GL-SF1200 dnsmasq stops responding after few hours - few days of uptime
I have a pair of GL-SF1200 as a main 5GHz + 2.4GHz router and GL-E750 Mudi as a 5GHz WDS extender.
Once every day or two DNS server on GL-SF1200 stops responding. When I enter it’s SSH, I see that dnsmasq process is stuck in a “D” sate, so it’s impossible to kill it and restart, I have to reboot the router.
The GL-SF1200’s firmware is 3.215 (2022-09-21 11:49:06)
Here is some info from dnsmasq /proc filesystem:
root@GL-SF1200:/proc/1751# cat status
Umask:	0022
State:	D (disk sleep)
Tgid:	1751
Ngid:	0
Pid:	1751
PPid:	1
TracerPid:	0
Uid:	453	453	453	453
Gid:	453	453	453	453
FDSize:	256
Groups:
VmPeak:	    2936 kB
VmSize:	    2936 kB
VmLck:	       0 kB
VmPin:	       0 kB
VmHWM:	    1708 kB
VmRSS:	    1708 kB
RssAnon:	     140 kB
RssFile:	    1568 kB
RssShmem:	       0 kB
VmData:	     156 kB
VmStk:	     132 kB
VmExe:	     320 kB
VmLib:	    2284 kB
VmPTE:	      16 kB
VmPMD:	       0 kB
VmSwap:	       0 kB
Threads:	1
SigQ:	2/932
SigPnd:	00000000000000000000000000000100
ShdPnd:	00000000000000000000000000004100
SigBlk:	00000000000000000000000000000000
SigIgn:	00000000000000000000000000001000
SigCgt:	0000000000000000000000000003e003
CapInh:	0000000000000000
CapPrm:	0000000000003400
CapEff:	0000000000003400
CapBnd:	0000003fffffffff
CapAmb:	0000000000000000
NoNewPrivs:	0
Speculation_Store_Bypass:	unknown
Cpus_allowed:	f
Cpus_allowed_list:	0-3
voluntary_ctxt_switches:	6479
nonvoluntary_ctxt_switches:	261
root@GL-SF1200:/proc/1751# cat syscall
0 0x4 0x8915 0x7fbcc970 0x1 0x0 0x0 0x7fbcc850 0x77ef15a8
root@GL-SF1200:/proc/1751# cat stack
[<805354b8>] devinet_ioctl+0x158/0xb10
[<80446620>] sock_ioctl+0x300/0x35c
[<802317a0>] do_vfs_ioctl+0x764/0x800
[<8023188c>] SyS_ioctl+0x50/0x94
[<80117578>] syscall_common+0x34/0x58
The state D means uninterruptible sleep. Does it stay that way?
Maybe you can write a monitoring script to fix this.
Nope, it never exits that state and stays in that syscall until rebooted. The process can not be SIGKILLed.
I switched off Mudi to check if it’s WDS that triggers the bug.
Nope, without WDS client dnsmasq is blocked again. Attaching dmesg output with errors in case someone is interested. I probably will try to reflash the router…
dmesg.txt.zip (5.3 KB)
Have you modified any configuration of sf1200 after the factory configuration?
What do you mean by configuration? I set it up using it’s web GUI to enable both 2.4g and 5g networks and other network options. I configured VPN client in it but didn’t use it for half a year. It worked quite fine for 4 months and then I added E750 as a WDS client and this started to happen.
I didn’t modify it’s firmware, didn’t install any additional software. I enabled luci interface attempting to add a cron task that reboots it at night but it hangs at day time after reboots anyway.
It just hanged again, I checked if there other processes in ‘D’ state besides dnsmasq and turned out there are.
It’s weird to see brctl showmacs br-guest being stuck in the same syscall because guest networks are disabled on the router UI! I tried to run it in the shell and it blocked my shell forever too. I’ll reflash it tonight.
 1743 dnsmasq   2936 D    /usr/sbin/dnsmasq -C /var/etc/dnsmasq.conf.cfg01411c -k -x /var/run/dnsmasq/dnsmasq.cfg01411c.pid
 3592 root      5116 D    /usr/sbin/hostapd -s -P /var/run/wifi-phy0.pid -B /var/run/hostapd-phy0.conf
 4557 root      5240 D    /usr/sbin/hostapd -s -P /var/run/wifi-phy1.pid -B /var/run/hostapd-phy1.conf
27152 root      1580 D    ip -4 route list table main
27212 root       896 D    brctl showmacs br-guest
root@GL-SF1200:/# cat /proc/1743/stack
[<873e1854>] cfg80211_ch_switch_notify+0x3d0/0x4470 [cfg80211]
[<801eaad0>] kmalloc_order+0x20/0x54
[<80452038>] __kmalloc_reserve.isra.8+0x40/0xa4
root@GL-SF1200:/# cat /proc/4557/stack
[<804ae388>] genl_lock_dumpit+0x30/0x6c
[<804aacb8>] netlink_dump+0x124/0x2d0
[<804ab034>] netlink_recvmsg+0x1d0/0x364
[<80446bb8>] ___sys_recvmsg+0xc0/0x178
[<80447c7c>] __sys_recvmsg+0x50/0x80
root@GL-SF1200:/# cat /proc/27152/stack
[<804aabb8>] netlink_dump+0x24/0x2d0
[<804ab4b0>] __netlink_dump_start+0x130/0x28c
[<80482498>] rtnetlink_rcv_msg+0x1d0/0x394
[<804adfec>] netlink_rcv_skb+0xd4/0x178
[<804ad49c>] netlink_unicast+0x1b4/0x2e8
[<804adb50>] netlink_sendmsg+0x43c/0x498
[<8044763c>] SyS_sendto+0xd4/0x128
root@GL-SF1200:/# cat /proc/27212/stack
[<8048cf34>] dev_ioctl+0x504/0x630
Resetting the router didn’t help.
I didn’t set any options except LAN IP range, static DHCP assignments and wifi security/passwords.
