Guest Network on physical LAN port plus WIFI (Slate AX, GL-AXT1800)
I would like to add pyhiscal LAN2 port to the guest network:
Guest Network = LAN2 + Guest WIFI.
I think, I need to “move” eth1 from br-lan to br-guest.
May I ask to help me here, please?
There is similar topic for the GL-B1300, but I think i canot copy past the solution to the GL-AXT1800:
Please refer to
Thanks for pointing me into the right direction.
I did the changes directly in the config file and not in the web frontend(s):
/etc/config/network
I moved the line with list ports 'eth1'
from the section config device option name 'br-lan'
to the section config interface 'guest'
Looks like this now:
grafik
from the glinet web ui this settings is not avaiable?
No, the GL Web GUI is pretty limited.
I hope the can implement this useful feature soon.
