Home Router “Buffalo WZR-HP-AG300H” with DD-wrt Version DD-WRT v3.0-r27716 std
Gl-inet 750M V3.022 (wireguard Server)
300M (wireguard client, e.g. outside in a Hotel)
I connect my 750M to my home router. I configure the 750M as Wireguard Server, now I try to connect my Android Phone (wireguad Client App installed), but it does not work.
For example I want to connect to the wireguard Server e.g. when I stay in a Hotel, I want use a 300M as client in a Hotel to connect the Server at Home.
I connect the 750M to my home:
Internet <–> (Wan)Home Router(Lan) <–> (Wan)750M(Lan)
Is this right? What must I do to get it to work? Portforwarding etc. necessary?
No, but what is the IP from the 750M when I connect it to the Wan Port. Is it possible to give the Wan port from 750M a static IP ?
Is there any description that is usefull for me?
So you can configure port forwarding. If you don’t configure port forwarding, even if you set a static IP address to 750M, it doesn’t work as well. because it doesn’t have dedicated public IP address.
Hello
I CAN reach my Webcams, my Nas but i cant Look Tv with my Vodafone TV App From outside.
When i use my other vpn Server pptp it work. Why it does not work with wireguard?
There must be a different between these Servers, I can reach all my local devices from outside but the Vodafone TV app does not detect the local IP location. I had try this with the android wireguard client and also with my 300M. Must I forward any other ports?