Here is the dmesg log
[83286.315218] siwifi_calculate_legrate invalid legrate: 4
[83286.337347] siwifi_calculate_legrate invalid legrate: 4
[83286.360751] siwifi_calculate_legrate invalid legrate: 4
[83286.383752] siwifi_calculate_legrate invalid legrate: 4
[83292.774956] [0]Total force ps drop len : 1
[83343.402041] [1]Total force ps drop len : 7
[83351.716692] [0]Total force ps drop len : 1
[83382.424378] [1]Total force ps drop len : 7
[83392.791207] [0]Total force ps drop len : 1
[83406.109724] [1]Total force ps drop len : 1
[83429.566646] [1]Total force ps drop len : 7
[83459.852887] [0]Total force ps drop len : 1
[83472.274519] [1]Total force ps drop len : 7
[83492.808157] [0]Total force ps drop len : 1
[83512.492623] [1]Total force ps drop len : 7
[83525.913001] siwifi_calculate_legrate invalid legrate: 4
[83525.925009] siwifi_calculate_legrate invalid legrate: 4
[83525.949882] siwifi_calculate_legrate invalid legrate: 4
[83525.990258] siwifi_calculate_legrate invalid legrate: 4
[83526.029687] siwifi_calculate_legrate invalid legrate: 4
[83526.052435] siwifi_calculate_legrate invalid legrate: 4
[83526.075567] siwifi_calculate_legrate invalid legrate: 4
[83526.126618] siwifi_calculate_legrate invalid legrate: 4
[83526.149518] siwifi_calculate_legrate invalid legrate: 4
[83526.172312] siwifi_calculate_legrate invalid legrate: 4
[83526.196146] siwifi_calculate_legrate invalid legrate: 4
[83532.817995] [0]Total force ps drop len : 1
[83535.302121] siwifi_calculate_legrate invalid legrate: 4
[83535.384561] siwifi_calculate_legrate invalid legrate: 4
[83535.407858] siwifi_calculate_legrate invalid legrate: 4
[83535.445887] siwifi_calculate_legrate invalid legrate: 4
[83535.485066] siwifi_calculate_legrate invalid legrate: 4
[83535.507659] siwifi_calculate_legrate invalid legrate: 4
[83535.530693] siwifi_calculate_legrate invalid legrate: 4
[83535.545977] siwifi_calculate_legrate invalid legrate: 4
[83535.567669] siwifi_calculate_legrate invalid legrate: 4
[83535.590785] siwifi_calculate_legrate invalid legrate: 4
[83535.614194] siwifi_calculate_legrate invalid legrate: 4
[83535.636071] siwifi_calculate_legrate invalid legrate: 4
[83535.659048] siwifi_calculate_legrate invalid legrate: 4
[83535.682074] siwifi_calculate_legrate invalid legrate: 4
[83535.704043] siwifi_calculate_legrate invalid legrate: 4
[83535.726649] siwifi_calculate_legrate invalid legrate: 4
[83535.792298] siwifi_calculate_legrate invalid legrate: 4
[83535.965295] siwifi_calculate_legrate invalid legrate: 4
[83535.988557] siwifi_calculate_legrate invalid legrate: 4
[83536.100847] siwifi_calculate_legrate invalid legrate: 4
[83536.124987] siwifi_calculate_legrate invalid legrate: 4
[83536.147517] siwifi_calculate_legrate invalid legrate: 4
[83536.170515] siwifi_calculate_legrate invalid legrate: 4
[83536.193305] siwifi_calculate_legrate invalid legrate: 4
[83536.217924] siwifi_calculate_legrate invalid legrate: 4
[83536.241284] siwifi_calculate_legrate invalid legrate: 4
[83554.368701] wait cmd timeout, tout : 6000(ms), defer_push : 0!
[83554.374661] tkn[1409258]  flags:0008  result: -4  cmd: 119-unknown                  - reqcfm(   0-MM_RESET_REQ)
[83554.385095] tkn[1409258]  flags:0008  result: -4  cmd: 119-unknown                  - reqcfm(   0-MM_RESET_REQ)
[83554.395635] tkn[1409259]  flags:001f  result:  0  cmd:5132-ME_TRAFFIC_IND_REQ       - reqcfm(5133-ME_TRAFFIC_IND_CFM)
[83554.406747] tkn[1409260]  flags:001e  result: -4  cmd:  63-MM_BCN_CHANGE_REQ        - reqcfm(  64-MM_BCN_CHANGE_CFM)
[83554.417656] tkn[1409261]  flags:001f  result:  0  cmd:5132-ME_TRAFFIC_IND_REQ       - reqcfm(5133-ME_TRAFFIC_IND_CFM)
[83554.428456] [lb]gic mask : 0x5, pending : 0x8
[83554.432933] ipc_env->reg_base : b1000000
[83554.437098] a2e status : 0x202, raw staus : 0x202, mask : 0x1f03, trigger(e2a) : 0x0
[83554.445245] [by API]e2a status : 0x0, raw staus : 0x0, mask : 0xfff, trigger(a2e) : 0x202
[83554.453792] siwifi_hw->dbgdump_elem.err_cur_idx 0,0,848ab500,54,1
[83554.460362] set max idx to LMAC failed!
[83555.408978] [1]Total force ps drop len : 1
[83557.447723] [1]Total force ps drop len : 7
[83558.208082] cmd queue[0] crashed
[83558.211422] siwifi_hw->dbgdump_elem.err_cur_idx 1,1,85f96e80,-20,1
[83569.088042] wait cmd timeout, tout : 18000(ms), defer_push : 1!
[83569.094104] tkn[1409260]  flags:001e  result: -4  cmd:  63-MM_BCN_CHANGE_REQ        - reqcfm(  64-MM_BCN_CHANGE_CFM)
[83569.104854] tkn[1409259]  flags:001f  result:  0  cmd:5132-ME_TRAFFIC_IND_REQ       - reqcfm(5133-ME_TRAFFIC_IND_CFM)
[83569.115570] tkn[1409260]  flags:001e  result: -4  cmd:  63-MM_BCN_CHANGE_REQ        - reqcfm(  64-MM_BCN_CHANGE_CFM)
[83569.126293] tkn[1409261]  flags:001f  result:  0  cmd:5132-ME_TRAFFIC_IND_REQ       - reqcfm(5133-ME_TRAFFIC_IND_CFM)
[83569.136992] [lb]gic mask : 0x5, pending : 0x8
[83569.141530] ipc_env->reg_base : b1000000
[83569.145530] a2e status : 0x202, raw staus : 0x202, mask : 0x1f03, trigger(e2a) : 0x0
[83569.153371] [by API]e2a status : 0x0, raw staus : 0x0, mask : 0xfff, trigger(a2e) : 0x202
[83569.161771] siwifi_hw->dbgdump_elem.err_cur_idx 2,2,86db4100,20,1
[83569.169148] cmd queue[0] crashed
[83569.172561] siwifi_hw->dbgdump_elem.err_cur_idx 3,3,85f96980,-20,1
[83569.180819] cmd queue[0] crashed
[83569.184295] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[83569.191930] cmd queue[0] crashed
[83569.198185] cmd queue[0] crashed
[83569.201518] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[83569.219352] cmd queue[0] crashed
[83569.229368] cmd queue[0] crashed
[83569.233665] cmd queue[0] crashed
[83569.237083] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[83569.253740] cmd queue[0] crashed
[83569.257196] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[83569.282544] cmd queue[0] crashed
[83569.286450] cmd queue[0] crashed
[83569.289958] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[83569.304014] cmd queue[0] crashed
