GL-MT6000 Flint 2 - SQM not shaping upload speed after a reboot
Quick check:
have you disabled these options here in luci firewall:
Maybe also try to disable hardware acceleration on the gl ui to be extra sure.
Then replace cake with fqcodel (ive readed fqcodel works a bit better than cake on this soc mainly for higher speeds).
then reboot.
Edit:
Also it is likely wed is enabled too (wifi only), wed and SQM is a little complicated topic, one says it bypass sqm, the other tested it fine, + theres also tuning going on by OpenWrt upstream so you might want to play with this setting too and restart.
Of course
Seems like this actually helped
But, after a reboot...
You had to add /etc/init.d/sqm restart on the startup or not?
Tried that workaround and not working on the MT3000, op24.
Turn this off.
It is, the issue is after a reboot, then if disable it and enable it again it works, or if I restart it through SSH. I guess the process of the GL firmware is causing the issue, just like you said
Can you confirm that SQM is running after a restart?
/etc/init.d/sqm status
root@GL-MT3000:~# /etc/init.d/sqm status
active with no instances
root@GL-MT3000:~#
Settings
config queue 'eth1'
option enabled '1'
option interface 'eth0'
option download '4000'
option upload '4000'
option qdisc 'cake'
option script 'piece_of_cake.qos'
option linklayer 'ethernet'
option debug_logging '0'
option verbosity '5'
option overhead '44'
root@GL-MT3000:~#
MT3000
No problem with the test
Should it be eth1 as per the answer above?
yeap
You should also turn off hardware acceleration on the page
eth0 is the wan interface, it is supposed to be set there.
Using eth1 SQM works good, even after a reboot, all good
Connected using a cable because eth1 is the LAN port, when I test over Wi-Fi SQM doesn't work at all, doesn't shape upload and download.
Hardware acceleration is disabled, I might have forgotten to disable it once while testing yesterday because I tried 4.5.16, 4.6.2 and 4.6.0-op24 but I have the same issue.
If I choose eth0 and apply settings it works over Wi-Fi, shapes both, after the reboot it only shapes download not upload. So, back to the same issue.
I tried to move the startup position and it didn't help, will keep trying.
Yes, I have to because the service wasn't starting back up after a reboot :call_me_hand:
Confirmed on my setup. We really have to deal with this bufferbloat asap GL…. Not acceptable.
Because we have qos in our firmware
Both qos and sqm are rate-limiting software and are incompatible
  1. /etc/init.d/gl_eqos stop
  2. /etc/init.d/gl_eqos disable
  3. Add a line
So, should your script at /etc/init.d/sqm have a /etc/init.d/gl_eqos stop if it's running?
And also the opposite... When you start the gl_eqos, it must check if SQM is running. If yes, then stop it, once both are incompatible with each other.
It won't work.
As far as the current firmware is concerned, sqm is a third party plugin and we cannot implement this operation
Article 2 May be considered
@Renato @Steve68 @Niet
Test it out?
I tested and found no issues, I will merge the next firmware version
I'm not using SQM, so I cannot test it :slight_smile:
But in your script, it's checking only eth1... Probably will be better if it checks all ports and not only eth1
Not very realistic
You will need at least the ports that can multi-wan out of the box. OR maybe the ability to disable the QOS from the GUI?
