Goal: Setup offline media server (local only)
Hi people,
I just got this pocket router, logged into web interface to setup and update firmware etc (automatically).
However, I was trying to find SMB or File Sharing options.
After doing some searching online it should be under the "Applications" but it's missing:
Then, I found that a few previous firmware versions prior, they removed it to save space.
My current firmware version is: 4.3.24
I checked this post:
and ran via SSH;
opkg update
opkg install gl-sdk4-webdav gl-sdk4-nas-exfat gl-sdk4-nas-utils gl-sdk4-nas-web gl-sdk4-ui-nasview samba4-server samba4-libs samba4-utils minidlna blkid kmod-fs-ext4 kmod-fs-ntfs kmod-fs-vfat kmod-fs-exfat kmod-usb-storage-uas ntfs-3g ntfs-3g-utils dosfstools e2fsprogs shadow-common shadow-useradd
No errors/warnings.
Rebooted the router.
However, the "File Sharing" option is still missing.
Any suggestions?