[83569.307330] siwifi_hw->dbgdump_elem.err_cur_idx 4,4,85f96280,0,10
[83569.313717] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[83570.354058] cmd queue[0] crashed
[83570.357598] cmd queue[0] crashed
[83570.361007] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[83570.372011] cmd queue[0] crashed
[83570.375291] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[83571.415985] cmd queue[0] crashed
[83571.419878] cmd queue[0] crashed
[83571.423139] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[83571.434016] cmd queue[0] crashed
[83571.437301] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[83571.453977] cmd queue[0] crashed
[83571.457684] cmd queue[0] crashed
[83571.461069] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[83571.472077] cmd queue[0] crashed
[83571.475482] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[83571.491523] cmd queue[0] crashed
[83571.494805] siwifi_hw->dbgdump_elem.err_cur_idx 5,5,8480a400,0,10
[83571.501517] cmd queue[0] crashed
[83571.504790] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[83571.515547] cmd queue[0] crashed
[83571.518934] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[83571.538471] cmd queue[0] crashed
[83572.560522] cmd queue[0] crashed
[83572.564073] cmd queue[0] crashed
[83572.567313] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[83572.579838] cmd queue[0] crashed
[83572.583120] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[83572.599520] cmd queue[0] crashed
[83572.603079] cmd queue[0] crashed
[83572.606320] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[83572.617213] cmd queue[0] crashed
[83572.620714] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[83572.636549] cmd queue[0] crashed
[83572.639948] siwifi_hw->dbgdump_elem.err_cur_idx 6,6,85740c00,0,10
[83572.646529] cmd queue[0] crashed
[83572.650002] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[83572.661319] cmd queue[0] crashed
[83572.664600] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[83572.681432] cmd queue[0] crashed
[83572.685125] cmd queue[0] crashed
[83572.688679] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[83572.699902] cmd queue[0] crashed
[83572.703183] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[83572.719382] cmd queue[0] crashed
[83572.723296] cmd queue[0] crashed
[83572.726562] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[83572.737638] cmd queue[0] crashed
[83572.741057] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[83572.757324] cmd queue[0] crashed
[83572.761218] cmd queue[0] crashed
[83572.764486] siwifi_hw->dbgdump_elem.err_cur_idx 7,7,85ea3d00,0,10
[83572.770860] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[83572.782420] cmd queue[0] crashed
[83572.785718] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[83572.801949] cmd queue[0] crashed
[83572.805494] cmd queue[0] crashed
[83572.809087] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[83572.820097] cmd queue[0] crashed
[83572.823385] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[83572.839476] cmd queue[0] crashed
[83572.843168] cmd queue[0] crashed
[83572.846423] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[83572.857741] cmd queue[0] crashed
[83572.861177] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[83572.877480] cmd queue[0] crashed
[83572.881439] cmd queue[0] crashed
[83572.884919] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[83572.896080] cmd queue[0] crashed
[83572.899503] siwifi_hw->dbgdump_elem.err_cur_idx 8,8,85740400,0,10
[83572.905634] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[83572.965149] cmd queue[0] crashed
[83572.969023] cmd queue[0] crashed
[83572.972300] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[83572.983531] cmd queue[0] crashed
[83572.987034] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[83573.567983] cmd queue[0] crashed
[83573.571359] lmac_dump_registers band=0
[83573.575119] umac task_dump_registers-baseaddr=0x81ffd000 backtrace=0x81ffcc00 gpr=0x81ffce00 cpu=0x81ffcf00
[83573.585022]
[83573.585022] $ 0:	ffffffff	ffffffff	ffffffff	ffffffff
[83573.585022] $ 4:	ffffffff	ffffffff	ffffffff	ffffffff
[83573.585022] $ 8:	ffffffff	ffffffff	ffffffff	ffffffff
[83573.585022] $12:	ffffffff	ffffffff	ffffffff	ffffffff
[83573.585022] $16:	ffffffff	ffffffff	ffffffff	ffffffff
[83573.585022] $20:	ffffffff	ffffffff	ffffffff	ffffffff
[83573.585022] $24:	ffffffff	ffffffff
[83573.585022] $28:	ffffffff	ffffffff	ffffffff	ffffffff
[83573.585185] epc: ffffffff
[83573.628438] ra: ffffffff
[83573.630977] Status: ffffffff
[83573.633903] Cause: ffffffff
[83573.636728] BadVA: ffffffff
[83573.639670] Prid: ffffffff
[83573.642443] Call Trace:
[83573.644897] [<0xffffffff>] <-
[83573.647934] [<0xffffffff>] <-
[83573.651013] [<0xffffffff>] <-
[83573.654023] [<0xffffffff>] <-
[83573.657028] [<0xffffffff>] <-
[83573.660173] [<0xffffffff>] <-
[83573.663215] [<0xffffffff>] <-
[83573.666186] [<0xffffffff>] <-
[83573.669254] [<0xffffffff>] <-
[83573.672294] [<0xffffffff>] <-
[83573.675262] [<0xffffffff>] <-
[83573.678308] [<0xffffffff>] <-
[83573.681278] [<0xffffffff>] <-
[83573.684241] [<0xffffffff>] <-
[83573.687205] [<0xffffffff>] <-
[83573.690246] [<0xffffffff>] <-
[83573.693217] [<0xffffffff>] <-
[83573.696186] [<0xffffffff>] <-
[83573.699415] [<0xffffffff>] <-
[83573.702398] [<0xffffffff>] <-
[83573.705367] [<0xffffffff>] <-
[83573.708461] [<0xffffffff>] <-
[83573.711538] [<0xffffffff>] <-
[83573.714582] [<0xffffffff>] <-
[83573.717582] [<0xffffffff>] <-
[83573.720675] [<0xffffffff>] <-
[83573.723712] [<0xffffffff>] <-
[83573.726681] [<0xffffffff>] <-
[83573.729744] [<0xffffffff>] <-
[83573.732783] [<0xffffffff>] <-
[83573.735752] [<0xffffffff>] <-
[83573.738796] [<0xffffffff>] <-
[83573.741767] [<0xffffffff>] <-
[83573.744731] [<0xffffffff>] <-
[83573.747774] [<0xffffffff>] <-
[83573.750965] [<0xffffffff>] <-
