So for X750, how do I download that beta firmware for eSIM app to show up?
The beta firmware are developing, maybe we will release it in next fews days.
You can get the firmware what support esim function: http://download.gl-inet.com/firmware/x750/esim/
Note: X750 uses 16M NOR flash, and the storage space is almost used up. In order to add the eSIM function, we deleted the USB storage, SMS, vlan and S2S functions.
I tried download a few eSIM on X750. All of them getting this error "Err message:Auth server failed. | " They are from different stores. My X750 has EC25-AF modem
Here are logs when I try to download BetterRoaming esim ( free to download from their website)
Wed Oct 9 20:57:51 2024
DBG, IPA_DL_RETRY, lib/esim/ipa2.c:1148 [retry:0]
DBG, IPA_DL_0, lib/esim/ipa2.c:949 [es10.euicc_info1]
Wed Oct 9 20:57:52 2024
DBG, IPA_DL_1, lib/esim/ipa2.c:957 [es10.euicc_challenge]
DBG, IPA_DL_2, lib/esim/ipa2.c:965 [es9.init_auth]
Wed Oct 9 20:57:53 2024
DBG, IPA_DL_3, lib/esim/ipa2.c:988 [es10.auth_server]
Wed Oct 9 20:58:01 2024
ERR, XAT_CSIM_APDU_RESP_1, lib/esim/ipa2.c:241 [err:-1]
ERR, XAT_CSIM_2, lib/esim/ipa2.c:334 [invalid apdu_resp:(null)]
ERR, XAT_CSIM_6, lib/esim/ipa2.c:430 [invalid apdu_resp:(null)]
Wed Oct 9 20:58:09 2024
Wed Oct 9 20:58:17 2024
Wed Oct 9 20:58:25 2024
Wed Oct 9 20:58:34 2024
Wed Oct 9 20:58:42 2024
Wed Oct 9 20:58:50 2024
ERR, XAT_CSIM_1, lib/esim/ipa2.c:327 [err:-1]
DBG, IPA_DL_10, lib/esim/ipa2.c:1114 [end.err: -4, fail_reason:0]
2024-10-10 03:58:50.713, ERROR, sdk:381] Auth server failed.
2024-10-10 03:58:50.718, DEBUG, progress:52] TransProgress:Stop
I was able to setup the card with 2 E-sims (Telekom ) but the O2 E-sims did not work. it still shows 5 esims in profile but no way to enable or delete broken esims.
Also the seed profile can not be activated through the esim manager.
location germany
Hello, I have the same product of yours. I am confusing, Does X750 have the ability to add esim profiles without purchising eSIM card from Gl.iNet store?
in other word, Does X750 already have a chipset of eSIM?
Morever, What is the comfortable firmware version of esim? and where can I download it?
No. You need this SIM to store the eSIM profiles on it. It is like a eSIM to traditional SIM adapter.
let's wait his reply
yes. you need that esim from the store.
No, there isn't esim chip in device.
You need to purchase Physical eSIM from our store. eSIM — GL.iNet
The firmware support eSIM link: http://download.gl-inet.com/firmware/x750/esim/
We find your problem reason, the Willkommen esim profile is not the standard esim format, standard esim profile ICCID should be 20 digits, but Willkommen esim profile ICCID is 18 digits.
We fixed this issue by adding compatibility to our program, it can show all the sim profiles, I replied your email.
yes working correctly now.
great fast support ![]()
Thank you
I have installed the eiot club physical esim into sim 1 on my gl-x3000 and have installed latest beta firmware and enabled beta details (4.7 beta 5) but I still don't see esim manager under apps.
Esim is working and has cellular connectivity.
What have I done wrong?
Steve
The V4.7 beta firmware don't add the esim manage function, we are working this issue, please use this firmware first.
http://download.gl-inet.com/firmware/x3000/esim/
Is there any chance that Qualcom might update their software to allow support.
Cheers.
It looks like esim manager app disappeared from openwrt-x750-4.3.23-1014-1728892018.bin
Please find here:
Is your X750 firmware the same as the link above?
Yes, the 10/14 version don't have esim app in it.
If you have inserted the physical eSIM card into your X750?
The eSIM page only displayed when the modem recognizes the SIM type is eSIM.
Yes. I have installed the eSIM card bought from GL-INET store.
