Hi all, newbie here.
I’m experiencing troubles with my GL-AXT1800 Slate AX. I connected to a 5Ghz Wifi6 network as a repeater for almost a day, then the router rebooted and connected to the same wifi ssid but in 2.4Ghz.
Now i’m unable to reconnect to the 5Ghz ssid anymore. From the admin web panel i don’t see the 5Ghz ssid, instead using Luci i can see the ssid but when i try to connect to it, the router crash, reboot and get stuck in boot loop and i have to reset it.
My specifics:
FW version: 4.0.1 release 3 updated from web admin upgrade tab
No VPN
No AdGuard
No plugins installed
Set as router
I tried to separate
Can someone help me?
Thanks in advance