[83573.753945] [<0xffffffff>] <-
[83573.756941] [<0xffffffff>] <-
[83573.759987] [<0xffffffff>] <-
[83573.762959] [<0xffffffff>] <-
[83573.765923] [<0xffffffff>] <-
[83573.768955] [<0xffffffff>] <-
[83573.772011] [<0xffffffff>] <-
[83573.774980] [<0xffffffff>] <-
[83573.778032] [<0xffffffff>] <-
[83573.781070] [<0xffffffff>] <-
[83573.784088] [<0xffffffff>] <-
[83573.787056] [<0xffffffff>] <-
[83573.790193] [<0xffffffff>] <-
[83573.793171] [<0xffffffff>] <-
[83573.796136] [<0xffffffff>] <-
[83573.799218] [<0xffffffff>] <-
[83573.802206] [<0xffffffff>] <-
[83573.805169] [<0xffffffff>] <-
[83573.808261] [<0xffffffff>] <-
[83573.811364] [<0xffffffff>] <-
[83573.814348] [<0xffffffff>] <-
[83573.817314] [<0xffffffff>] <-
[83573.820377] [<0xffffffff>] <-
[83573.823358] [<0xffffffff>] <-
[83573.826324] [<0xffffffff>] <-
[83573.829373] [<0xffffffff>] <-
[83573.832355] [<0xffffffff>] <-
[83573.835322] [<0xffffffff>] <-
[83573.838347] [<0xffffffff>] <-
[83573.841324] [<0xffffffff>] <-
[83573.844290] [<0xffffffff>] <-
[83573.847256] [<0xffffffff>] <-
[83573.850342] [<0xffffffff>] <-
[83573.853326] [<0xffffffff>] <-
[83573.856290] [<0xffffffff>] <-
[83573.859335] [<0xffffffff>] <-
[83573.862314] [<0xffffffff>] <-
[83573.865278] [<0xffffffff>] <-
[83573.868308] [<0xffffffff>] <-
[83573.871296] [<0xffffffff>] <-
[83573.874265] [<0xffffffff>] <-
[83573.877231] [<0xffffffff>] <-
[83573.880315] [<0xffffffff>] <-
[83573.883306] [<0xffffffff>] <-
[83573.886271] [<0xffffffff>] <-
[83573.889319] [<0xffffffff>] <-
[83573.892300] [<0xffffffff>] <-
[83573.895264] [<0xffffffff>] <-
[83573.898293] [<0xffffffff>] <-
[83573.901284] [<0xffffffff>] <-
[83573.904254] [<0xffffffff>] <-
[83573.907218] [<0xffffffff>] <-
[83573.910344] [<0xffffffff>] <-
[83573.913336] [<0xffffffff>] <-
[83573.916300] [<0xffffffff>] <-
[83573.919347] [<0xffffffff>] <-
[83573.922326] [<0xffffffff>] <-
[83573.925291] [<0xffffffff>] <-
[83573.928323] [<0xffffffff>] <-
[83573.931302] [<0xffffffff>] <-
[83573.934268] [<0xffffffff>] <-
[83573.937232] [<0xffffffff>] <-
[83573.940274] [<0xffffffff>] <-
[83573.943252] [<0xffffffff>] <-
[83573.946218] [<0xffffffff>] <-
[83573.949256] [<0xffffffff>] <-
[83573.952244] [<0xffffffff>] <-
[83573.955209] [<0xffffffff>] <-
[83573.958235] [<0xffffffff>] <-
[83573.961211] [<0xffffffff>] <-
[83573.964176] [<0xffffffff>] <-
[83573.967140] [<0xffffffff>] <-
[83573.970201] [<0xffffffff>] <-
[83573.973184] [<0xffffffff>] <-
[83573.976148] [<0xffffffff>] <-
[83573.979192] [<0xffffffff>] <-
[83573.982171] [<0xffffffff>] <-
[83573.985135] [<0xffffffff>] <-
[83573.988163] [<0xffffffff>] <-
[83573.991147] [<0xffffffff>] <-
[83573.994111] [<0xffffffff>] <-
[83573.997075] [<0xffffffff>] <-
[83574.000114] [<0xffffffff>] <-
[83574.003104] [<0xffffffff>] <-
[83574.006075] [<0xffffffff>] <-
[83574.009178] [<0xffffffff>] <-
[83574.012264] [<0xffffffff>] <-
[83574.015337] [<0xffffffff>] <-
[83574.018518] [<0xffffffff>] <-
[83574.021660] [<0xffffffff>] <-
[83574.024777] [<0xffffffff>] <-
[83574.027969] [<0xffffffff>] <-
[83574.031086] [<0xffffffff>] <-
[83574.034136] [<0xffffffff>] <-
[83574.035127] cmd queue[0] crashed
[83574.037209] [<0xffffffff>] <-
[83574.042882] cmd queue[0] crashed
[83574.043563] [<0xffffffff>] <-
[83574.043569] [<0xffffffff>] <-
[83574.043573] [<0xffffffff>] <-
[83574.043577] [<0xffffffff>] <-
[83574.043581] [<0xffffffff>] <-
[83574.043585] [<0xffffffff>] <-
[83574.043589] [<0xffffffff>] <-
[83574.043592] [<0xffffffff>] <-
[83574.043596] [<0xffffffff>] <-
[83574.043600] [<0xffffffff>] <-
[83574.043604] [<0xffffffff>] <-
[83574.043608] [<0xffffffff>] <-
[83574.043612] [<0xffffffff>] <-
[83574.043616] [<0xffffffff>] <-
[83574.043640] [<0xffffffff>] <-
[83574.046897] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[83574.054330] cmd queue[0] crashed
[83574.056125] [<0xffffffff>] <-
[83574.059218] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[83574.062186] [<0xffffffff>] <-
[83574.075113] cmd queue[0] crashed
[83574.077077] [<0xffffffff>] <-
[83574.077082] [<0xffffffff>] <-
[83574.077086] [<0xffffffff>] <-
[83574.077089] [<0xffffffff>] <-
[83574.077094] [<0xffffffff>] <-
[83574.077098] [<0xffffffff>] <-
[83574.077101] [<0xffffffff>] <-
[83574.077105] [<0xffffffff>] <-
[83574.077109] [<0xffffffff>] <-
[83574.077113] [<0xffffffff>] <-
[83574.077139] [<0xffffffff>] <-
[83574.081421] cmd queue[0] crashed
[83574.083194] [<0xffffffff>] <-
[83574.083199] [<0xffffffff>] <-
[83574.083203] [<0xffffffff>] <-
[83574.083207] [<0xffffffff>] <-
[83574.083211] [<0xffffffff>] <-
[83574.083215] [<0xffffffff>] <-
[83574.083219] [<0xffffffff>] <-
[83574.083222] [<0xffffffff>] <-
[83574.083226] [<0xffffffff>] <-
[83574.083231] [<0xffffffff>] <-
[83574.083252] [<0xffffffff>] <-
[83574.086286] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[83574.089273] [<0xffffffff>] <-
[83574.089293] [<0xffffffff>] <-
[83574.096891] cmd queue[0] crashed
[83574.098374] [<0xffffffff>] <-
[83574.101625] siwifi_hw->dbgdump_elem.err_cur_idx 9,9,85740f00,0,10
[83574.104564] [<0xffffffff>] <-
[83574.110842] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[83574.113607] [<0xffffffff>] <-
[83574.113615] [<0xffffffff>] <-
[83574.113619] [<0xffffffff>] <-
[83574.113623] [<0xffffffff>] <-
[83574.113626] [<0xffffffff>] <-
[83574.113630] [<0xffffffff>] <-
[83574.113634] [<0xffffffff>] <-
[83574.113638] [<0xffffffff>] <-
[83574.113642] [<0xffffffff>] <-
[83574.113646] [<0xffffffff>] <-
[83574.113650] [<0xffffffff>] <-
[83574.113654] [<0xffffffff>] <-
[83574.113657] [<0xffffffff>] <-
[83574.113661] [<0xffffffff>] <-
[83574.113665] [<0xffffffff>] <-
[83574.113669] [<0xffffffff>] <-
[83574.113673] [<0xffffffff>] <-
[83574.113677] [<0xffffffff>] <-
[83574.113681] [<0xffffffff>] <-
[83574.113685] [<0xffffffff>] <-
[83574.113689] [<0xffffffff>] <-
[83574.113693] [<0xffffffff>] <-
[83574.113696] [<0xffffffff>] <-
[83574.113700] [<0xffffffff>] <-
