Ok. For some reason, everytime I start the X750, I have to do a modem reboot in order for the device to recognize esim and EID. But when I try to download esim, I still get this error "Err message:Get euicc info failed. |" I tried multiple different esim, all getting same error.
Also, the esim app still from time to time failed to get EID and then stopped showing up in the menu until I reboot the modem. Does it mean the SIM card I get from the store is defective?
Please follow the steps to share the device to us to check.
1.Connect the device to the internet with using an Ethernet cable or repeater mode. Make sure the device stays connected to the internet throughout the process.
2.Refer to this link GoodCloud support guide for instructions to share your device with the support account.
3.Send your device's MAC address and password to GL.iNet support at hoff.xin@gl-inet.com for further assistance.
@temerosoivan @bruce
I sent you an email referencing this post
It shows, there is a little bug, you module is in echo mode, just turn it off with ATE0 command is ok, we will fix this bug in the next firmware. @temerosoivan
I am getting " Err message:Auth server failed. " error when loading eSIMs. I tried different vendors and same result. Any idea on why?
I just got my esim kit today! I was wondering... If I have my Splitz IMEI repaired to match my phone, and I try to have the carrier switch me from a psim to an esim would everything function as normal? (not detecting the device etc.)
eSIM is supposedly binding to EID on your eSIM physical module. There is no way to trick the EID. So this won't work. Unless your carrier don't care about EID.
Hi, would this forward have eSIM support because it desapear:
Current Firmware
- Version4.0
- Firmware Type0319release3
- Compile Time2024-09-06 8:58:20(UTC+08:00)
