I got the MF823, but it won’t connect. Tested the SIM in another stick in a Fritzbox. Works. Tested the MF823 with this SIM in a Fritzbox. Works.
Settings are identical.
What can I do to troubleshoot this? The user interface seems to lack a Network Selection where I also could see signal strength, right?
These are my log files:
Sun Apr 30 14:09:07 2017 kern.info kernel: [ 2428.290000] usb 1-1: USB disconnect, device number 16
Sun Apr 30 14:09:07 2017 kern.info kernel: [ 2428.290000] option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
Sun Apr 30 14:09:07 2017 kern.info kernel: [ 2428.300000] option 1-1:1.0: device disconnected
Sun Apr 30 14:09:07 2017 kern.info kernel: [ 2428.310000] qmi_wwan 1-1:1.3 wwan0: unregister ‘qmi_wwan’ usb-ehci-platform-1, WWAN/QMI device
Sun Apr 30 14:09:19 2017 daemon.info hostapd: wlan0: STA a4:5e:60:b8:2c:89 WPA: group key handshake completed (RSN)
Sun Apr 30 14:09:29 2017 kern.info kernel: [ 2449.660000] usb 1-1: new high-speed USB device number 17 using ehci-platform
Sun Apr 30 14:09:29 2017 kern.info kernel: [ 2449.860000] usb-storage 1-1:1.0: USB Mass Storage device detected
Sun Apr 30 14:09:29 2017 kern.info kernel: [ 2449.880000] scsi host28: usb-storage 1-1:1.0
Sun Apr 30 14:09:30 2017 kern.notice kernel: [ 2450.890000] scsi 28:0:0:0: CD-ROM ZTE USB SCSI CD-ROM 2.31 PQ: 0 ANSI: 2
Sun Apr 30 14:09:30 2017 kern.notice kernel: [ 2450.910000] scsi 28:0:0:1: Direct-Access ZTE MMC Storage 2.31 PQ: 0 ANSI: 2
Sun Apr 30 14:09:30 2017 kern.notice kernel: [ 2450.990000] sd 28:0:0:1: [sda] Attached SCSI removable disk
Sun Apr 30 14:09:31 2017 daemon.err miniupnpd[10074]: Failed to get IP for interface wwan0
Sun Apr 30 14:09:35 2017 kern.info kernel: [ 2455.920000] usb 1-1: USB disconnect, device number 17
Sun Apr 30 14:09:35 2017 kern.info kernel: [ 2456.370000] usb 1-1: new high-speed USB device number 18 using ehci-platform
Sun Apr 30 14:09:36 2017 kern.info kernel: [ 2456.590000] option 1-1:1.0: GSM modem (1-port) converter detected
Sun Apr 30 14:09:36 2017 kern.info kernel: [ 2456.590000] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB0
Sun Apr 30 14:09:36 2017 kern.info kernel: [ 2456.620000] qmi_wwan 1-1:1.3: cdc-wdm0: USB WDM device
Sun Apr 30 14:09:36 2017 kern.info kernel: [ 2456.630000] qmi_wwan 1-1:1.3 wwan0: register ‘qmi_wwan’ at usb-ehci-platform-1, WWAN/QMI device, ce:30:13:61:0e:2a
Sun Apr 30 14:09:36 2017 kern.info kernel: [ 2456.650000] usb-storage 1-1:1.4: USB Mass Storage device detected
Sun Apr 30 14:09:36 2017 kern.info kernel: [ 2456.660000] scsi host29: usb-storage 1-1:1.4
Sun Apr 30 14:09:37 2017 kern.notice kernel: [ 2457.660000] scsi 29:0:0:0: CD-ROM ZTE USB SCSI CD-ROM 2.31 PQ: 0 ANSI: 2
Sun Apr 30 14:09:37 2017 kern.notice kernel: [ 2457.680000] scsi 29:0:0:1: Direct-Access ZTE MMC Storage 2.31 PQ: 0 ANSI: 2
Sun Apr 30 14:09:37 2017 kern.notice kernel: [ 2457.690000] sd 29:0:0:1: [sda] Attached SCSI removable disk
Sun Apr 30 14:10:10 2017 daemon.notice netifd: Interface ‘modem’ is setting up now