[83574.113704] [<0xffffffff>] <-
[83574.113708] [<0xffffffff>] <-
[83574.113712] [<0xffffffff>] <-
[83574.113716] [<0xffffffff>] <-
[83574.113720] [<0xffffffff>] <-
[83574.113723] [<0xffffffff>] <-
[83574.113727] [<0xffffffff>] <-
[83574.113731] [<0xffffffff>] <-
[83574.113735] [<0xffffffff>] <-
[83574.113739] [<0xffffffff>] <-
[83574.113743] [<0xffffffff>] <-
[83574.113747] [<0xffffffff>] <-
[83574.113751] [<0xffffffff>] <-
[83574.113754] [<0xffffffff>] <-
[83574.113759] [<0xffffffff>] <-
[83574.113763] [<0xffffffff>] <-
[83574.113766] [<0xffffffff>] <-
[83574.113770] [<0xffffffff>] <-
[83574.113774] [<0xffffffff>] <-
[83574.113778] [<0xffffffff>] <-
[83574.113782] [<0xffffffff>] <-
[83574.113813] [<0xffffffff>] <-
[83574.207085] cmd queue[0] crashed
[83574.211017] [<0xffffffff>] <-
[83574.215017] cmd queue[0] crashed
[83574.220084] [<0xffffffff>] <-
[83574.220090] [<0xffffffff>] <-
[83574.220116] [<0xffffffff>] <-
[83574.223285] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[83574.226046] [<0xffffffff>] <-
[83574.226064] [<0xffffffff>] <-
[83574.233850] cmd queue[0] crashed
[83574.235056] [<0xffffffff>] <-
[83574.238201] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[83574.241078] [<0xffffffff>] <-
[83574.254005] cmd queue[0] crashed
[83574.256116] [<0xffffffff>] <-
[83574.259718] cmd queue[0] crashed
[83574.262157] [<0xffffffff>] <-
[83574.265128] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[83574.268155] [<0xffffffff>] <-
[83574.268170] [<0xffffffff>] <-
[83574.277096] cmd queue[0] crashed
[83574.277221] [<0xffffffff>] <-
[83574.280353] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[83574.283370] [<0xffffffff>] <-
[83574.298735] cmd queue[0] crashed
[83574.299077] cmd queue[0] crashed
[83574.301735] [<0xffffffff>] <-
[83574.304697] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[83574.307653] [<0xffffffff>] <-
[83574.315801] cmd queue[0] crashed
[83574.316644] [<0xffffffff>] <-
[83574.319964] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[83574.322711] [<0xffffffff>] <-
[83574.335783] cmd queue[0] crashed
[83574.337691] [<0xffffffff>] <-
[83574.340732] siwifi_hw->dbgdump_elem.err_cur_idx 10,10,85ea3800,0,10
[83574.341315] cmd queue[0] crashed
[83574.343741] [<0xffffffff>] <-
[83574.346711] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[83574.349744] [<0xffffffff>] <-
[83574.349763] [<0xffffffff>] <-
[83574.357336] cmd queue[0] crashed
[83574.358762] [<0xffffffff>] <-
[83574.362015] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[83574.364950] [<0xffffffff>] <-
[83574.378728] cmd queue[0] crashed
[83574.383273] [<0xffffffff>] <-
[83574.386930] cmd queue[0] crashed
[83574.389181] [<0xffffffff>] <-
[83574.392429] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[83574.395370] [<0xffffffff>] <-
[83574.406070] cmd queue[0] crashed
[83574.407633] [<0xffffffff>] <-
[83574.410707] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[83574.413911] [<0xffffffff>] <-
[83574.413916] [<0xffffffff>] <-
[83574.413919] [<0xffffffff>] <-
[83574.413923] [<0xffffffff>] <-
[83574.413927] [<0xffffffff>] <-
[83574.413931] [<0xffffffff>] <-
[83574.413935] [<0xffffffff>] <-
[83574.413939] [<0xffffffff>] <-
[83574.413943] [<0x3c1a8200>] <-
[83574.413947] [<0x275ad000>] <-
[83574.413950] [<0x3c1b2000>] <-
[83574.413954] [<0x35bd025>] <-
[83574.413958] [<0x241b01fc>] <-
[83574.413962] [<0x35bd023>] <-
[83574.413966] [<0xaf40fffc>] <-
[83574.413970] [<0x10000001>] <-
[83574.413990] heart_beat  restart over. count 1
[83574.610986] lb-fmac 11000000.wifi-lb wlan1: restart Del sta 1 (84:f7:03:2d:e8:28)
[83574.618647] remove STA 84:f7:03:2d:e8:28 from hash table success
[83574.624684] lb-fmac 11000000.wifi-lb wlan1: restart Del sta 3 (64:16:66:22:39:4f)
[83574.632315] remove STA 64:16:66:22:39:4f from hash table success
[83574.638442] lb-fmac 11000000.wifi-lb wlan1: restart Del sta 9 (84:f7:03:2d:db:dc)
[83574.645971] remove STA 84:f7:03:2d:db:dc from hash table success
[83574.652062] lb-fmac 11000000.wifi-lb wlan1: restart Del sta 29 (48:7e:48:41:54:4c)
[83574.659914] remove STA 48:7e:48:41:54:4c from hash table success
[83574.665955] lb-fmac 11000000.wifi-lb wlan1: restart Del sta 31 (c4:23:60:cb:69:9d)
[83574.673777] remove STA c4:23:60:cb:69:9d from hash table success
[83574.680207] lmac_glue_stop(0)
[83574.683246] stop_task, 0
[83574.685816] stop aresetn 2 por_resetn 1
[83574.690126] tkn[1409259]  flags:001f  result:  0  cmd:5132-ME_TRAFFIC_IND_REQ       - reqcfm(5133-ME_TRAFFIC_IND_CFM)
[83574.700954] tkn[1409261]  flags:001f  result:  0  cmd:5132-ME_TRAFFIC_IND_REQ       - reqcfm(5133-ME_TRAFFIC_IND_CFM)
[83574.713865] platform shutdown : 0
[83574.721278] tx headroom : 224, tx amsdu headroom : 50, rx headroom : 182, rx pd offset 224
[83574.732931] lmac_glue_start(0)
[83574.736027] start_task, 0
[83574.738882] task entry_addr=0x1f00000
[83574.742554] start aresetn 0 por_resetn 0
[83574.746563] wait lmac init(0)>>>>>>>>>>>>>>>>>>>>>>>
[83602.291219] [1]Total force ps drop len : 1
[83703.479343] [1]Total force ps drop len : 1
[83763.263995] [1]Total force ps drop len : 1
[83798.426895] [1]Total force ps drop len : 7
[83851.959310] [1]Total force ps drop len : 1
[83895.277388] [1]Total force ps drop len : 7
[84004.125709] [1]Total force ps drop len : 1
[84045.273629] [1]Total force ps drop len : 1
[84145.852213] [1]Total force ps drop len : 7
[84150.352905] [1]Total force ps drop len : 1
[84189.435055] [1]Total force ps drop len : 7
[84237.315687] [1]Total force ps drop len : 7
[84282.834246] [1]Total force ps drop len : 7
[84299.242527] [1]Total force ps drop len : 1
[84320.719954] [1]Total force ps drop len : 7
[84363.403597] [1]Total force ps drop len : 7
[84436.345670] [1]Total force ps drop len : 7
[84448.132112] [1]Total force ps drop len : 1
[84488.788042] [1]Total force ps drop len : 7
[84537.747003] [1]Total force ps drop len : 7
[84597.636106] [1]Total force ps drop len : 1
