[GL-MT3000] not able to detect the 5G RM520N-GL modem in 4.2 version and continuous reconnect in older versions
I am seeing issue with RM520N-GL continuous reconnect issue
Tue Feb 28 12:27:54 2023 kern.debug kernel: [ 5930.624649] PeerProbeReqSanity() - wrong IE_HT_CAP. eid_len = 0
Tue Feb 28 12:27:54 2023 kern.err kernel: [ 5930.630581] 7981@C08L1,sync_fsm_peer_request_idle_action() 2168: shiang! PeerProbeReqSanity failed!
Tue Feb 28 12:27:55 2023 kern.debug kernel: [ 5930.744990] PeerProbeReqSanity() - wrong IE_HT_CAP. eid_len = 0
Tue Feb 28 12:27:55 2023 kern.err kernel: [ 5930.750921] 7981@C08L1,sync_fsm_peer_request_idle_action() 2168: shiang! PeerProbeReqSanity failed!
Tue Feb 28 12:27:56 2023 kern.info kernel: [ 5932.313653] usb 2-1: new SuperSpeed Gen 1x2 USB device number 2 using xhci-mtk
Tue Feb 28 12:27:56 2023 kern.info kernel: [ 5932.339887] usb 2-1: LPM exit latency is zeroed, disabling LPM.
Tue Feb 28 12:27:56 2023 kern.info kernel: [ 5932.368896] option 2-1:1.0: GSM modem (1-port) converter detected
Tue Feb 28 12:27:56 2023 kern.info kernel: [ 5932.375275] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB0
Tue Feb 28 12:27:56 2023 kern.info kernel: [ 5932.382400] option 2-1:1.1: GSM modem (1-port) converter detected
Tue Feb 28 12:27:56 2023 kern.info kernel: [ 5932.388849] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB1
Tue Feb 28 12:27:56 2023 kern.info kernel: [ 5932.396000] option 2-1:1.2: GSM modem (1-port) converter detected
Tue Feb 28 12:27:56 2023 kern.info kernel: [ 5932.402351] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB2
Tue Feb 28 12:27:56 2023 kern.info kernel: [ 5932.409817] option 2-1:1.3: GSM modem (1-port) converter detected
Tue Feb 28 12:27:56 2023 kern.info kernel: [ 5932.416244] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB3
Tue Feb 28 12:27:56 2023 kern.info kernel: [ 5932.438466] qmi_wwan 2-1:1.4: cdc-wdm0: USB WDM device
Tue Feb 28 12:27:56 2023 kern.info kernel: [ 5932.446742] qmi_wwan 2-1:1.4: QuectelEC25&EC21&EG91&EG95&EG06&EP06&EM06&BG96&AG35 work on RawIP mode
Tue Feb 28 12:27:56 2023 kern.info kernel: [ 5932.460956] qmi_wwan 2-1:1.4 wwan0: register 'qmi_wwan' at usb-11200000.xhci-1, WWAN/QMI device, 3a:34:3f:9c:1e:cb
Tue Feb 28 12:27:58 2023 user.warn : skip line without '=' Default
Tue Feb 28 12:28:01 2023 kern.debug kernel: [ 5937.638395] PeerProbeReqSanity() - wrong IE_HT_CAP. eid_len = 0
Tue Feb 28 12:28:01 2023 kern.err kernel: [ 5937.644326] 7981@C08L1,sync_fsm_peer_request_idle_action() 2168: shiang! PeerProbeReqSanity failed!
Tue Feb 28 12:28:03 2023 kern.debug kernel: [ 5938.743118] PeerProbeReqSanity() - wrong IE_HT_CAP. eid_len = 0
Tue Feb 28 12:28:03 2023 kern.err kernel: [ 5938.749060] 7981@C08L1,sync_fsm_peer_request_idle_action() 2168: shiang! PeerProbeReqSanity failed!
