Fantastic news that the kernel has been moved to 5.4. Looking forward to future builds.
Currently compiling a test build of kernel 5.4 to see if it posts. Will take 2-3 days as I am only using 1 CPU core as I am logging for errors.
I am also using the same items from my Linksys Builds too, but with QCA stuff instead of marvels stuff.
Right now i can’t compile any firmware for the Flint as it simply errors out so going to call it a day for now until what ever was done to completely break compiles is fixed. I have spent way to much time on this and with the lack of sleep its time to give it a rest for the sake of my health.
Running a new compile session. Just did a compile for my Linksys on the same VM for openwrt without issues. So if it fails i now know its not the VM but what ever changes has been made.
I will test before uploading to mirror if and when it completes.
Update: Compile has failed again. Failing on kernel compile stuff.
Update 2: Did another clean OS install on VM and same issue, so going to have to wait on commits from gl-inet, i did notice that some stuff didn’t download during the make -j$(($(nproc)+1)) V=sc download part with a load of 404’s This of course is for the 5.4 Kernel so when i get chance will keep trying to compile Kernel 4.4 builds.
The error is always at
* Restart config...
* Multiple devices driver support (RAID and LVM)
Multiple devices driver support (RAID and LVM) (MD) [Y/n/?] y
RAID support (BLK_DEV_MD) [M/y/?] m
Linear (append) mode (MD_LINEAR) [M/n/?] m
RAID-0 (striping) mode (MD_RAID0) [M/?] m
RAID-1 (mirroring) mode (MD_RAID1) [M/?] m
RAID-10 (mirrored striping) mode (MD_RAID10) [M/?] m
RAID-4/RAID-5/RAID-6 mode (MD_RAID456) [M/?] m
Multipath I/O support (MD_MULTIPATH) [M/n/?] m
Faulty test module for MD (MD_FAULTY) [N/m/?] n
Block device as cache (BCACHE) [N/m/y/?] n
Device mapper support (BLK_DEV_DM) [M/n/?] m
Device mapper debugging support (DM_DEBUG) [N/y/?] n
Unstriped target (DM_UNSTRIPED) [N/m/?] n
Crypt target support (DM_CRYPT) [M/n/?] m
Crypt target support (DM_REQ_CRYPT) [N/m/?] (NEW) aborted!
Console input/output is redirected. Run 'make oldconfig' to update configuration.
make[7]: [scripts/kconfig/Makefile:73: syncconfig] Error 1 (ignored)
make -f ./scripts/Makefile.build obj=arch/arm/tools uapi
make -f ./scripts/Makefile.build obj=scripts/basic
make -f ./scripts/Makefile.asm-generic obj=arch/arm/include/generated/uapi/asm \
generic=include/uapi/asm-generic
rm -f .tmp_quiet_recordmcount
set -e; mkdir -p include/generated/uapi/linux/; trap "rm -f include/generated/uapi/linux/.version.h.tmp" EXIT; { if [ 164 -gt 255 ]; then echo \#define LINUX_VERSION_CODE 328959; else echo \#define LINUX_VERSION_CODE 328868; fi; echo '#define KERNEL_VERSION(a,b,c) (((a) << 16) + ((b) << 8) + ((c) > 255 ? 255 : (c)))'; } > include/generated/uapi/linux/.version.h.tmp; if [ ! -r include/generated/uapi/linux/version.h ] || ! cmp -s include/generated/uapi/linux/version.h include/generated/uapi/linux/.version.h.tmp; then : ' UPD include/generated/uapi/linux/version.h'; mv -f include/generated/uapi/linux/.version.h.tmp include/generated/uapi/linux/version.h; fi
make -f ./scripts/Makefile.build obj=scripts/dtc
set -e; mkdir -p include/config/; trap "rm -f include/config/.kernel.release.tmp" EXIT; { echo "5.4.164$(bash ./scripts/setlocalversion .)"; } > include/config/.kernel.release.tmp; if [ ! -r include/config/kernel.release ] || ! cmp -s include/config/kernel.release include/config/.kernel.release.tmp; then : ' UPD include/config/kernel.release'; mv -f include/config/.kernel.release.tmp include/config/kernel.release; fi