[84628.565168] [1]Total force ps drop len : 7
[84676.500910] [1]Total force ps drop len : 7
[84729.636085] [1]Total force ps drop len : 7
[84746.116027] [1]Total force ps drop len : 1
[84770.158644] [1]Total force ps drop len : 7
[84807.848803] [1]Total force ps drop len : 7
[84855.893414] [1]Total force ps drop len : 7
[84895.620137] [1]Total force ps drop len : 1
[84912.213069] [1]Total force ps drop len : 7
[84971.925392] [1]Total force ps drop len : 7
[85045.124175] [1]Total force ps drop len : 1
[85116.814867] [1]Total force ps drop len : 7
[85194.218514] [1]Total force ps drop len : 1
[85206.797200] [1]Total force ps drop len : 7
[85214.159714] [1]Total force ps drop len : 1
[85307.475929] [1]Total force ps drop len : 7
[85342.698523] [1]Total force ps drop len : 1
[85359.437581] [1]Total force ps drop len : 1
[85391.202974] [1]Total force ps drop len : 7
[85402.076161] [1]Total force ps drop len : 1
[85452.647374] [1]Total force ps drop len : 7
[85492.202545] [1]Total force ps drop len : 1
[85501.933390] [1]Total force ps drop len : 1
[85517.256010] [1]Total force ps drop len : 7
[85542.515278] [1]Total force ps drop len : 1
[85563.276040] [1]Total force ps drop len : 7
[85602.296705] [1]Total force ps drop len : 7
[85625.150282] [1]Total force ps drop len : 1
[85641.707021] [1]Total force ps drop len : 1
[85666.382868] [1]Total force ps drop len : 1
[85690.423305] [1]Total force ps drop len : 7
[85742.280822] [1]Total force ps drop len : 7
[85790.596178] [1]Total force ps drop len : 1
[85800.973568] [1]Total force ps drop len : 1
[85824.239399] [1]Total force ps drop len : 7
[85867.174423] [1]Total force ps drop len : 1
[85915.936616] [1]Total force ps drop len : 7
[85938.871463] [1]Total force ps drop len : 1
[85955.977704] [1]Total force ps drop len : 7
[85989.849623] [1]Total force ps drop len : 1
[86007.440261] [1]Total force ps drop len : 7
[86044.755811] [1]Total force ps drop len : 1
[86061.013198] [1]Total force ps drop len : 7
[86079.659457] [1]Total force ps drop len : 1
[86088.170607] [1]Total force ps drop len : 1
[86103.205002] [1]Total force ps drop len : 7
[86116.345891] [1]Total force ps drop len : 1
[86142.155050] [1]Total force ps drop len : 7
[86236.036171] [1]Total force ps drop len : 1
[86281.095019] [1]Total force ps drop len : 3
[86374.572757] [1]Total force ps drop len : 7
[86379.258471] [1]Total force ps drop len : 3
[86384.106641] [1]Total force ps drop len : 1
[86429.357712] [1]Total force ps drop len : 3
[86441.664379] [1]Total force ps drop len : 7
[86467.008322] [1]Total force ps drop len : 3
[86532.996048] [1]Total force ps drop len : 1
[86682.500137] [1]Total force ps drop len : 1
[86831.184919] [1]Total force ps drop len : 1
[86885.030408] [1]Total force ps drop len : 1
[86919.232027] [1]Total force ps drop len : 1
[86980.688895] [1]Total force ps drop len : 1
[87128.554532] [1]Total force ps drop len : 1
[87276.624903] [1]Total force ps drop len : 1
[87458.060814] [1]Total force ps drop len : 1
[87574.199311] [1]Total force ps drop len : 1
[87723.703305] [1]Total force ps drop len : 1
[87873.207879] [1]Total force ps drop len : 1
[88024.145135] [1]Total force ps drop len : 1
[88169.962691] [1]Total force ps drop len : 1
[88321.515536] [1]Total force ps drop len : 1
[88468.970505] [1]Total force ps drop len : 1
[88617.450668] [1]Total force ps drop len : 1
[88766.954500] [1]Total force ps drop len : 1
[88914.557960] [1]Total force ps drop len : 1
[88953.575779] [1]Total force ps drop len : 1
[89064.324184] [1]Total force ps drop len : 1
[89213.828095] [1]Total force ps drop len : 1
[89363.332105] [1]Total force ps drop len : 1
[89512.836114] [1]Total force ps drop len : 1
[89661.520939] [1]Total force ps drop len : 1
[89810.615347] [1]Total force ps drop len : 1
[89960.120442] [1]Total force ps drop len : 1
[90109.623724] [1]Total force ps drop len : 1
[90220.455970] [1]Total force ps drop len : 3
[90257.693807] [1]Total force ps drop len : 1
[90405.968922] [1]Total force ps drop len : 1
[90554.449005] [1]Total force ps drop len : 1
[90559.599306] [1]Total force ps drop len : 3
[90612.800070] [1]Total force ps drop len : 1
[90700.688325] [1]Total force ps drop len : 3
[90702.928939] [1]Total force ps drop len : 1
[90736.462311] [1]Total force ps drop len : 3
[90850.795379] [1]Total force ps drop len : 1
[90949.491319] [1]Total force ps drop len : 1
[90998.660129] [1]Total force ps drop len : 1
[91161.254405] [1]Total force ps drop len : 1
[91296.439303] [1]Total force ps drop len : 1
[91445.124584] [1]Total force ps drop len : 1
[91594.628106] [1]Total force ps drop len : 1
[91744.132527] [1]Total force ps drop len : 1
[91891.998223] [1]Total force ps drop len : 1
[92046.604810] [1]Total force ps drop len : 1
[92190.596393] [1]Total force ps drop len : 1
[92287.244998] [1]Total force ps drop len : 1
[92338.462290] [1]Total force ps drop len : 1
[92490.013930] [1]Total force ps drop len : 1
[92635.569130] [1]Total force ps drop len : 1
[92785.540489] [1]Total force ps drop len : 1
[92875.430474] [1]Total force ps drop len : 1
[92934.839219] [1]Total force ps drop len : 1
[93083.934338] [1]Total force ps drop len : 1
[93263.526399] [1]Total force ps drop len : 1
[93380.279313] [1]Total force ps drop len : 1
[93529.783305] [1]Total force ps drop len : 1
[93679.287443] [1]Total force ps drop len : 1
[93828.586506] [1]Total force ps drop len : 1
[93877.516911] [1]Total force ps drop len : 1
[93914.176260] [1]Total force ps drop len : 1
[93977.168945] [1]Total force ps drop len : 1
[94000.664200] [1]Total force ps drop len : 3
[94110.375232] rx pkt(1) disassoc from [90:81:58:a0:9d:e6] reasoncode: 8
[94128.618528] [1]Total force ps drop len : 1
[94275.460683] [1]Total force ps drop len : 1
[94328.281627] [1]Total force ps drop len : 1
[94424.964153] [1]Total force ps drop len : 1
I have several gl-sf1200 and I am seeing a similar issue with ver 3.215.
