Hi, I’m kind a new to this. I tried looking for luci-app-shadowsocksr on “advanced” webui but can’t find it.
Current build 19.07.0-rc1
Is there any working shadowsocksr for this router?
luci-app-ssr-plus_all.ipk is the latest shadowsocksr for this router Brume -W
opkg install shadowsocks-libev-config_3.3.5-1_aarch64_cortex-a53.ipk
opkg install shadowsocks-libev-ss-redir_3.3.5-1_aarch64_cortex-a53.ipk
opkg install dns2socks_2.1-2_aarch64_cortex-a53.ipk
opkg install microsocks_1.0.2-2_aarch64_cortex-a53.ipk
opkg install pdnsd-alt_1.2.9b-par-2_aarch64_cortex-a53.ipk
opkg install tcping_0.3-1_aarch64_cortex-a53.ipk
opkg install shadowsocks-rust-sslocal_1.11.1-1_aarch64_cortex-a53.ipk
opkg install shadowsocks-rust-ssserver_1.11.1-1_aarch64_cortex-a53.ipk
opkg install shadowsocksr-libev-ssr-check_2.5.6-9_aarch64_cortex-a53.ipk
opkg install shadowsocksr-libev-ssr-local_2.5.6-9_aarch64_cortex-a53.ipk
opkg install shadowsocksr-libev-ssr-redir_2.5.6-9_aarch64_cortex-a53.ipk
opkg install xray-core_1.4.2-1_aarch64_cortex-a53.ipk
opkg install libubox20210516_2021-05-16-b14c4688-2_aarch64_cortex-a53.ipk
opkg install libustream-openssl20201210_2020-12-10-68d09243-1_aarch64_cortex-a53.ipk
all right
but
opkg install luci-app-ssr-plus_184-9_all.ipk
opkg install luci-i18n-ssr-plus-zh-cn_184-9_all.ipk
are error
must have “shadowsocksr-libev-alt.ipk”,
where can i download shadowsocksr-libev-alt.ipk for aarch64_cortex-a53?
I has solved the problom
Can you let others know what the problem was, as I’m having an issue trying to install?
@siboney has another thread on this subject that may have the info:
Mind on sharing how?
