In “repeater mode” constantly loses connection with the AP. I’ve tried different settings, but without the proper result. Doesn’t work, almost. It looks like not enough power of power supply.
Can you try another power adapter?
It seems that the problem is only in the 2.4 GHz band. In 5GHz repeater mode, the router works great!
2.4G is more prone to interference. Let’s keep using 5G.
- “I reside in Tiga and am currently the only resident. Your device is not functioning in 2.4 repeater mode.”
- “The parenting device indicates that it is experiencing significant data loss, but the signal strength is strong at -59.”
It looks like the problem only occurs with MikroTik routers. I have tried different models but the result is the same - in 2.4 GHz it does not work as “Repeater”. SFT1200 constantly loses connection with AP with message"significant data loss."
So you mean when connecting to Mikrotik router as repeater, right? Do you have the model of Mikrotik router?
Yes, when I connect to MikroTik AP in 2.4 repeater mode, it doesn’t work properly. Loses connection constantly. But in repeater 5GHz mode works fine! Tried different models of MikroTik devices. For example, MikroTik hap ac2 and MikroTik hap lite give the same result. Looks like problems in 2.4GHz-N-Band
When I start checking the connection speed with the speedtest, at the begining everything goes well, then all of a sudden it loses the connection and the test fails.
Can you do a test connecting 2.4GHz WWAN to MicroTik and 5GHz WLAN to client device? I get disconnects with 2.4GHz on both WWAN and WLAN.
I do not work for and I do not have formal association with GL.iNet.
GL-SFT1200 Noise level of 0 dBm does not look right. It should be -80 to -110 dBm.
It appears to be a software bug that does not show the actual noise level.
At first I thought everything was ok in 5GHz, but now I see the same problems in 5GHz repeater mode. In this mode, GL-SFT1200 simply does not work. And I do not see any help from Technical support. This router is really raw.
We will get a Mikrotik AP and test.
Here is the log. Maybe this will help find a solution
Sat Dec 31 01:23:37 2022 kern.warn kernel: [ 2514.742641] lmac[0] Error, msdu index reach maximum limit, 31
Sat Dec 31 01:23:37 2022 kern.warn kernel: [ 2514.748634] lmac[0] Error, buffer is not uploaded to host buffer completely
Sat Dec 31 01:23:37 2022 kern.warn kernel: [ 2514.957068] lmac[0] Error, msdu index reach maximum limit, 31
Sat Dec 31 01:23:37 2022 kern.warn kernel: [ 2514.962866] lmac[0] Error, buffer is not uploaded to host buffer completely
Sat Dec 31 01:23:40 2022 user.info mwan3rtmon[2064]: Detect rtchange event.
Sat Dec 31 01:23:41 2022 kern.warn kernel: [ 2518.798064] lmac[0] Error, msdu index reach maximum limit, 31
Sat Dec 31 01:23:41 2022 kern.warn kernel: [ 2518.803986] lmac[0] Error, buffer is not uploaded to host buffer completely
Sat Dec 31 01:23:41 2022 user.notice relay: Reloading relay due to connected of wwan (wlan-sta)
Sat Dec 31 01:23:41 2022 kern.warn kernel: [ 2519.092812] lmac[0] Error, msdu index reach maximum limit, 31
Sat Dec 31 01:23:41 2022 kern.warn kernel: [ 2519.098735] lmac[0] Error, buffer is not uploaded to host buffer completely
Sat Dec 31 01:23:41 2022 kern.warn kernel: [ 2519.124051] lmac[0] Error, msdu index reach maximum limit, 31