See below:
[31939.120551] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[31939.127174] cmd queue[1] crashed
[31940.589605] cmd queue[1] crashed
[31940.593221] cmd queue[1] crashed
[31940.596468] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[31940.613283] cmd queue[1] crashed
[31940.616878] cmd queue[1] crashed
[31940.620258] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[31940.636349] cmd queue[1] crashed
[31940.640205] cmd queue[1] crashed
[31940.643464] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[31940.659660] cmd queue[1] crashed
[31940.662938] siwifi_hw->dbgdump_elem.err_cur_idx 5,5,85e3b200,0,10
[31940.669656] cmd queue[1] crashed
[31940.672921] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[31940.689041] cmd queue[1] crashed
[31940.692800] cmd queue[1] crashed
[31940.696047] siwifi_send_dbg_get_vendor_mp_info_req send msg fail
[31944.038893] cmd queue[1] crashed
[31944.042170] lmac_dump_registers band=1
[31944.045924] umac task_dump_registers-baseaddr=0x820fd000 backtrace=0x820fcc00 gpr=0x820fce00 cpu=0x820fcf00
[31944.055758]
[31944.055758] $ 0: ffffffff ffffffff ffffffff ffffffff
[31944.055758] $ 4: ffffffff ffffffff ffffffff ffffffff
[31944.055758] $ 8: ffffffff ffffffff ffffffff ffffffff
[31944.055758] $12: ffffffff ffffffff ffffffff ffffffff
[31944.055758] $16: ffffffff ffffffff ffffffff ffffffff
[31944.055758] $20: ffffffff ffffffff ffffffff ffffffff
[31944.055758] $24: ffffffff ffffffff
[31944.055758] $28: ffffffff ffffffff ffffffff ffffffff
[31944.055959] epc: ffffffff
[31944.098986] ra: ffffffff
[31944.101520] Status: ffffffff
[31944.104397] Cause: ffffffff
[31944.107186] BadVA: ffffffff
[31944.110036] Prid: ffffffff
[31944.112756] Call Trace:
[31944.115205] [<0xffffffff>] ←
[31944.118167] [<0xffffffff>] ←
[31944.121211] [<0xffffffff>] ←
[31944.124194] [<0xffffffff>] ←
[31944.127161] [<0xffffffff>] ←
[31944.130200] [<0xffffffff>] ←
[31944.133181] [<0xffffffff>] ←
[31944.136148] [<0xffffffff>] ←
[31944.139189] [<0xffffffff>] ←
[31944.142174] [<0xffffffff>] ←
[31944.145142] [<0xffffffff>] ←
[31944.148104] [<0xffffffff>] ←
[31944.151149] [<0xffffffff>] ←
[31944.154130] [<0xffffffff>] ←
[31944.157097] [<0xffffffff>] ←
[31944.160140] [<0xffffffff>] ←
[31944.163122] [<0xffffffff>] ←
[31944.166089] [<0xffffffff>] ←
[31944.169152] [<0xffffffff>] ←
[31944.172134] [<0xffffffff>] ←
[31944.175102] [<0xffffffff>] ←
[31944.178065] [<0xffffffff>] ←
[31944.181109] [<0xffffffff>] ←
[31944.184091] [<0xffffffff>] ←
[31944.187059] [<0xffffffff>] ←
[31944.190101] [<0xffffffff>] ←
[31944.193083] [<0xffffffff>] ←
[31944.196050] [<0xffffffff>] ←
[31944.199115] [<0xffffffff>] ←
[31944.202111] [<0xffffffff>] ←
[31944.205078] [<0xffffffff>] ←
[31944.208041] [<0xffffffff>] ←
[31944.211098] [<0xffffffff>] ←
[31944.214081] [<0xffffffff>] ←
[31944.217048] [<0xffffffff>] ←
[31944.220099] [<0xffffffff>] ←
[31944.223082] [<0xffffffff>] ←
[31944.226049] [<0xffffffff>] ←
[31944.229092] [<0xffffffff>] ←
[31944.232075] [<0xffffffff>] ←
[31944.235042] [<0xffffffff>] ←
[31944.238005] [<0xffffffff>] ←
[31944.241050] [<0xffffffff>] ←
[31944.244031] [<0xffffffff>] ←
[31944.246998] [<0xffffffff>] ←
[31944.250043] [<0xffffffff>] ←
[31944.253026] [<0xffffffff>] ←
[31944.255993] [<0xffffffff>] ←
[31944.259035] [<0xffffffff>] ←
[31944.262018] [<0xffffffff>] ←
[31944.264985] [<0xffffffff>] ←
[31944.267948] [<0xffffffff>] ←
[31944.270989] [<0xffffffff>] ←
[31944.273972] [<0xffffffff>] ←
[31944.276939] [<0xffffffff>] ←
[31944.279981] [<0xffffffff>] ←
[31944.282963] [<0xffffffff>] ←
[31944.285930] [<0xffffffff>] ←
[31944.288971] [<0xffffffff>] ←
[31944.291952] [<0xffffffff>] ←
[31944.294919] [<0xffffffff>] ←
[31944.297882] [<0xffffffff>] ←
[31944.300953] [<0xffffffff>] ←
[31944.303934] [<0xffffffff>] ←
[31944.306902] [<0xffffffff>] ←
[31944.309950] [<0xffffffff>] ←
[31944.312931] [<0xffffffff>] ←
[31944.315898] [<0xffffffff>] ←
[31944.318939] [<0xffffffff>] ←
[31944.321922] [<0xffffffff>] ←
[31944.324889] [<0xffffffff>] ←
[31944.327852] [<0xffffffff>] ←
[31944.330895] [<0xffffffff>] ←
[31944.333878] [<0xffffffff>] ←
[31944.336845] [<0xffffffff>] ←
[31944.339888] [<0xffffffff>] ←
[31944.342871] [<0xffffffff>] ←
[31944.345837] [<0xffffffff>] ←
[31944.348880] [<0xffffffff>] ←
[31944.351861] [<0xffffffff>] ←
[31944.354829] [<0xffffffff>] ←
[31944.357791] [<0xffffffff>] ←
[31944.360834] [<0xffffffff>] ←
[31944.363815] [<0xffffffff>] ←
[31944.366782] [<0xffffffff>] ←
[31944.369824] [<0xffffffff>] ←
[31944.372806] [<0xffffffff>] ←
[31944.375773] [<0xffffffff>] ←
[31944.378736] [<0xffffffff>] ←
[31944.381779] [<0xffffffff>] ←
[31944.384762] [<0xffffffff>] ←
[31944.387729] [<0xffffffff>] ←
[31944.390771] [<0xffffffff>] ←
[31944.393752] [<0xffffffff>] ←
[31944.396718] [<0xffffffff>] ←
[31944.399774] [<0xffffffff>] ←
[31944.402777] [<0xffffffff>] ←
[31944.405753] [<0xffffffff>] ←
[31944.408716] [<0xffffffff>] ←
[31944.411770] [<0xffffffff>] ←
[31944.414757] [<0xffffffff>] ←
[31944.417724] [<0xffffffff>] ←
[31944.420771] [<0xffffffff>] ←
[31944.423752] [<0xffffffff>] ←
[31944.426719] [<0xffffffff>] ←
[31944.429801] [<0xffffffff>] ←
[31944.432787] [<0xffffffff>] ←
[31944.435753] [<0xffffffff>] ←
[31944.438716] [<0xffffffff>] ←
[31944.441761] [<0xffffffff>] ←
[31944.444744] [<0xffffffff>] ←
[31944.447710] [<0xffffffff>] ←
[31944.450752] [<0xffffffff>] ←
[31944.453732] [<0xffffffff>] ←
[31944.456699] [<0xffffffff>] ←
[31944.459742] [<0xffffffff>] ←
[31944.462733] [<0xffffffff>] ←
[31944.465700] [<0xffffffff>] ←
[31944.468663] [<0xffffffff>] ←
[31944.471702] [<0xffffffff>] ←
[31944.474684] [<0xffffffff>] ←
[31944.477659] [<0xffffffff>] ←
[31944.480732] [<0xffffffff>] ←
[31944.483716] [<0xffffffff>] ←
[31944.486682] [<0xffffffff>] ←
[31944.489726] [<0xffffffff>] ←
[31944.492708] [<0xffffffff>] ←
[31944.495674] [<0xffffffff>] ←
[31944.498637] [<0xffffffff>] ←
[31944.501682] [<0xffffffff>] ←
[31944.504664] [<0xffffffff>] ←
[31944.507630] [<0xffffffff>] ←
[31944.510669] [<0xffffffff>] ←
[31944.513651] [<0xffffffff>] ←
[31944.516618] [<0xffffffff>] ←
