I have the GL-AR750S router, I’m trying to hook up a USB Printer to the router through the port. I loaded CUP and P910nd, I saw where I can configure the p910nd, and followed the direction through the openwrt wiki, I’m still not getting any connectivity from my Win10 machines to the printer. Does anyone have any ideals?
Long time before I configured printer on the router and I hope that you can refer to this.
Install cups
opkg update
opkg install cups
/etc/init.d/cupsd enable
Add user access
Change /etc/cups/cupsd.conf Pls make sure you use the IP address correct.
User root
Group root
AuthClass Anonymous
Allow from 192.168.8.1/24
Check printer info
chmod 700 /usr/lib/cups/backend/usb
And you can see the printer information
DEBUG: list_devices
DEBUG: libusb_get_device_list=2
DEBUG2: Printer found with device ID:
MFG:Canon;CMD:BJL,BJRaster3,BSCCe,PLI;SOJ:TXT01;MDL:iP3600
series;CLS:PRINTER;DES:Canon iP3600
series;VER:1.020;STA:10;HRI:ASI;MSI:AOFF,BOFF,DAT,E3,HFSF;PDR:6; Device URI:
usb://Canon/iP3600%20series?serial=13C040
direct usb://Canon/iP3600%20series?serial=13C040 "Canon iP3600 series" "Canon
iP3600 series" "MFG:Canon;CMD:BJL,BJRaster3,BSCCe,PLI;SOJ:TXT01;MDL:iP3600
series;VER:1.020;STA:10;HRI:ASI;MSI:AOFF,BOFF,DAT,E3,HFSF;PDR:6;" ""
Configure the printer
go to http://192.168.8.1:631 and add your printer. Pls use your root password.
Use printer in windows
The printer address is http://192.168.8.1:631/printers/Canon_iP3600_series
Use cache
Cups need to cache printer files. If router’s RAM is not big it may cause problem. So you can ask cups to cache in USB devices.
Modify /etc/cups/cupsd.conf and add your external storage.
RequestRoot /mnt/sda1
TempDir /mnt/sda1
You need to check if cups is running normally.
I try for the GL-B1300. I can access to the cups admin interfaces. But I don’t know how to add my printer.
when I type : /usr/share/cups/usb: It’ say :
/usr/share/cups/usb: No such file or directory
DEBUG: list_devices
DEBUG: libusb_get_device_list=5
But no printer found…
Printer is connected (power on) into usb to the mesh node (not the main node which as a usb storage)
I can see 2 defaults printers in the web interface, it’s normal ?
“LP” and “USB” in queue name
Now it’s ok I have add cups on my subnode (with ssh) and my printer work on the subnode usb ![]()
I simply connected via SSH to the subnode and then installed cups as mentioned above and used the ip address of the subnode to configure the printer in cups.
For those who came here and didn’t get success with CUPS.
For my HP LaserJet Pro M1132 p910nd solution worked perfect without any messing with ppds or drivers for unix.
GL.iNet Travel Router (GL-AR750S) USB Printing from Router - 12. 17. 21
(Printer is already connected to router USB port)
login to your router via web browser (192.168.8.1)
MORE SETTINGS > Advanced
a. download and install Luci
- SSH (Secure Shell) into your router
A. Download and open PuTTY
Host Name (or IP address)= 192.168.8.1
accept the PuTTY Security Alert
login as: root
password: is your router’s password
Configure p910nd Print Server in PuTTY
A. enter commands
opkg update
opkg install kmod-usb-printer
opkg install p910nd luci-app-p910nd
ls /dev/usb/lp*
(if configured correctly, results should be= /dev/usb/lp0) -
back to your web browser of your router (192.168.8.1)
A. FIREWALL > Open Ports on Router
Name= enter whatever you like, I entered (USB>WIFI Printing)
Port= 1900
Protocol= TCP/UDP
Status= Enabled
Add
B. MORE SETTINGS > Advanced
click on 192.168.8.1/cgi-bin/luci
Password= enter your router’s password
Services > p910nd Printer server
a. enabled= make sure it is checked
b. Device= /dev/usb/lp0
c. Interface= unspecified
d. Port= 1900
e. Bidirectional mode= leave checked
f. Save&Apply
- On PC, start > Printer
A. Add a printer or scanner
B. click The printer that I want isn’t listed
C. add a local printer or network printer with manual settings
D. create a new port= type of port Standard TCP/IP Port
E. Hostname or IP address: 192.168.8.1
F. uncheck= Query the printer and automatically select the drive to use
G. click next, let the computer detect TCP/IP
H. Custom then click Settings
- Protocol: RAW, Port Number: 9100
I. Pick your printer driver and follow instructions to complete configuration and installation
Final: reboot your router and turn off/on your printer and print something.
Add additional computers to print, follow step 6 on each computer.
