I’ve having an issue where my Sandisk Extreme Portable SSD isn’t “recognized” on the GL-MT1300 usb port. I’ve looked at fdisk command. but no disk is shown. If I insert a microsd card, it does display in fdisk.
However, when I put the same drive on my Slate’s usb port, it’s recognized, it mounts, I can share it over the network, etc. Everything works. The drive is formatted NTFS, works and is visible in windows.
Both the Beryl and the Slate have latest updated firmware. What would cause the newer device not the see the drive, especially since the Beryl has a usb 3.0 port?
Slate:
Wed Apr 21 23:44:59 2021 kern.info kernel: [ 1779.426179] usb 1-1: new high-speed USB device number 2 using ehci-platform
Wed Apr 21 23:45:00 2021 daemon.err stubby[2024]: Could not schedule query: None of the configured upstreams could be used to send queries on the specified transports
Wed Apr 21 23:45:00 2021 kern.info kernel: [ 1779.641809] scsi host1: uas
Wed Apr 21 23:45:01 2021 kern.notice kernel: [ 1780.724896] scsi 1:0:0:0: Direct-Access SanDisk Extreme 55AE 3000 PQ: 0 ANSI: 6
Wed Apr 21 23:45:01 2021 kern.notice kernel: [ 1780.750820] scsi 1:0:0:1: Enclosure SanDisk SES Device 3000 PQ: 0 ANSI: 6
Wed Apr 21 23:45:01 2021 kern.notice kernel: [ 1780.761092] sd 1:0:0:0: [sdb] 3906963617 512-byte logical blocks: (2.00 TB/1.82 TiB)
Wed Apr 21 23:45:01 2021 daemon.err stubby[2024]: Could not schedule query: None of the configured upstreams could be used to send queries on the specified transports
Wed Apr 21 23:45:01 2021 kern.notice kernel: [ 1780.788701] sd 1:0:0:0: [sdb] Write Protect is off
Wed Apr 21 23:45:01 2021 kern.debug kernel: [ 1780.793854] sd 1:0:0:0: [sdb] Mode Sense: 37 00 10 00
Wed Apr 21 23:45:01 2021 kern.notice kernel: [ 1780.801458] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, supports DPO and FUA
Wed Apr 21 23:45:01 2021 kern.info kernel: [ 1780.834105] sd 1:0:0:0: [sdb] Optimal transfer size 1048576 bytes
Wed Apr 21 23:45:01 2021 kern.info kernel: [ 1780.881692] sdb: sdb1
Wed Apr 21 23:45:01 2021 kern.notice kernel: [ 1780.896571] sd 1:0:0:0: [sdb] Attached SCSI disk
Beryl: Nothing from after I connected the USB. I waited 5 minutes and checked again, still nothing.
I’ve had the same problem with a usb ssd, I’ve found a workaround but no solution. This thread FS#1305 - Not working UAS driver for usb hdd case ORICO 2599US3-V1 · Issue #6243 · openwrt/openwrt · GitHub explains a bit about it and give two solutions. Only the second one works in my case and doesn’t survive a reboot. What worked is this command echo 357d:7788:u > /sys/module/usb_storage/parameters/quirks but replace 357d:7788 with your own VID:PID after you do this plug the device into the router.
First you need to determine your vendor id and product id for a Samsung t5 ssd. This process will be different depending on your environment so use Google to find out how.
I just wish there was a step by step tutorial because I feel like I’m not the only one is that having this problem or there needs to be a page for supported ssd/hard drives.
