GL-B1300 Physical Ethernet Port Guest LAN
Hi all,
The GL-B1300 has two physical ethernet ports.
Is it possible to have the 1st ethernet port on LAN and the 2nd ethernet port on Guest Network?
Thank you!
The following config /etc/config/network make the middle port the guest network.
root@GL-B1300:/etc/config# cat network
config interface 'loopback'
	option ifname 'lo'
	option proto 'static'
	option ipaddr '127.0.0.1'
	option netmask '255.0.0.0'
config globals 'globals'
	option ula_prefix 'auto'
config interface 'lan'
	option ifname 'eth1'
	option force_link '1'
	option type 'bridge'
	option ip6assign '60'
	option hostname 'GL-B1300-008-5G'
	option ipaddr '192.168.8.1'
	option ieee1905managed '1'
config interface 'wan'
	option ifname 'eth0'
	option proto 'dhcp'
	option metric '10'
config interface 'wan6'
	option proto 'dhcpv6'
config switch
	option name 'switch0'
	option reset '1'
	option enable_vlan '1'
config switch_vlan
	option device 'switch0'
	option vlan '1'
	option ports '0t 1 2 3'
config switch_vlan
	option vlan '2'
	option ports '0t 5'
config switch_vlan
	option vlan '3'
	option ports '0t 4'
config switch_ext
	option name 'QosPtMode'
	option port_id '1'
	option mode 'dscp'
	option status 'enable'
config switch_ext
	option port_id '2'
	option mode 'dscp'
config switch_ext
	option port_id '3'
	option mode 'dscp'
config switch_ext
	option port_id '4'
	option mode 'dscp'
config switch_ext
	option port_id '5'
	option mode 'dscp'
config interface 'guest'
	option ifname 'eth1.3'
	option ipaddr '192.168.9.1'
Perfect, that worked beautifully. Thank you hansome!
If I want to make the other port (end port) the guest network, what entries would I need to change?
left LAN port as guest network:
        option ifname 'lo'
        option proto 'dhcp'
        option metric '10'
config switch
        option reset '1'
config switch_vlan
        option vlan '3'
config switch_vlan
        option vlan '2'
        option ports '0t 5'
config switch_vlan
        option vlan '1'
        option ports '0t 4'
config switch_ext
        option port_id '1'
        option mode 'dscp'
config switch_ext
        option port_id '2'
        option mode 'dscp'
config switch_ext
        option port_id '3'
        option mode 'dscp'
config switch_ext
        option port_id '4'
        option mode 'dscp'
config switch_ext
        option port_id '5'
        option mode 'dscp'
Thanks again hansome, that’s brilliant!
I really appreciate your time to help me here :slight_smile:
