The GL-MT300N V2-ec6 running Version 3.102 firmware setup in repeater mode does not automatically connect to wifi at boot. The SSID and password are saved properly.
If I select the remembered WiFi network SSID and press [Join] the message “wifi not in range” will be immediately displayed.
If I select the Scan link in the Repeater section of http://192.168.8.1/#/internet the SSID will be found and I can connect by entering the password.
I would like the MT300N to connect to the saved wifi on boot. Any recommendations on how to resolve this problem?
This morning I located the issue and this is resolved. Here is the background information.
Internet connectivity is provided by a Cellular to WiFi hotspot. The GL-MT300N-V2 (Mango) subscribes to the SSID provided by the WiFi hotspot. I then have various devices attached to the LAN port. My application does not need a WiFi hotspot provided by the Mango and so I turned that functionality off. By turning off the 2.4G WiFi hotspot, the Mango will no longer connect automatically to Internet WiFi connection.
To resolve this issue I re-enabled the Mango 2.4G WiFi.
To protect the Mango 2.4G WiFi from being accessed by clients, since I cannot disable it without disabling the bridge connection to the cellular hotspot, I hid the SSID and gave it a long random password.
OpenWRT should allow one to subscribe to a WiFi gateway and not enable itself as a WiFi hotspot.
Thanks for replying so promptly and I hope you have a great day.
in gladmin web\ internet click on “repeater options” and set to autoconnect
in gladmin web\wireless if there is a green dot under 2.4gzh tab click the “on” button on the far right and wait for it to turn off.
then edit router from rj45 jack
I tried those settings prior to my initial posting. I’ve tried them again. Upon reboot, OpenWRT does not reconnect to the WiFi gateway subscription.
When the web/wireless setting for 2.4GHz is enabled, the Mango will connect to the Internet WiFi subscribed SSID. I suspect a bug, however, I can work around it.
Yes, if one disables the AP on the Mango then the wireless ISP connection no longer automatically connects on boot. One must initiate a scan, locate the wisp SSID and enter the password. If the AP on the Mango is NOT disabled, the wisp automatically reconnects at boot.