Sun Apr 30 14:10:10 2017 daemon.notice netifd: modem (28980): wwan[28980] Using proto:wwan device:/dev/cdc-wdm0 iface:wwan0 desc:ONDA MT505UP/ZTE
Sun Apr 30 14:10:10 2017 daemon.info dnsmasq[17113]: exiting on receipt of SIGTERM
Sun Apr 30 14:10:11 2017 daemon.notice netifd: modem (28980): Waiting for network registration
Sun Apr 30 14:10:11 2017 daemon.notice netifd: modem (28980): Starting network internet
Sun Apr 30 14:10:11 2017 daemon.notice netifd: modem (28980): Starting DHCP
Sun Apr 30 14:10:11 2017 daemon.notice netifd: Interface ‘modem_4’ is enabled
Sun Apr 30 14:10:11 2017 daemon.notice netifd: Interface ‘modem_6’ is enabled
Sun Apr 30 14:10:11 2017 daemon.notice netifd: Interface ‘modem’ is now up
Sun Apr 30 14:10:11 2017 daemon.notice netifd: Network device ‘wwan0’ link is up
Sun Apr 30 14:10:11 2017 daemon.notice netifd: Network alias ‘wwan0’ link is up
Sun Apr 30 14:10:11 2017 daemon.notice netifd: Interface ‘modem_4’ has link connectivity
Sun Apr 30 14:10:11 2017 daemon.notice netifd: Interface ‘modem_4’ is setting up now
Sun Apr 30 14:10:11 2017 daemon.notice netifd: Interface ‘modem_6’ has link connectivity
Sun Apr 30 14:10:11 2017 daemon.notice netifd: Interface ‘modem_6’ is setting up now
Sun Apr 30 14:10:11 2017 daemon.notice netifd: modem (28980): Command failed: Unknown error
Sun Apr 30 14:10:11 2017 user.notice root: qmi bringup failed, retry in 15s
Sun Apr 30 14:10:11 2017 daemon.notice netifd: modem_4 (29072): udhcpc (v1.24.1) started
Sun Apr 30 14:10:11 2017 daemon.notice netifd: modem_4 (29072): Sending discover…
Sun Apr 30 14:10:13 2017 daemon.info dnsmasq[29149]: started, version 2.73 cachesize 150
Sun Apr 30 14:10:13 2017 daemon.info dnsmasq[29149]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth no-DNSSEC loop-detect inotify
Sun Apr 30 14:10:13 2017 daemon.info dnsmasq[29149]: DNS service limited to local subnets
Sun Apr 30 14:10:13 2017 daemon.info dnsmasq-dhcp[29149]: DHCP, IP range 10.254.254.100 – 10.254.254.249, lease time 12h
Sun Apr 30 14:10:13 2017 daemon.info dnsmasq[29149]: using local addresses only for domain lan
Sun Apr 30 14:10:13 2017 daemon.warn dnsmasq[29149]: no servers found in /tmp/resolv.conf.auto, will retry
Sun Apr 30 14:10:13 2017 daemon.info dnsmasq[29149]: read /etc/hosts - 1 addresses
Sun Apr 30 14:10:13 2017 daemon.info dnsmasq[29149]: read /tmp/hosts/dhcp - 1 addresses
Sun Apr 30 14:10:13 2017 daemon.info dnsmasq-dhcp[29149]: read /etc/ethers - 0 addresses
Sun Apr 30 14:10:14 2017 daemon.notice netifd: modem_4 (29072): Sending discover…
Sun Apr 30 14:10:17 2017 daemon.notice netifd: modem_4 (29072): Sending discover…
Sun Apr 30 14:10:22 2017 user.warn mwan3: Could not find gateway for interface modem (wwan0)
Sun Apr 30 14:10:22 2017 user.notice firewall: Reloading firewall due to ifup of modem (wwan0)
Sun Apr 30 14:10:35 2017 daemon.err miniupnpd[10074]: ioctl(s, SIOCGIFADDR, …): Cannot assign requested address
Sun Apr 30 14:10:35 2017 daemon.err miniupnpd[10074]: Failed to get IP for interface wwan0