Tue Feb 28 12:28:06 2023 kern.debug kernel: [ 5941.722029] PeerProbeReqSanity() - wrong IE_HT_CAP. eid_len = 0
Tue Feb 28 12:28:06 2023 kern.err kernel: [ 5941.727962] 7981@C08L1,sync_fsm_peer_request_idle_action() 2168: shiang! PeerProbeReqSanity failed!
Tue Feb 28 12:28:06 2023 kern.debug kernel: [ 5942.648404] PeerProbeReqSanity() - wrong IE_HT_CAP. eid_len = 0
Tue Feb 28 12:28:06 2023 kern.err kernel: [ 5942.654333] 7981@C08L1,sync_fsm_peer_request_idle_action() 2168: shiang! PeerProbeReqSanity failed!
Tue Feb 28 12:28:07 2023 kern.debug kernel: [ 5942.766995] PeerProbeReqSanity() - wrong IE_HT_CAP. eid_len = 0
Tue Feb 28 12:28:07 2023 kern.err kernel: [ 5942.772930] 7981@C08L1,sync_fsm_peer_request_idle_action() 2168: shiang! PeerProbeReqSanity failed!
Tue Feb 28 12:28:07 2023 kern.info kernel: [ 5942.974737] usb 2-1: USB disconnect, device number 2
Tue Feb 28 12:28:07 2023 kern.info kernel: [ 5942.979966] option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
Tue Feb 28 12:28:07 2023 kern.info kernel: [ 5942.988086] option 2-1:1.0: device disconnected
Tue Feb 28 12:28:07 2023 kern.info kernel: [ 5942.993111] option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
Tue Feb 28 12:28:07 2023 kern.info kernel: [ 5943.001317] option 2-1:1.1: device disconnected
Tue Feb 28 12:28:07 2023 kern.info kernel: [ 5943.006209] option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
Tue Feb 28 12:28:07 2023 kern.info kernel: [ 5943.014455] option 2-1:1.2: device disconnected
Tue Feb 28 12:28:07 2023 kern.info kernel: [ 5943.019449] option1 ttyUSB3: GSM modem (1-port) converter now disconnected from ttyUSB3
Tue Feb 28 12:28:07 2023 kern.info kernel: [ 5943.027578] option 2-1:1.3: device disconnected
Tue Feb 28 12:28:07 2023 kern.info kernel: [ 5943.032383] qmi_wwan 2-1:1.4 wwan0: unregister 'qmi_wwan' usb-11200000.xhci-1, WWAN/QMI device
Tue Feb 28 12:28:07 2023 kern.info kernel: [ 5943.330830] usb 2-1: new SuperSpeed Gen 1x2 USB device number 3 using xhci-mtk
Tue Feb 28 12:28:07 2023 kern.info kernel: [ 5943.355805] usb 2-1: LPM exit latency is zeroed, disabling LPM.