make -f ./scripts/Makefile.asm-generic obj=arch/arm/include/generated/asm \
generic=include/asm-generic
rm -f include/linux/version.h
Error: kernelrelease not valid - run 'make prepare' to update it
echo "#include <asm-generic/compat.h>" > arch/arm/include/generated/asm/compat.h
set -e; mkdir -p include/generated/; trap "rm -f include/generated/.utsrelease.h.tmp" EXIT; { if [ `echo -n "5.4.164" | wc -c ` -gt 64 ]; then echo '"5.4.164" exceeds 64 characters' >&2; exit 1; fi; echo \#define UTS_RELEASE \"5.4.164\"; } > include/generated/.utsrelease.h.tmp; if [ ! -r include/generated/utsrelease.h ] || ! cmp -s include/generated/utsrelease.h include/generated/.utsrelease.h.tmp; then : ' UPD include/generated/utsrelease.h'; mv -f include/generated/.utsrelease.h.tmp include/generated/utsrelease.h; fi
echo "#include <asm-generic/current.h>" > arch/arm/include/generated/asm/current.h
The present kernel configuration has modules disabled.
echo "#include <asm-generic/emergency-restart.h>" > arch/arm/include/generated/asm/emergency-restart.h
echo "#include <asm-generic/exec.h>" > arch/arm/include/generated/asm/exec.h
echo "#include <asm-generic/early_ioremap.h>" > arch/arm/include/generated/asm/early_ioremap.h
Type 'make config' and enable loadable module support.
echo "#include <asm-generic/extable.h>" > arch/arm/include/generated/asm/extable.h
make -f ./scripts/Makefile.build obj=arch/arm/boot/dts
echo "#include <asm-generic/flat.h>" > arch/arm/include/generated/asm/flat.h
Then build a kernel with module support enabled.
echo "#include <asm-generic/irq_regs.h>" > arch/arm/include/generated/asm/irq_regs.h
echo "#include <asm-generic/kdebug.h>" > arch/arm/include/generated/asm/kdebug.h
echo "#include <asm-generic/local.h>" > arch/arm/include/generated/asm/local.h
echo "#include <asm-generic/local64.h>" > arch/arm/include/generated/asm/local64.h
make[5]: [Makefile:1389: modules] Error 1 (ignored)
echo "#include <asm-generic/mmiowb.h>" > arch/arm/include/generated/asm/mmiowb.h
echo "#include <asm-generic/msi.h>" > arch/arm/include/generated/asm/msi.h
echo "#include <asm-generic/parport.h>" > arch/arm/include/generated/asm/parport.h
echo "#include <asm-generic/mm-arch-hooks.h>" > arch/arm/include/generated/asm/mm-arch-hooks.h
echo "#include <asm-generic/preempt.h>" > arch/arm/include/generated/asm/preempt.h
echo "#include <asm-generic/seccomp.h>" > arch/arm/include/generated/asm/seccomp.h
echo "#include <asm-generic/serial.h>" > arch/arm/include/generated/asm/serial.h
echo "#include <asm-generic/trace_clock.h>" > arch/arm/include/generated/asm/trace_clock.h
echo "#include <asm-generic/simd.h>" > arch/arm/include/generated/asm/simd.h
make -f ./scripts/Makefile.build obj=arch/arm/tools kapi
bash './arch/arm/tools/syscallnr.sh' 'arch/arm/tools/syscall.tbl' 'arch/arm/include/generated/asm/unistd-nr.h' ''
mkdir -p arch/arm/include/generated/asm/ && awk -f arch/arm/tools/gen-mach-types arch/arm/tools/mach-types > arch/arm/include/generated/asm/mach-types.h
bash './arch/arm/tools/syscalltbl.sh' 'arch/arm/tools/syscall.tbl' 'arch/arm/include/generated/calls-oabi.S' 'common,oabi'
bash './arch/arm/tools/syscalltbl.sh' 'arch/arm/tools/syscall.tbl' 'arch/arm/include/generated/calls-eabi.S' 'common,eabi'
make -f ./scripts/Makefile.build obj=scripts/mod
