[GL-MT6000 / Flint 2] Bricked (GPT Corruption) - Seeking Web UI Recovery Files
Hello everyone,
I am writing to share my experience trying to recover a bricked GL-MT6000 (Flint 2) and to seek assistance from the GL.iNet support team.
I recently bricked my Flint2 router after some partition operation that was not well planned. The device is now unresponsive to standard recovery methods. I can access the U-Boot Web UI by connecting my Ethernet cable to Port #3 (LAN2). However, recovery via uploading relevant file from GLi.NET via this option, fails。
My next step was Serial Console Recovery via the UART pins. However, upon opening my unit , I found that the UART pins are practically inaccessible, obstructed by plastic channels/cable guides glued or placed directly over the area with no easy way to dismantle.
Request for Help @GL.iNet @GL.iNet Support) I have seen in other threads, such as making an MT6000 Flint2 router work again , that official support can provide specific low-level files like uboot.fip and art partitions to help resolve deep brick scenarios.
However, if flashing those specific files requires an active Serial/UART connection, this method is simply out of my reach due to the physical obstruction. Therefore, my highly preferred and possible only next option is: is it possible to receive a special .bin image or a GPT Dump Image that restores the full eMMC partition structure directly via the U-Boot Web UI? Since my U-Boot web interface is still accessible, a single file that rebuilds the partition map blindly without needing UART access would be a lifesaver.
If this is possible, I can provide my router's MAC address via private Message.
Thank you in advance for your time and support!
We have sent you the download link for the relevant files via private message. Please check your inbox.
This here is the reason we back you guys^.
Great work, never change.