Tue Feb 28 12:28:07 2023 kern.info kernel: [ 5943.385475] option 2-1:1.0: GSM modem (1-port) converter detected
Tue Feb 28 12:28:07 2023 kern.info kernel: [ 5943.391838] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB0
Tue Feb 28 12:28:07 2023 kern.info kernel: [ 5943.398953] option 2-1:1.1: GSM modem (1-port) converter detected
Tue Feb 28 12:28:07 2023 kern.info kernel: [ 5943.405268] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB1
Tue Feb 28 12:28:07 2023 kern.info kernel: [ 5943.412425] option 2-1:1.2: GSM modem (1-port) converter detected
Tue Feb 28 12:28:07 2023 kern.info kernel: [ 5943.418740] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB2
Tue Feb 28 12:28:07 2023 kern.info kernel: [ 5943.425993] option 2-1:1.3: GSM modem (1-port) converter detected
Tue Feb 28 12:28:07 2023 kern.info kernel: [ 5943.432321] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB3
Tue Feb 28 12:28:07 2023 kern.info kernel: [ 5943.443015] qmi_wwan 2-1:1.4: cdc-wdm0: USB WDM device
Tue Feb 28 12:28:07 2023 kern.info kernel: [ 5943.448403] qmi_wwan 2-1:1.4: QuectelEC25&EC21&EG91&EG95&EG06&EP06&EM06&BG96&AG35 work on RawIP mode
Tue Feb 28 12:28:07 2023 kern.info kernel: [ 5943.458692] qmi_wwan 2-1:1.4 wwan0: register 'qmi_wwan' at usb-11200000.xhci-1, WWAN/QMI device, 3a:34:3f:9c:1e:cb
Tue Feb 28 12:28:10 2023 user.warn : skip line without '=' Default
Tue Feb 28 12:28:15 2023 kern.debug kernel: [ 5950.884060] PeerProbeReqSanity() - wrong IE_HT_CAP. eid_len = 0
Tue Feb 28 12:28:15 2023 kern.err kernel: [ 5950.890041] 7981@C08L1,sync_fsm_peer_request_idle_action() 2168: shiang! PeerProbeReqSanity failed!
Tue Feb 28 12:28:18 2023 kern.debug kernel: [ 5953.866538] PeerProbeReqSanity() - wrong IE_HT_CAP. eid_len = 0
Tue Feb 28 12:28:18 2023 kern.err kernel: [ 5953.872471] 7981@C08L1,sync_fsm_peer_request_idle_action() 2168: shiang! PeerProbeReqSanity failed!
Tue Feb 28 12:28:19 2023 kern.debug kernel: [ 5954.907825] PeerProbeReqSanity() - wrong IE_HT_CAP. eid_len = 0
Tue Feb 28 12:28:19 2023 kern.err kernel: [ 5954.913762] 7981@C08L1,sync_fsm_peer_request_idle_action() 2168: shiang! PeerProbeReqSanity failed!
Tue Feb 28 12:28:22 2023 kern.debug kernel: [ 5957.894352] PeerProbeReqSanity() - wrong IE_HT_CAP. eid_len = 0
Tue Feb 28 12:28:22 2023 kern.err kernel: [ 5957.900290] 7981@C08L1,sync_fsm_peer_request_idle_action() 2168: shiang! PeerProbeReqSanity failed!
Tue Feb 28 12:28:23 2023 kern.debug kernel: [ 5959.013577] PeerProbeReqSanity() - wrong IE_HT_CAP. eid_len = 0
Tue Feb 28 12:28:23 2023 kern.err kernel: [ 5959.019507] 7981@C08L1,sync_fsm_peer_request_idle_action() 2168: shiang! PeerProbeReqSanity failed!
Tue Feb 28 12:28:26 2023 kern.debug kernel: [ 5961.997528] PeerProbeReqSanity() - wrong IE_HT_CAP. eid_len = 0
Tue Feb 28 12:28:26 2023 kern.err kernel: [ 5962.003458] 7981@C08L1,sync_fsm_peer_request_idle_action() 2168: shiang! PeerProbeReqSanity failed!
Tue Feb 28 12:28:27 2023 kern.debug kernel: [ 5962.909591] PeerProbeReqSanity() - wrong IE_HT_CAP. eid_len = 0
Tue Feb 28 12:28:27 2023 kern.err kernel: [ 5962.915521] 7981@C08L1,sync_fsm_peer_request_idle_action() 2168: shiang! PeerProbeReqSanity failed!
Tue Feb 28 12:28:27 2023 kern.debug kernel: [ 5963.028801] PeerProbeReqSanity() - wrong IE_HT_CAP. eid_len = 0
Tue Feb 28 12:28:27 2023 kern.err kernel: [ 5963.034738] 7981@C08L1,sync_fsm_peer_request_idle_action() 2168: shiang! PeerProbeReqSanity failed!
