I bought a MT6000 and want to use is at a VPN server providing both IPv4 and IPv6 connectivity among other things. As a disclaimer I'm using the latest stable firmware 4.5.8 and not a preview firmware.
After enabling the IPv6 support on the router, I was happy to notice that the WireGuard Server got assigned IPv6 addresses from fd00:db8:0:abc::/64 subnet in addition to the usual 10.0.0.0/24. What puzzled me quite a bit was that there were no IPv6 packets going through the tunnel even though the configuration all seemed good and the client had the ::/0 route automatically set to their peer configs as well.
Upon further investigation, it turned out that the AllowedIPs section in /tmp/wireguard/wgserver only had the IP address (e.g. 10.0.0.2) included in it and no IPv6 address, meaning all IPv6 packets were blocked on the router. I fixed this using wg set wgserver peer <publicKey> allowed-ips 10.0.0.2,fd00:db8:0:abc::2 and the packets started going through, but even though I had both Remote Access LAN and IP Masquerading enabled in the WireGuard Server Options, I could not access either LAN or WAN from the WireGuard tunnel. I did extensive research on this forum and also reading through the scripts on the router, but couldn't find any documentation, so posting everything I know here in case it's useful for others as well.
I found out that the first issue with the allowed-ips not including the IPv6 address was related to /lib/netifd/proto/wgserver.sh script discarding all IP addresses except for the first one. The config /etc/config/wireguard_server correctly includes option client_ip '10.0.0.2/24,fd00:db8:0:abc::2/64' with both addresses, but /lib/netifd/proto/wgserver.sh line echo "AllowedIPs=${client_ip%%/*}" >> "${wg_cfg}" effectively truncates it into 10.0.0.2.
Related to the masquerading problem, it seems like the problem is in the firewall, particularly in the /etc/firewall.nat6 script. I see it has a special handling for the guest zone in handle_guest_zone function that marks the packets in PREROUTING of the mangle table and then masquerades them in the zone_wan_postrouting chain based on the mark, to allow IPv6 masquerading. I don't even use the guest zone, but I feel something similar should be done for the wgserver, I tried adding a simple ip6tables -t mangle -I PREROUTING -i wgserver -j MARK --set-xmark 0xaa/0xaa entry for the wgserver zone, effectively treating it as a guest zone and all my problems were resolved.
I can send some sample scripts that worked for me in this topic, but I'd like to ask if this is a known issue and if there's a better fix available?
Replying to myself here, but just after posting the original topic, I found the real issue with the /etc/firewall.nat6 script.
Edit: Removed some incorrect information from here, I thought I found an issue with firewall.nat6, but it turns out I was wrong and had just lost track of my own changes. The original message still stands that I've ended up fixing this locally by running the guest network setup for the wgserver zone/interface as well.
Thanks for a super quick response, really appreciate it!
For the first AllowedIPs problem I ended up with going with something like:
local ip_cidr allowed_ips IFS=","
for ip_cidr in $client_ip; do
allowed_ips="${allowed_ips:+$allowed_ips,}${ip_cidr%%/*}"
config_foreach detect_route_allowed route_rules ${ip_cidr%%/*}
done
echo "AllowedIPs=${allowed_ips}" >> "${wg_cfg}"
in the load_peers() function of /lib/netifd/proto/wgserver.sh. It's a bit verbose, but does the job and creates a fairly tidy AllowedIPs configuration for me. I might have to reset my router to double-check, but I believe moving the return inside the if and adding the following loop have fixed both issues now for me. I'm mainly just worried things will get mixed up on firmware upgrades.
Thanks Bruce for the updates! Honestly, this customer support experience is making me more likely to recommend GL.iNet products to my friends and family. Hope you find an elegant solution to the NAT6 problem as well, ideally it would route to both WAN and LAN interfaces.
Hey Bruce, sorry for a slow reply, I just wanted to verify that everything works as I expected before posting.
What I personally did was just modify the handle_guest_zone() function of /etc/firewall.nat6 to instead of using hardcoded br-guest interface name instead allow a configurable interface as follows:
handle_guest_zone() {
zone_name="wan"
local iface="$1"
if ! ip6tables -t mangle -C PREROUTING -i "$iface" -j MARK --set-xmark 0xaa/0xaa &>/dev/null; then
ip6tables -t mangle -I PREROUTING -i "$iface" -j MARK --set-xmark 0xaa/0xaa
fi
local postrouting_chain="zone_${zone_name}_postrouting"
ip6t_add "$postrouting_chain" -t nat \
-m mark --mark 0xaa/0xaa -m comment --comment "!fw3" -j MASQUERADE
local input_chain="zone_${zone_name}_input"
ip6t_add "$input_chain" -t filter -m conntrack --ctstate DNAT \
-m comment --comment "!fw3: Accept port forwards" -j ACCEPT
local forward_chain="zone_${zone_name}_forward"
ip6t_add "$forward_chain" -t filter -m conntrack --ctstate DNAT \
and then in the handle_zone() call it for both guest and wgserver:
if [ "$(uci -q get glipv6.lan.mode)" == "native" -o "$(uci -q get glipv6.lan.mode)" == "relay" ];then
if [ "$zone_name" == "guest" ];then
handle_guest_zone "br-guest"
fi
if [ "$zone_name" == "wgserver" ];then
handle_guest_zone "wgserver"
fi
return
fi
but I'm still not quite certain if this is the best solution. However, if I try to connect to WAN it works just fine, and if I try to connect to LAN it's connecting from the fd00:db8:0:abc::2 address just like it's connecting from the 10.0.0.2/24 when using IPv4. I also have the guest network enabled and haven't seen anything weird there.
In case it helps, I've just used the above method to modify the firewall.nat6 and wgserver.sh files, and been using IPv6 without issues through my VPN for quite a bit. The only slight downside is that all the changes get reverted when upgrading the device to the latest firmware, but during the time I've owned it there's been just one stable firmware release, so it's not that much of a hassle. I hope we get improved IPv6 support in an official firmware soon.
Thanks for your suggestions.
As you said just release one stable firmware, it is very careful and rigorous for a stable version.
Already in plan, please await.
I'm having a similar problem. I setup VPN for just one device to use it. I don't mind if IPv6 doesn't work for this specific device via VPN but as soon as I activate the VPN all other devices in my network loose IPv6 connectivity aswell even though they are not routed through the VPN.
Absolutely follow the steps @juhovh laid out in this thread. If memory serves, there are three key files you need to tweak. The guy’s a wizard—he got it working flawlessly on my setup with these exact settings. If you run into any hiccups, slide into my DMs; I’m more than happy to assist.
Here's hoping the Gl-iNet devs roll these changes into the next firmware update, so we can skip the manual tweaks in the future.
Thank you but I think this does not solve my issue as I am having problems with the Wireguard Client instead of the Wireguard Server.
I am connecting to a Mullvad VPN via the build-in Wireguard client. I thought my issue might be related and would be fixed in a new update aswell.
EDIT: Just saw the warning in the IPv6 settings that IPv6 and VPN are known to cause issues if used at the same time. Guess I'll just wait for this to be implemented.
Before I set up my own WG Server for a residential IP, I was using Mullvad, and it ran flawlessly. My provider doesn’t natively support IPv6, but switching over to NAT for IPv6 gave me a public IPv6 address without a hitch. Give it a shot!
Thanks for your suggestion. I am not sure where the problem might be. I am on stock firmware 4.6.2. I haven't done any manual work on the router so far. Everything should be "vanilla" and setup via the GL.iNet interface.
I do have a native IPv6 connectivity. It's working fine while the VPN is disabled and I can reach IPv6 websites without any problems. As soon as I activate the VPN the IPv6 connection on all devices is lost no matter if they are routed through the VPN or not. I wouldn't mind if the devices which gets routed through the VPN does not have IPv6 connectivity but I would need it on the devices which are not routed throught the VPN.
Native IPv6 didn’t work for me either. I’d suggest changing the mode to NAT6, at least just to test it out. You can do this from the IPv6 settings under the Network section.
