I've tried many things to fix the issue, yet nothing works. The only "working" thing is to restart the modem entirely. Once the connection drops for any number of reasons, it then refuses to reconnect again.
I've even upgraded to Preview Plan Version, 4.6.3 Release3 (2024-07-25 6:31:41)
Issue still happens.
2.4Ghz works just fine with reconnect.
I tested my other travel router, GL-A1300 (Slate Plus) latest preview version and have no issues with it.
Issue still happens, refuses to reconnect to a 5ghz network after disconnect (by user input) -or random connection dropped but now it also affects 2.4Ghz.
The only fix now is to erase the wifi profiles and reconnect manually. Restarting the router does not work.
The first time it happened was at a McDonald's Lobby, figured that it was just a crappy network thing they had going. Didn't bother me too much, but then I went to a Tacobell next day and same thing happened again figured as much it was just some proprietary network thing some corps are using. I went home and tested on my own network and observed the same thing.
This had(has) not happened with my GL-A1300.
I tried my main wifi modem TP-Link AC1900 same thing happened, then I tried a portable hotspot device "MiFi m3000" same thing happened.
I remember back in May through August of 2023 this never happened with the device. I stopped traveling for a bit because of covid in my area started to go up again, so i packed the device away. I started recently going out again so brought the device out with me and ever since i upgraded the firmware it's been nothing but issues.
As for my home environment; My house is pretty wide open, my main wifi box is in the same room as me when testing, like 3ft away from me, as for possible interference, I had my heater disabled since the start of summer so that doesn't emit 1970s emp waves, my a/c unit is on the other side of my house about 20ft away which was not running at the time.
I didn't see your reply at the time. I did a factory reset of my device on the latest firmware and still was an issue on 4.6.3, i found a beta firmware file from 2023-12-25
So i downloaded openwrt-mt3000-4.5.0-1225-1703489422 and it worked
4.5.0 Release6 Compile Time: 2023-12-25 6:59:58 (UTC+00:00)
Video of 4.5.0 beta working
I upgraded to 4.5.16 from stable and this worked too, Video of the upgrade from 4.5.0 beta to 4.5.16 stable keeping settings
From your logread file, v4.6.2, the repeater is able to connect the SSID 'M3000-833E', and obtain the IP from M3000-833E. Does it mean that you can connect only by forgetting and then manually connect with the password?
Yea I need to delete the connection and then reconnect with password again. If the connection drops or If I manually switch APs it no longer connects to previous connections that are saved. When removing the connection and then manually reconnecting with the password it will work.
For example, I connect to McDonald's wifi, it saves.the connection and it works just fine. If I somehow get disconnected, it no longer reconnects. I need to erase the wifi connection and manually connect.
When connecting to my other AP set in WPA3/WPA2 Transition Mode, it doesn't work unless I remove the connection then re-add it logread (4).tar (223.5 KB)
This wasn't the case in 4.5.0 and 4.5.16, they worked fine with WPA3/WPA2 transition
Thanks for your corporation.
Please try this test firmware in the MT3000 and repeats with your primary router to test.
Update point:
Before the repeater interface is connected by WPA3 if primary requires WPA2/WPA3 mixed mode, now the repeater interface changed to WPA2/WPA3 mixed mode to connect.
R&D assume the MIFI (m3000) Wi-Fi OTA interface or interaction issue, which something differents.
Could you mind to share your MT3000 with us? we would like to capture the WiFi OTA log, the MT3000 require to connect a WAN to access the Internet and so we remote the MT3000 via the GoodCloud, did you have WAN Internet access method now?
