hi, i’m trying to set up a private vpn between two offices, i’m using two small devices that have a built-in openvpn function Mini Travel Router, WiFi Converter, OpenWrt Pre-Installed, Repeater Bridge, 300Mbps High Performance, OpenVPN Client) i’ve correctly set up server and client but i can’t ping from server side to client side while yes i’m be able to do the reverse, any suggest how to fix it? thanks in advance for your support.
Hi, you can view related topics. Openvpn site-to-site - #8 by luochongjun
Back history
There is no reason to install “vanilla” OpenWRT unless you really need. You can set up a server using Wireguard via the GL UI. Here is how to do that:
Jump down to server, and then for each client follow the client section.