gcc -Wp,-MD,scripts/mod/.mk_elfconfig.d -Wall -Wmissing-prototypes -Wstrict-prototypes -O2 -fomit-frame-pointer -std=gnu89 -O2 -I/home/openwrt/gl-infra-builder/wlan-ap/openwrt/staging_dir/host/include -Wall -Wmissing-prototypes -Wstrict-prototypes -I/home/openwrt/gl-infra-builder/wlan-ap/openwrt/staging_dir/host/include -o scripts/mod/mk_elfconfig scripts/mod/mk_elfconfig.c -L/home/openwrt/gl-infra-builder/wlan-ap/openwrt/staging_dir/host/lib
ccache_cc -Wp,-MD,scripts/mod/.devicetable-offsets.s.d -nostdinc -isystem /home/openwrt/gl-infra-builder/wlan-ap/openwrt/staging_dir/toolchain-arm_cortex-a7_gcc-7.5.0_musl_eabi/lib/gcc/arm-openwrt-linux-muslgnueabi/7.5.0/include -I./arch/arm/include -I./arch/arm/include/generated -I./include -I./arch/arm/include/uapi -I./arch/arm/include/generated/uapi -I./include/uapi -I./include/generated/uapi -include ./include/linux/kconfig.h -include ./include/linux/compiler_types.h -D__KERNEL__ -mlittle-endian -Wall -Wundef -Werror=strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Werror=implicit-function-declaration -Werror=implicit-int -Werror=return-type -Wno-format-security -std=gnu89 -Werror -fno-dwarf2-cfi-asm -mno-unaligned-access -fno-ipa-sra -mabi=apcs-gnu -mno-thumb-interwork -marm -Wa,-mno-warn-deprecated -msoft-float -Uarm -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow --param=allow-store-data-races=0 -Wimplicit-fallthrough -Wno-unused-but-set-variable -Wno-unused-const-variable -fomit-frame-pointer -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -Wno-array-bounds -Wno-stringop-overflow -Wno-restrict -Wno-maybe-uninitialized -fno-strict-overflow -fno-merge-all-constants -fmerge-constants -fno-stack-check -fconserve-stack -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -DKBUILD_BASENAME='"devicetable_offsets"' -DKBUILD_MODNAME='"devicetable_offsets"' -fverbose-asm -S -o scripts/mod/devicetable-offsets.s scripts/mod/devicetable-offsets.c
ccache_cc -Wp,-MD,scripts/mod/.empty.o.d -nostdinc -isystem /home/openwrt/gl-infra-builder/wlan-ap/openwrt/staging_dir/toolchain-arm_cortex-a7_gcc-7.5.0_musl_eabi/lib/gcc/arm-openwrt-linux-muslgnueabi/7.5.0/include -I./arch/arm/include -I./arch/arm/include/generated -I./include -I./arch/arm/include/uapi -I./arch/arm/include/generated/uapi -I./include/uapi -I./include/generated/uapi -include ./include/linux/kconfig.h -include ./include/linux/compiler_types.h -D__KERNEL__ -mlittle-endian -Wall -Wundef -Werror=strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Werror=implicit-function-declaration -Werror=implicit-int -Werror=return-type -Wno-format-security -std=gnu89 -Werror -fno-dwarf2-cfi-asm -mno-unaligned-access -fno-ipa-sra -mabi=apcs-gnu -mno-thumb-interwork -marm -Wa,-mno-warn-deprecated -msoft-float -Uarm -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow --param=allow-store-data-races=0 -Wimplicit-fallthrough -Wno-unused-but-set-variable -Wno-unused-const-variable -fomit-frame-pointer -fno-var-tracking-assignments -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -Wno-array-bounds -Wno-stringop-overflow -Wno-restrict -Wno-maybe-uninitialized -fno-strict-overflow -fno-merge-all-constants -fmerge-constants -fno-stack-check -fconserve-stack -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -DKBUILD_BASENAME='"empty"' -DKBUILD_MODNAME='"empty"' -c -o scripts/mod/empty.o scripts/mod/empty.c
In file included from <command-line>:0:0:
././include/linux/kconfig.h:5:10: fatal error: generated/autoconf.h: No such file or directory
#include <generated/autoconf.h>
compilation terminated.