[31944.519659] [<0xffffffff>] ←
[31944.522641] [<0xffffffff>] ←
[31944.525608] [<0xffffffff>] ←
[31944.528570] [<0xffffffff>] ←
[31944.531609] [<0xffffffff>] ←
[31944.534591] [<0xffffffff>] ←
[31944.537558] [<0xffffffff>] ←
[31944.540613] [<0xffffffff>] ←
[31944.543598] [<0xffffffff>] ←
[31944.546564] [<0xffffffff>] ←
[31944.549609] [<0xffffffff>] ←
[31944.552590] [<0xffffffff>] ←
[31944.555557] [<0xffffffff>] ←
[31944.558519] [<0xffffffff>] ←
[31944.561588] [<0xffffffff>] ←
[31944.564570] [<0xffffffff>] ←
[31944.567537] [<0xffffffff>] ←
[31944.570577] [<0xffffffff>] ←
[31944.573558] [<0xffffffff>] ←
[31944.576525] [<0xffffffff>] ←
[31944.579561] [<0xffffffff>] ←
[31944.582541] [<0xffffffff>] ←
[31944.585507] [<0xffffffff>] ←
[31944.588470] [<0xffffffff>] ←
[31944.591509] [<0xffffffff>] ←
[31944.594489] [<0xffffffff>] ←
[31944.597456] [<0xffffffff>] ←
[31944.600495] [<0xffffffff>] ←
[31944.603476] [<0xffffffff>] ←
[31944.606442] [<0xffffffff>] ←
[31944.609489] [<0xffffffff>] ←
[31944.612471] [<0xffffffff>] ←
[31944.615438] [<0xffffffff>] ←
[31944.618401] [<0xffffffff>] ←
[31944.621444] [<0xffffffff>] ←
[31944.624427] [<0xffffffff>] ←
[31944.627393] [<0xffffffff>] ←
[31944.630433] [<0xffffffff>] ←
[31944.633415] [<0xffffffff>] ←
[31944.636382] [<0xffffffff>] ←
[31944.639421] [<0xffffffff>] ←
[31944.642403] [<0xffffffff>] ←
[31944.645370] [<0xffffffff>] ←
[31944.648333] [<0xffffffff>] ←
[31944.651370] [<0xffffffff>] ←
[31944.654350] [<0xffffffff>] ←
[31944.657317] [<0xffffffff>] ←
[31944.660356] [<0xffffffff>] ←
[31944.663337] [<0xffffffff>] ←
[31944.666304] [<0xffffffff>] ←
[31944.669341] [<0xffffffff>] ←
[31944.672323] [<0xffffffff>] ←
[31944.675289] [<0xffffffff>] ←
[31944.678252] [<0xffffffff>] ←
[31944.681290] [<0xffffffff>] ←
[31944.684273] [<0xffffffff>] ←
[31944.687239] [<0xffffffff>] ←
[31944.690308] [<0xffffffff>] ←
[31944.693291] [<0xffffffff>] ←
[31944.696258] [<0xffffffff>] ←
[31944.699299] [<0xffffffff>] ←
[31944.702281] [<0xffffffff>] ←
[31944.705247] [<0xffffffff>] ←
[31944.708210] [<0xffffffff>] ←
[31944.711256] [<0xffffffff>] ←
[31944.714239] [<0xffffffff>] ←
[31944.717206] [<0xffffffff>] ←
[31944.720248] [<0xffffffff>] ←
[31944.723229] [<0xffffffff>] ←
[31944.726196] [<0xffffffff>] ←
[31944.729233] [<0xffffffff>] ←
[31944.732215] [<0xffffffff>] ←
[31944.735181] [<0xffffffff>] ←
[31944.738144] [<0xffffffff>] ←
[31944.741198] [<0xffffffff>] ←
[31944.744183] [<0xffffffff>] ←
[31944.747150] [<0xffffffff>] ←
[31944.750191] [<0xffffffff>] ←
[31944.753174] [<0xffffffff>] ←
[31944.756140] [<0xffffffff>] ←
[31944.759196] [<0xffffffff>] ←
[31944.762184] [<0xffffffff>] ←
[31944.765152] [<0xffffffff>] ←
[31944.768115] [<0xffffffff>] ←
[31944.771171] [<0xffffffff>] ←
[31944.774151] [<0xffffffff>] ←
[31944.777118] [<0xffffffff>] ←
[31944.780164] [<0xffffffff>] ←
[31944.783151] [<0xffffffff>] ←
[31944.786120] [<0xffffffff>] ←
[31944.789168] [<0xffffffff>] ←
[31944.792151] [<0xffffffff>] ←
[31944.795117] [<0xffffffff>] ←
[31944.798079] [<0xffffffff>] ←
[31944.801120] [<0xffffffff>] ←
[31944.804100] [<0xffffffff>] ←
[31944.807066] [<0xffffffff>] ←
[31944.810107] [<0xffffffff>] ←
[31944.813088] [<0xffffffff>] ←
[31944.816054] [<0xffffffff>] ←
[31944.819122] [<0xffffffff>] ←
[31944.822105] [<0xffffffff>] ←
[31944.825072] [<0xffffffff>] ←
[31944.828035] [<0xffffffff>] ←
[31944.831089] [<0xffffffff>] ←
[31944.834074] [<0xffffffff>] ←
[31944.837041] [<0xffffffff>] ←
[31944.840131] [<0xffffffff>] ←
[31944.843113] [<0xffffffff>] ←
[31944.846079] [<0xffffffff>] ←
[31944.849131] [<0xffffffff>] ←
[31944.852116] [<0xffffffff>] ←
[31944.855083] [<0xffffffff>] ←
[31944.858046] [<0xffffffff>] ←
[31944.861092] [<0xffffffff>] ←
[31944.864074] [<0xffffffff>] ←
[31944.867041] [<0xffffffff>] ←
[31944.870086] [<0xffffffff>] ←
[31944.873068] [<0xffffffff>] ←
[31944.876034] [<0xffffffff>] ←
[31944.879074] [<0xffffffff>] ←
[31944.882057] [<0x3c1a8210>] ←
[31944.885024] [<0x275ad000>] ←
[31944.887988] [<0x3c1b2000>] ←
[31944.891047] [<0x35bd025>] ←
[31944.893946] [<0x241b01fc>] ←
[31944.896914] [<0x35bd023>] ←
[31944.899873] [<0xaf40fffc>] ←
[31944.902854] [<0x10000001>] ←
[31944.905829] heart_beat restart over. count 1
Greetings,
So in an effort to figure out what is happening I ran the following command:
logread -e dhcp.script
Tue Apr 11 07:13:16 2023 daemon.notice netifd: wwan (2979): /lib/netifd/dhcp.script: line 62: netclash: not found
Tue Apr 11 16:57:12 2023 daemon.notice netifd: wwan (2979): /lib/netifd/dhcp.script: line 62: netclash: not found
Tue Apr 11 22:57:13 2023 daemon.notice netifd: wwan (2979): /lib/netifd/dhcp.script: line 62: netclash: not found
Wed Apr 12 04:57:13 2023 daemon.notice netifd: wwan (2979): /lib/netifd/dhcp.script: line 62: netclash: not found
What is netclash?
Greetings,
So I have discovered more information as to what is causing the units I have to soft crash. The issue is when the wwan does not correctly get a dhcp renewal. I am looking as to why they are not picking up the offer by the dhcp server. But if the renewal fails the soft crash occurs on my setups. Hope this helps others.
Hi Nelson,
Just a thought I’ll throw out: you should be able to set a cronjob to stop/start dnsmasq according to whatever time you like under LuCI → System → Scheduled Tasks. /etc/init.d/dnsmasq {stop, start} accordingly. Here’s my goto generator:
I replaced the router long ago, but as a topic starter would remind that in my case dnsmasq (and some other processes) were in D state, which means defunct, they were not possible to terminate. Attempt to send a signal to a defunct dnsmasq blocked sending process forever. So any workarounds attempting to restart it would fail. The issue were not in dnsmasq itself, it was just the first process which failure I noticed.
Greetings,
So in the end I replaced the units with used aruba ap-105 flashed with latest openwrt and they just worked great. So must be something with the gl unit firmware.
Just to note - exact same issue still happening on this model May 2025 - nice debugging work - did not to effect a fix by GL.iNet to date.
