GL-AXT1800 and NordVPN
I’ve been trying to set up a NordVPN client on GL-AXT1800 but keep geeting auth error. Here is the log and it would be appreciated if you could advise me on how to make this work.
Sun Mar 17 02:45:38 2024 daemon.notice ovpnclient[21613]: TCP/UDP: Preserving recently used remote address: [AF_INET]212.102.50.122:443
Sun Mar 17 02:45:38 2024 daemon.notice ovpnclient[21613]: Socket Buffers: R=[87380->87380] S=[16384->16384]
Sun Mar 17 02:45:38 2024 daemon.notice ovpnclient[21613]: Attempting to establish TCP connection with [AF_INET]212.102.50.122:443 [nonblock]
Sun Mar 17 02:45:38 2024 daemon.notice ovpnclient[21613]: TCP connection established with [AF_INET]212.102.50.122:443
Sun Mar 17 02:45:38 2024 daemon.notice ovpnclient[21613]: TCP_CLIENT link local: (not bound)
Sun Mar 17 02:45:38 2024 daemon.notice ovpnclient[21613]: TCP_CLIENT link remote: [AF_INET]212.102.50.122:443
Sun Mar 17 02:45:39 2024 daemon.notice ovpnclient[21613]: TLS: Initial packet from [AF_INET]212.102.50.122:443, sid=e8c3d802 f55ceec4
Sun Mar 17 02:45:40 2024 daemon.notice ovpnclient[21613]: VERIFY OK: depth=2, C=PA, O=NordVPN, CN=NordVPN Root CA
Sun Mar 17 02:45:40 2024 daemon.notice ovpnclient[21613]: VERIFY OK: depth=1, O=NordVPN, CN=NordVPN CA9
Sun Mar 17 02:45:40 2024 daemon.notice ovpnclient[21613]: VERIFY KU OK
Sun Mar 17 02:45:40 2024 daemon.notice ovpnclient[21613]: Validating certificate extended key usage
Sun Mar 17 02:45:40 2024 daemon.notice ovpnclient[21613]: ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Sun Mar 17 02:45:40 2024 daemon.notice ovpnclient[21613]: VERIFY EKU OK
Sun Mar 17 02:45:40 2024 daemon.notice ovpnclient[21613]: VERIFY X509NAME OK: CN=jp521.nordvpn.com
Sun Mar 17 02:45:40 2024 daemon.notice ovpnclient[21613]: VERIFY OK: depth=0, CN=jp521.nordvpn.com
Sun Mar 17 02:45:40 2024 daemon.notice ovpnclient[21613]: Control Channel: TLSv1.3, cipher TLSv1.3 TLS_AES_256_GCM_SHA384, peer certificate: 4096 bit RSA, signature: RSA-SHA512
Sun Mar 17 02:45:40 2024 daemon.notice ovpnclient[21613]: [jp521.nordvpn.com] Peer Connection Initiated with [AF_INET]212.102.50.122:443
Sun Mar 17 02:45:41 2024 daemon.notice ovpnclient[21613]: SENT CONTROL [jp521.nordvpn.com]: 'PUSH_REQUEST' (status=1)
Sun Mar 17 02:45:42 2024 daemon.notice ovpnclient[21613]: AUTH: Received control message: AUTH_FAILED
Sun Mar 17 02:45:42 2024 daemon.notice ovpnclient[21613]: SIGTERM[soft,auth-failure] received, process exiting