make[6]: [scripts/Makefile.build:99: scripts/mod/devicetable-offsets.s] Error 1 (ignored)
set -e; mkdir -p scripts/mod/; trap "rm -f scripts/mod/.devicetable-offsets.h.tmp" EXIT; { echo "#ifndef __DEVICETABLE_OFFSETS_H__"; echo "#define __DEVICETABLE_OFFSETS_H__"; echo "/*"; echo " * DO NOT MODIFY."; echo " *"; echo " * This file was generated by Kbuild"; echo " */"; echo ""; sed -ne 's:^[[:space:]]*\.ascii[[:space:]]*"\(.*\)".*:\1:; /^->/{s:->#\(.*\):/* \1 */:; s:^->\([^ ]*\) [\$#]*\([^ ]*\) \(.*\):#define \1 \2 /* \3 */:; s:->::; p;}' < scripts/mod/devicetable-offsets.s; echo ""; echo "#endif"; } > scripts/mod/.devicetable-offsets.h.tmp; if [ ! -r scripts/mod/devicetable-offsets.h ] || ! cmp -s scripts/mod/devicetable-offsets.h scripts/mod/.devicetable-offsets.h.tmp; then : ' UPD scripts/mod/devicetable-offsets.h'; mv -f scripts/mod/.devicetable-offsets.h.tmp scripts/mod/devicetable-offsets.h; fi
/bin/sh: 1: cannot open scripts/mod/devicetable-offsets.s: No such file
make[6]: [scripts/mod/Makefile:12: scripts/mod/devicetable-offsets.h] Error 2 (ignored)
make[6]: [scripts/Makefile.build:297: scripts/mod/empty.o] Error 1 (ignored)
scripts/mod/mk_elfconfig < scripts/mod/empty.o > scripts/mod/elfconfig.h
/bin/sh: 1: cannot open scripts/mod/empty.o: No such file
make[6]: [scripts/mod/Makefile:25: scripts/mod/elfconfig.h] Error 2 (ignored)
gcc -Wp,-MD,scripts/mod/.modpost.o.d -Wall -Wmissing-prototypes -Wstrict-prototypes -O2 -fomit-frame-pointer -std=gnu89 -O2 -I/home/openwrt/gl-infra-builder/wlan-ap/openwrt/staging_dir/host/include -Wall -Wmissing-prototypes -Wstrict-prototypes -I/home/openwrt/gl-infra-builder/wlan-ap/openwrt/staging_dir/host/include -c -o scripts/mod/modpost.o scripts/mod/modpost.c
gcc -Wp,-MD,scripts/mod/.sumversion.o.d -Wall -Wmissing-prototypes -Wstrict-prototypes -O2 -fomit-frame-pointer -std=gnu89 -O2 -I/home/openwrt/gl-infra-builder/wlan-ap/openwrt/staging_dir/host/include -Wall -Wmissing-prototypes -Wstrict-prototypes -I/home/openwrt/gl-infra-builder/wlan-ap/openwrt/staging_dir/host/include -c -o scripts/mod/sumversion.o scripts/mod/sumversion.c
gcc -Wp,-MD,scripts/mod/.file2alias.o.d -Wall -Wmissing-prototypes -Wstrict-prototypes -O2 -fomit-frame-pointer -std=gnu89 -O2 -I/home/openwrt/gl-infra-builder/wlan-ap/openwrt/staging_dir/host/include -Wall -Wmissing-prototypes -Wstrict-prototypes -I/home/openwrt/gl-infra-builder/wlan-ap/openwrt/staging_dir/host/include -c -o scripts/mod/file2alias.o scripts/mod/file2alias.c
In file included from scripts/mod/modpost.c:21:
scripts/mod/modpost.h:17:10: fatal error: elfconfig.h: No such file or directory
17 | #include "elfconfig.h"
make[6]: [scripts/Makefile.host:124: scripts/mod/modpost.o] Error 1 (ignored)
In file included from scripts/mod/file2alias.c:13:
make[6]: [scripts/Makefile.host:124: scripts/mod/file2alias.o] Error 1 (ignored)
In file included from scripts/mod/sumversion.c:11:
make[6]: [scripts/Makefile.host:124: scripts/mod/sumversion.o] Error 1 (ignored)
gcc -o scripts/mod/modpost scripts/mod/modpost.o scripts/mod/file2alias.o scripts/mod/sumversion.o -L/home/openwrt/gl-infra-builder/wlan-ap/openwrt/staging_dir/host/lib
gcc: error: scripts/mod/modpost.o: No such file or directory
