My new router mounts my 128GB flash drive fine, but I’ve tried a new 6TB external hard drive and an old 2TB one, and neither external one mounted. I include the syslog and kernel log for the flash and the 2TB drive below. There were complaints in the logs with the 6TB about it being a very large drive, but not for the 2TB.
I tried manually mounting as suggested in this old thread, but it didn’t work. https://forum.gl-inet.com/t/bug-v2-19-can-not-detect-usb-disk/1430
Thoughts?
2TB hard drive syslog:
Version 2016.2.22 integrated FUSE 27
Mounted /dev/sdc1 (Read-Write, label “F 2TB”, NTFS 3.1)
Cmdline options: utf8
Mount options: utf8,allow_other,nonempty,relatime,fsname=/dev/sdc1,blkdev,blksize=4096
Ownership and permissions disabled, configuration type 1
128GB flash syslog
Mounted /dev/sdd1 (Read-Write, label “”, NTFS 3.1)
Mount options: utf8,allow_other,nonempty,relatime,fsname=/dev/sdd1,blkdev,blksize=4096
2TB hard drive kernel log:
[ 4781.624489] usb 1-1: new high-speed USB device number 8 using ehci-platform
[ 4781.778420] usb-storage 1-1:1.0: USB Mass Storage device detected
[ 4781.800466] scsi host4: usb-storage 1-1:1.0
[ 4782.816936] scsi 4:0:0:0: Direct-Access WD Ext HDD 1021 2021 PQ: 0 ANSI: 4
[ 4782.828488] sd 4:0:0:0: [sdc] 3907024896 512-byte logical blocks: (2.00 TB/1.82 TiB)
[ 4782.844521] sd 4:0:0:0: [sdc] Write Protect is off
[ 4782.849408] sd 4:0:0:0: [sdc] Mode Sense: 17 00 10 08
[ 4782.854576] sd 4:0:0:0: [sdc] No Caching mode page found
[ 4782.860006] sd 4:0:0:0: [sdc] Assuming drive cache: write through
[ 4782.938587] sdc: sdc1
[ 4782.954719] sd 4:0:0:0: [sdc] Attached SCSI disk
128GB flash kernel log
[ 5435.890343] usb 1-1: new high-speed USB device number 9 using ehci-platform
[ 5436.044368] usb-storage 1-1:1.0: USB Mass Storage device detected
[ 5436.066387] scsi host5: usb-storage 1-1:1.0
[ 5437.072013] scsi 5:0:0:0: Direct-Access SanDisk Ultra 1.00 PQ: 0 ANSI: 6
[ 5437.083732] sd 5:0:0:0: [sdd] 242614272 512-byte logical blocks: (124 GB/116 GiB)
[ 5437.092942] sd 5:0:0:0: [sdd] Write Protect is off
[ 5437.097825] sd 5:0:0:0: [sdd] Mode Sense: 43 00 00 00
[ 5437.098925] sd 5:0:0:0: [sdd] Write cache: disabled, read cache: enabled, doesn’t support DPO or FUA
[ 5437.140861] sdd: sdd1
[ 5437.151080] sd 5:0:0:0: [sdd] Attached SCSI removable disk