Tue Feb 28 12:28:35 2023 kern.debug kernel: [ 5971.150190] PeerProbeReqSanity() - wrong IE_HT_CAP. eid_len = 0
Tue Feb 28 12:28:35 2023 kern.err kernel: [ 5971.156310] 7981@C08L1,sync_fsm_peer_request_idle_action() 2168: shiang! PeerProbeReqSanity failed!
Tue Feb 28 12:28:38 2023 kern.debug kernel: [ 5974.137801] PeerProbeReqSanity() - wrong IE_HT_CAP. eid_len = 0
Tue Feb 28 12:28:38 2023 kern.err kernel: [ 5974.143728] 7981@C08L1,sync_fsm_peer_request_idle_action() 2168: shiang! PeerProbeReqSanity failed!
Tue Feb 28 12:28:39 2023 kern.debug kernel: [ 5975.167788] PeerProbeReqSanity() - wrong IE_HT_CAP. eid_len = 0
Tue Feb 28 12:28:39 2023 kern.err kernel: [ 5975.173728] 7981@C08L1,sync_fsm_peer_request_idle_action() 2168: shiang! PeerProbeReqSanity failed!
Tue Feb 28 12:28:39 2023 kern.debug kernel: [ 5975.286124] PeerProbeReqSanity() - wrong IE_HT_CAP. eid_len = 0
Tue Feb 28 12:28:39 2023 kern.err kernel: [ 5975.292056] 7981@C08L1,sync_fsm_peer_request_idle_action() 2168: shiang! PeerProbeReqSanity failed!
Tue Feb 28 12:28:42 2023 kern.debug kernel: [ 5978.151885] PeerProbeReqSanity() - wrong IE_HT_CAP. eid_len = 0
Tue Feb 28 12:28:42 2023 kern.err kernel: [ 5978.157831] 7981@C08L1,sync_fsm_peer_request_idle_action() 2168: shiang! PeerProbeReqSanity failed!
Tue Feb 28 12:28:43 2023 kern.debug kernel: [ 5979.158724] PeerProbeReqSanity() - wrong IE_HT_CAP. eid_len = 0
Tue Feb 28 12:28:43 2023 kern.err kernel: [ 5979.164681] 7981@C08L1,sync_fsm_peer_request_idle_action() 2168: shiang! PeerProbeReqSanity failed!
Tue Feb 28 12:28:43 2023 kern.debug kernel: [ 5979.272015] PeerProbeReqSanity() - wrong IE_HT_CAP. eid_len = 0
Tue Feb 28 12:28:43 2023 kern.err kernel: [ 5979.277941] 7981@C08L1,sync_fsm_peer_request_idle_action() 2168: shiang! PeerProbeReqSanity failed!
Tue Feb 28 12:28:46 2023 kern.debug kernel: [ 5982.246746] PeerProbeReqSanity() - wrong IE_HT_CAP. eid_len = 0
Tue Feb 28 12:28:46 2023 kern.err kernel: [ 5982.252673] 7981@C08L1,sync_fsm_peer_request_idle_action() 2168: shiang! PeerProbeReqSanity failed!
Tue Feb 28 12:28:47 2023 kern.debug kernel: [ 5983.290979] PeerProbeReqSanity() - wrong IE_HT_CAP. eid_len = 0
Tue Feb 28 12:28:47 2023 kern.err kernel: [ 5983.296926] 7981@C08L1,sync_fsm_peer_request_idle_action() 2168: shiang! PeerProbeReqSanity failed!
Tue Feb 28 12:28:50 2023 kern.debug kernel: [ 5986.275097] PeerProbeReqSanity() - wrong IE_HT_CAP. eid_len = 0
Tue Feb 28 12:28:50 2023 kern.err kernel: [ 5986.281054] 7981@C08L1,sync_fsm_peer_request_idle_action() 2168: shiang! PeerProbeReqSanity failed!