gcc: error: scripts/mod/file2alias.o: No such file or directory
gcc: error: scripts/mod/sumversion.o: No such file or directory
gcc: fatal error: no input files
make[6]: [scripts/Makefile.host:116: scripts/mod/modpost] Error 1 (ignored)
make -f ./scripts/Makefile.build obj=.
ccache_cc -Wp,-MD,kernel/.bounds.s.d -nostdinc -isystem /home/openwrt/gl-infra-builder/wlan-ap/openwrt/staging_dir/toolchain-arm_cortex-a7_gcc-7.5.0_musl_eabi/lib/gcc/arm-openwrt-linux-muslgnueabi/7.5.0/include -I./arch/arm/include -I./arch/arm/include/generated -I./include -I./arch/arm/include/uapi -I./arch/arm/include/generated/uapi -I./include/uapi -I./include/generated/uapi -include ./include/linux/kconfig.h -include ./include/linux/compiler_types.h -D__KERNEL__ -mlittle-endian -Wall -Wundef -Werror=strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Werror=implicit-function-declaration -Werror=implicit-int -Werror=return-type -Wno-format-security -std=gnu89 -Werror -fno-dwarf2-cfi-asm -mno-unaligned-access -fno-ipa-sra -mabi=apcs-gnu -mno-thumb-interwork -marm -Wa,-mno-warn-deprecated -msoft-float -Uarm -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow --param=allow-store-data-races=0 -Wimplicit-fallthrough -Wno-unused-but-set-variable -Wno-unused-const-variable -fomit-frame-pointer -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -Wno-array-bounds -Wno-stringop-overflow -Wno-restrict -Wno-maybe-uninitialized -fno-strict-overflow -fno-merge-all-constants -fmerge-constants -fno-stack-check -fconserve-stack -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -DKBUILD_BASENAME='"bounds"' -DKBUILD_MODNAME='"bounds"' -fverbose-asm -S -o kernel/bounds.s kernel/bounds.c
set -e; mkdir -p include/generated/; trap "rm -f include/generated/.timeconst.h.tmp" EXIT; { echo | bc -q kernel/time/timeconst.bc; } > include/generated/.timeconst.h.tmp; if [ ! -r include/generated/timeconst.h ] || ! cmp -s include/generated/timeconst.h include/generated/.timeconst.h.tmp; then : ' UPD include/generated/timeconst.h'; mv -f include/generated/.timeconst.h.tmp include/generated/timeconst.h; fi
bash scripts/atomic/check-atomics.sh
make[6]: [scripts/Makefile.build:99: kernel/bounds.s] Error 1 (ignored)
set -e; mkdir -p include/generated/; trap "rm -f include/generated/.bounds.h.tmp" EXIT; { echo "#ifndef __LINUX_BOUNDS_H__"; echo "#define __LINUX_BOUNDS_H__"; echo "/*"; echo " * DO NOT MODIFY."; echo " *"; echo " * This file was generated by Kbuild"; echo " */"; echo ""; sed -ne 's:^[[:space:]]*\.ascii[[:space:]]*"\(.*\)".*:\1:; /^->/{s:->#\(.*\):/* \1 */:; s:^->\([^ ]*\) [\$#]*\([^ ]*\) \(.*\):#define \1 \2 /* \3 */:; s:->::; p;}' < kernel/bounds.s; echo ""; echo "#endif"; } > include/generated/.bounds.h.tmp; if [ ! -r include/generated/bounds.h ] || ! cmp -s include/generated/bounds.h include/generated/.bounds.h.tmp; then : ' UPD include/generated/bounds.h'; mv -f include/generated/.bounds.h.tmp include/generated/bounds.h; fi
/bin/sh: 1: cannot open kernel/bounds.s: No such file
make[6]: [Kbuild:14: include/generated/bounds.h] Error 2 (ignored)
There seems to be a new GL-iNet Beta build out here. The ax1800.tar.gz file needs to be extracted fully. Have not tested it myself.
