I tried connecting my GL-MT3000 to my China Mobile modem (Huawei HG8040H6) LAN port #4 but the DHCP setup doesn't complete. I have another TP-LINK wifi router connected to LAN port #1 and it works fine (I believe it also uses DHCP to get an IP from the modem).
I checked the HG8040H6's admin page (http://192.168.100.1/) and don't see any MAC address filtering or some kind of whitelist that would prevent the MT-3000 from getting an IP. The DHCP server is enabled and settings seem configured correctly (see below). The MT-3000 is listed in the device list but doesn't have an IPv4 address listed.
LAN configuration of Huawei modem:
Primary IP Address: 192.168.100.1
Primary address subnet mask: 255.255.255.0
DHCP configuration of Huawei modem:
Enable the primary DHCP server: ![]()
Enable DHCP relay: ![]()
Enabling Option 125:
LAN host IP address: 192.168.100.1
Subnet Mask: 255.255.255.0
Starting IP address: 192.168.100.2
End IP Address: 192.168.100.254
Lease period:1 day
Not sure what to do. I tried connecting the MT-3000 via ethernet to my TP-Link router instead and everything works fine. I would rather connect directly to the modem though to avoid an unnecessary hop.