Tue Feb 28 12:28:51 2023 kern.debug kernel: [ 5987.312758] PeerProbeReqSanity() - wrong IE_HT_CAP. eid_len = 0
Tue Feb 28 12:28:51 2023 kern.err kernel: [ 5987.318704] 7981@C08L1,sync_fsm_peer_request_idle_action() 2168: shiang! PeerProbeReqSanity failed!
Tue Feb 28 12:28:54 2023 kern.debug kernel: [ 5990.357032] PeerProbeReqSanity() - wrong IE_HT_CAP. eid_len = 0
Tue Feb 28 12:28:54 2023 kern.err kernel: [ 5990.362985] 7981@C08L1,sync_fsm_peer_request_idle_action() 2168: shiang! PeerProbeReqSanity failed!
Tue Feb 28 12:28:55 2023 kern.debug kernel: [ 5991.408413] PeerProbeReqSanity() - wrong IE_HT_CAP. eid_len = 0
Tue Feb 28 12:28:55 2023 kern.err kernel: [ 5991.414359] 7981@C08L1,sync_fsm_peer_request_idle_action() 2168: shiang! PeerProbeReqSanity failed!
Tue Feb 28 12:28:58 2023 kern.debug kernel: [ 5994.395951] PeerProbeReqSanity() - wrong IE_HT_CAP. eid_len = 0
Tue Feb 28 12:28:58 2023 kern.err kernel: [ 5994.401889] 7981@C08L1,sync_fsm_peer_request_idle_action() 2168: shiang! PeerProbeReqSanity failed!
Tue Feb 28 12:28:59 2023 kern.debug kernel: [ 5995.431716] PeerProbeReqSanity() - wrong IE_HT_CAP. eid_len = 0
Tue Feb 28 12:28:59 2023 kern.err kernel: [ 5995.437678] 7981@C08L1,sync_fsm_peer_request_idle_action() 2168: shiang! PeerProbeReqSanity failed!
Tue Feb 28 12:29:02 2023 kern.debug kernel: [ 5998.410838] PeerProbeReqSanity() - wrong IE_HT_CAP. eid_len = 0
Tue Feb 28 12:29:02 2023 kern.err kernel: [ 5998.416783] 7981@C08L1,sync_fsm_peer_request_idle_action() 2168: shiang! PeerProbeReqSanity failed!
Tue Feb 28 12:29:03 2023 kern.debug kernel: [ 5999.414799] PeerProbeReqSanity() - wrong IE_HT_CAP. eid_len = 0
Tue Feb 28 12:29:03 2023 kern.err kernel: [ 5999.420726] 7981@C08L1,sync_fsm_peer_request_idle_action() 2168: shiang! PeerProbeReqSanity failed!
Tue Feb 28 12:29:06 2023 kern.debug kernel: [ 6002.527173] PeerProbeReqSanity() - wrong IE_HT_CAP. eid_len = 0
Tue Feb 28 12:29:06 2023 kern.err kernel: [ 6002.533113] 7981@C08L1,sync_fsm_peer_request_idle_action() 2168: shiang! PeerProbeReqSanity failed!
Tue Feb 28 12:29:11 2023 kern.debug kernel: [ 6007.572831] PeerProbeReqSanity() - wrong IE_HT_CAP. eid_len = 0
Tue Feb 28 12:29:11 2023 kern.err kernel: [ 6007.578784] 7981@C08L1,sync_fsm_peer_request_idle_action() 2168: shiang! PeerProbeReqSanity failed!
Tue Feb 28 12:29:14 2023 kern.debug kernel: [ 6010.620812] PeerProbeReqSanity() - wrong IE_HT_CAP. eid_len = 0
Tue Feb 28 12:29:14 2023 kern.err kernel: [ 6010.626742] 7981@C08L1,sync_fsm_peer_request_idle_action() 2168: shiang! PeerProbeReqSanity failed!