its now on dl.gl-inet.com too now under Beta section.
Edit: i even manage to get it to do reboot loops just by connecting it into repeater mode! whoops.
Is your main wifi 160MHz? The beta firmware crash when connect to 160MHz wifi and that needs to be fixed.
In the latest beta i found a bug with wpa2/wpa3 encryption:
When i try to connect a device who doesn’t support wpa3,doesn’t connect at all.
Devices who support wpa3 works fine.
The solution for now is to use wpa/wpa2-psk only…
Thanks for the reply, yeah i was shocked it was so easy to crash out.
Still unable to compile 5.4 yml’s though same error during the compile run, whilst No issue on the same VM to compile the Linksys firmware.
I was hoping to get a 5.4 Kernel Clean version with some tweaks and Qosify on the flint so i could start working on the Linksys to enable Mesh nodes to work on it.
Edit: So i found the issue to why compiling stopped working.
In ~/gl-infra-builder/wlan-ap/openwrt/build_dir/toolchain-arm_cortex-a7_gcc-7.5.0_musl_eabi there was a broken symlink called linux which was being symlinked to linux-5.4.164 in the same directory however the directory was linux-5.4.164-qsdk-d5fcb18e5420670c8734c6a659873e73adab6dac
So either the linux-5.4.164-qsdk-d5fcb18e5420670c8734c6a659873e73adab6dac directory was ment to get renamed to linux-5.4.164 before symlinking or the script for symlinking didn’t take the download file name into question.
Currently the compile is still going with both .ipk and .apk extensions.
how to list wireless clients?
iw station dump does not work
Where is Tor ?
Probs like SQM didn’t compile correctly so not included. Give them chance.
Hello. These are BETA builds. There are going to be a lot of features and functions that do not work. The developers have stated that they know of most of the issues and are working on them. I would suggest a stable build download if these bugs are not your cup of tea.
Perhaps confused!
Do not use a VPN, on the contrary, DO use!
Yes. This seems confusing.
Right in terms of OpenWRT firmware, i have decided to do the build from scratch and have done 2 compiles so far adding bits in a bit at a time.
Here is the current result:
So now i am going to do the next test which is compile everything and see if it still builds after correctly if it does, i will then start putting the customised stuff in and setup the repo’s for the mirror.
Looks like good progress. Onwards and upwards.
Now I hit a snag, it’s now compiling .APK files as well as .ipk files, looked in menuconfig and unselected APK however it’s still compiling APK files which in turn kills the images compile due to lack of room.
If someone could point me in how to stop .APK compiling be gratefully received as this is the stopping point right now.
Update: Until I can find away to stop the .APK compiling I am going to stop compiles for awhile.
Ok everyone i have some good news.
I have managed to compile Kernel 5.4 with everything like Wireless working. However will need testers.
