 Alt= 1 #EPs= 3 Cls=ff(vend.) Sub=02 Prot=16 Driver=huawei_cdc_ncm
E: Ad=86(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=03(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
I:* If#= 3 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage
E: Ad=04(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=87(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 4 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage
E: Ad=05(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=88(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
ifconfig -a
wwan0 Link encap:Ethernet HWaddr 0C:5B:8F:27:9A:64
BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
but the configuration written by the Web GUI doesn’t work
i’m on vanilla openwrt don’t know about glinet gui… you should go in advanced firewall for glinet gui i guess or ssh an add interface to /etc/config/firewall add your interface to option network
good! please mark as solved for other users, consider installing vanilla openwrt since you use ssh/shell commands you don’t need gl.inet gui, much more information available for advanced users and you’ll learn a lot!