Tue Feb 28 12:29:22 2023 kern.debug kernel: [ 6018.673718] PeerProbeReqSanity() - wrong IE_HT_CAP. eid_len = 0
Tue Feb 28 12:29:22 2023 kern.err kernel: [ 6018.679648] 7981@C08L1,sync_fsm_peer_request_idle_action() 2168: shiang! PeerProbeReqSanity failed!
Tue Feb 28 12:29:24 2023 kern.debug kernel: [ 6019.682007] PeerProbeReqSanity() - wrong IE_HT_CAP. eid_len = 0
Tue Feb 28 12:29:24 2023 kern.err kernel: [ 6019.687937] 7981@C08L1,sync_fsm_peer_request_idle_action() 2168: shiang! PeerProbeReqSanity failed!
Tue Feb 28 12:29:24 2023 kern.debug kernel: [ 6019.802447] PeerProbeReqSanity() - wrong IE_HT_CAP. eid_len = 0
Tue Feb 28 12:29:24 2023 kern.err kernel: [ 6019.808379] 7981@C08L1,sync_fsm_peer_request_idle_action() 2168: shiang! PeerProbeReqSanity failed!
Tue Feb 28 12:29:27 2023 kern.debug kernel: [ 6022.788229] PeerProbeReqSanity() - wrong IE_HT_CAP. eid_len = 0
Tue Feb 28 12:29:27 2023 kern.err kernel: [ 6022.794156] 7981@C08L1,sync_fsm_peer_request_idle_action() 2168: shiang! PeerProbeReqSanity failed!
It looks like the device is underpowered, the MT3000 USB can only provide a maximum current of 1000mA, from what I understand, the maximum instantaneous current of RM520 can reach 3000mA+
3000ma+ is peak usage. But the problem is in 4.2.0 its not showing in the attached modem. And in the 4.1.3 its showing once its connected kernel might be panicking ?
First off all device is not detecting in 4.2.0 version. In the root shell i can check and able to see the device able to connect with modem managed (Needs to be installed with QMI)
I think this is a random event, depending on whether the modem is powered down at the page refresh.
I can reproduce consistently.
Perhaps you can try turning off the 2.4G wifi to reduce the current consumption in other parts.
Will it supply more than 1000mA in USB port for peak?
How much will it supply if i turn off both Wifi bands ?
You didn’t mention how is the modem setup but most interface cases I see for 5G modems have their own separate DC input. I doubt it will work if you are purely relying on the USB port provided by the MT3000 to power the 5G modem completely. The router alone can use up to 3A and the provided power brick doesn’t give more than 15W (5V*3A)
Worst case scenario, router needs at 5V, 3A and the modem another 3A… 6A at 5V!!!
That’s a good point, these latest 5G modems require more power. I think typically their own separate DC 5v 3 to 4A input.
I expect that the USB-C port on the GL-MT3000 can provide between 1.2A/6W to 1.5A/7.5W, based on recent routers in this thread:
Yes
Thanks for sharing the thread. But i know the issue is power on peak but normal operating should be less than 1000ma so it should work
Measure it with a digital tester to know for sure instead of using gut feeling. I had the same continuos disconnections with an EM06 while using the provided 15W power brick.
My issue is first modem is not detecting in the router default UI ( i was able to see in root shell connected devices, and using modemmanager i was able to connect but in UI its not showing. Thats the issue i am raising it.
I can confirm a similar problem with detection of Quectel EM160R LTE modem - MT3000 v.4.2 / GL GUI does not detect the modem, a new modem interface is not created, but the system log checked from Luci shows that the modem was found on the USB bus. The same modem works just fine on ATX1800 Slate v.4.2 after the fix provided (via remote access) by one of GL-Inet customer support rep :
https://forum.gl-inet.com/t/using-atx1800-with-quectel-em160r-gl/23443/37?u=i7bar
I was told that it would be added in v.4.2 but looks like it was not.