This has the following Apps Pre-installed:
Adblock
Wifi Schedule
banIP
Watchcat
Wake on LAN
Terminal
uHTTPd
UPnP
Network Shares (KSMBD)
VPN Bypass
OpenVPN
VPN Policy Routing
WireGuard
Statistics
Argon Theme (Also Config)
OpenWRT 2020 Theme
DNSCrypt-Proxy v2
SQM (With Cake)
QoS
{REMOVED DUE TO BRICKING}
If you have used my other build R16273 please use the factory image and start with a clean setup.
Known Bugs:
During boot kmod complains about dependencies
dependency not loaded nf_flow_table
dependency not loaded nf_conntrack_tftp
dependency not loaded nf_conntrack_snmp
dependency not loaded nf_conntrack_sip
dependency not loaded nf_conntrack_pptp
dependency not loaded nf_conntrack_irc
dependency not loaded nf_conntrack_h323
dependency not loaded nf_conntrack_ftp
dependency not loaded nf_conntrack_amanda
dependency not loaded nf_conntrack_broadcast
dependency not loaded nf_nat
missing dependency nf_conntrack
missing dependency nf_defrag_ipv4
missing dependency nf_defrag_ipv6
If you encounter a Bug please let me know in this thread.
Updated Script:
#!/bin/bash
## Update and install required packages for Gl-Inet Intra Cross Compile ##
sudo apt update && sudo apt dist-upgrade -y
sudo apt install -y build-essential gawk gcc-multilib flex git gettext libncurses5-dev \
libssl-dev python3-distutils zlib1g-dev neofetch qemu-guest-agent python3-yaml rsync sshpass \
## Clone Intra ##
git clone https://github.com/solidus1983/gl-infra-builder.git
cd ~/gl-infra-builder
python3 setup.py -c config-wlan-ap-5.4.yml
#python3 setup.py -c config-wlan-ap.yml
## Add Themes ##
cd ~/gl-infra-builder/wlan-ap/openwrt/package
git clone https://github.com/jerrykuku/luci-theme-argon.git
git clone https://github.com/jerrykuku/luci-app-argon-config.git
## Complete Intra Setup ##
#./scripts/gen_config.py target_wlan_ap-gl-ax1800-5-4 luci
./scripts/gen_config.py target_wlan_ap-gl-ax1800-5-4 solidus1983
### Run Menuconfig to adjust things ##
./scripts/getver.sh > ~/gl-infra-builder/wlan-ap/openwrt/version.info
cat ~/gl-infra-builder/wlan-ap/openwrt/version.info
read -p "Edit the .config file and then press any key to continue... " -n1 -s
make menuconfig
## Compile ##
make -j$(($(nproc)+1)) V=sc tools
make -j$(($(nproc)+1)) V=sc toolchain
make -i -j$(($(nproc)+1)) V=sc
#IGNORE_ERRORS=1 make -j$(($(nproc)+1)) V=sc ## Force compile even with errors
#make -j1 V=sc ## Diaganostics
If you want to test the official function with kernel 5.4, I can share the beta firmware to you! it is from the GL-inet software engineer.
For AXT1800
for uboot: https://glinet-forum-cn.oss-cn-shenzhen.aliyuncs.com/firmware/AXT1800-KERNEL5.4/openwrt-ipq807x-glinet_axt1800-squashfs-nand-factory.img
for web upgrade: https://glinet-forum-cn.oss-cn-shenzhen.aliyuncs.com/firmware/AXT1800-KERNEL5.4/openwrt-ipq807x-glinet_axt1800-squashfs-sysupgrade.tar
For AX1800:
for uboot upgrade:https://glinet-forum-cn.oss-cn-shenzhen.aliyuncs.com/firmware/AX1800-KERNEL5.4/openwrt-ipq807x-glinet_ax1800-squashfs-nand-factory.img (only UI3.x to UI4.0)
for web upgrade: https://glinet-forum-cn.oss-cn-shenzhen.aliyuncs.com/firmware/AX1800-KERNEL5.4/openwrt-ipq807x-glinet_ax1800-squashfs-sysupgrade.tar
