GL-MT1300 Storage shortage problem
Anyone knows how to resolve internal Storage shortage problem on MT1300.
it only has usable storage for 15.5 MiB, virtually it cannot install any software apps.
but it appear is allocated most its storage to Temp space 120MiB, but not useful for general purpose!
Please check this thread:
Temp space is in RAM, not taking any Disk space.
None of them actually worked.
It requires to add SD card or USB drive .
But how the router only has 15.5MiB usable storage at the first place?
None sense reply.
It doesn't resolve any problems.
How a router only has 15.5MiB space available that is the problem!
Some routers don't even allow you to install 3rd party packages :wink:
So it's not an issue of the router itself. Just use the extroot method, and you can have as much storage as you like.
