Hi All,
I have a GL-MT300N-V2 (v2.271 firmware) that I want to use as a dumb AP (with a shared SSID and password) via a wired bridge. However I cannot seem to connect via the WiFi to the unit.
I am attempting to do what this poster did: GL-MT300N Wired Bridge?.
My setup:
Main router is on 192.168.1.1 and is the gateway to internet with the DHCP server. DHCP starts at 192.168.1.50. I have 2 other routers configured as dumb APs on 192.168.1.2 and 192.168.1.3 with the same SSID and password.
I have configured the GL-MT300N-V2 unit to be on IP 192.168.1.4. Plugged it in via LAN and firewall script is disabled. Switch function is set to disabled. I can access the unit via the LAN IP address no problems.
When I am in the room with this unit, I can see the radio broadcasting and when my phone connects it gets an IP of 169.254.86.87…
In the Luci interface, under the wireless section, I see the message “Wireless is disabled or not associated”, same as this poster gets: GL-MT300N-V2 Wireless is disabled or not associated
I want to set a static IP for this router so that all of of my routers are outside of my DHCP range, but if needs be I’ll make it work some other way.
Anybody got any tips or ideas please? I’m sure I just missed some config steps… ![]()
Thanks
Jonathan