Sat Dec 31 01:23:41 2022 kern.warn kernel: [ 2519.129895] lmac[0] Error, buffer is not uploaded to host buffer completely
Sat Dec 31 01:23:41 2022 kern.warn kernel: [ 2519.213390] lmac[0] Error, msdu index reach maximum limit, 31
Sat Dec 31 01:23:41 2022 kern.warn kernel: [ 2519.219241] lmac[0] Error, buffer is not uploaded to host buffer completely
Sat Dec 31 01:23:41 2022 user.notice firewall: Reloading firewall due to ifup of wwan (wlan-sta)
Sat Dec 31 01:23:42 2022 kern.warn kernel: [ 2520.186901] lmac[0] Error, msdu index reach maximum limit, 31
Sat Dec 31 01:23:42 2022 kern.warn kernel: [ 2520.192773] lmac[0] Error, buffer is not uploaded to host buffer completely
Sat Dec 31 01:23:44 2022 user.notice relay: Reloading relay due to ifup of wwan (wlan-sta)
Sat Dec 31 01:23:54 2022 daemon.notice wpa_supplicant[19643]: wlan-sta: CTRL-EVENT-DISCONNECTED bssid=b8:69:f4:30:1e:f7 reason=2
Sat Dec 31 01:23:54 2022 kern.warn kernel: [ 2532.359715] lmac[0] {CTXT-2} unlink from {VIF-0}: status=4 nb_vif=1
Sat Dec 31 01:23:54 2022 kern.warn kernel: [ 2532.359749] lmac[0] {CTXT-2} Delete channel context
Sat Dec 31 01:23:54 2022 kern.info kernel: [ 2532.366467] lb-fmac 11000000.wifi-lb wlan-sta: Del key for vif(0), key index : 0
Sat Dec 31 01:23:54 2022 kern.info kernel: [ 2532.379034] lb-fmac 11000000.wifi-lb wlan-sta: Del key for vif(0), key index : 1
Sat Dec 31 01:23:54 2022 kern.info kernel: [ 2532.386614] lb-fmac 11000000.wifi-lb wlan-sta: Del key for vif(0), key index : 2
Sat Dec 31 01:23:54 2022 kern.info kernel: [ 2532.394466] lb-fmac 11000000.wifi-lb wlan-sta: Del key for vif(0), key index : 3
Sat Dec 31 01:23:54 2022 kern.info kernel: [ 2532.402026] lb-fmac 11000000.wifi-lb wlan-sta: Del key for vif(0), key index : 4
Sat Dec 31 01:23:54 2022 kern.info kernel: [ 2532.409610] lb-fmac 11000000.wifi-lb wlan-sta: Del key for vif(0), key index : 5
Sat Dec 31 01:23:54 2022 daemon.notice netifd: Network device ‘wlan-sta’ link is down
Sat Dec 31 01:23:54 2022 daemon.notice netifd: Interface ‘wwan’ has link connectivity loss
Sat Dec 31 01:23:55 2022 daemon.notice netifd: wwan (9029): udhcpc: received SIGTERM
Sat Dec 31 01:23:55 2022 daemon.notice wpa_supplicant[19643]: wlan-sta: Trying to associate with b8:69:f4:30:1e:f7 (SSID=‘MySweetHome’ freq=2462 MHz)
Sat Dec 31 01:23:55 2022 kern.warn kernel: [ 2532.905147] lmac[0] {CTXT-0} Create channel context: freq=2462MHz bw=20MHz pwr=20dBm
Sat Dec 31 01:23:55 2022 kern.warn kernel: [ 2532.912983] lmac[0] {CTXT-0} link to {VIF-0}: status=0 nb_vif=0
Sat Dec 31 01:23:55 2022 kern.warn kernel: [ 2532.913016] lmac[0] rc_init: station_id=33 format_mod=2 pre_type=0 short_gi=1 max_bw=0
Sat Dec 31 01:23:55 2022 kern.warn kernel: [ 2532.927063] lmac[0] rc_init: nss_max=1 mcs_max=7 r_idx_min=12 r_idx_max=12 no_samples=10
Sat Dec 31 01:23:55 2022 daemon.notice netifd: Network device ‘wlan-sta’ link is up
Sat Dec 31 01:23:55 2022 daemon.notice netifd: Interface ‘wwan’ has link connectivity
Sat Dec 31 01:23:55 2022 daemon.notice netifd: Interface ‘wwan’ is setting up now
Sat Dec 31 01:23:55 2022 daemon.notice wpa_supplicant[19643]: wlan-sta: Associated with b8:69:f4:30:1e:f7
Sat Dec 31 01:23:55 2022 daemon.notice wpa_supplicant[19643]: wlan-sta: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Sat Dec 31 01:23:55 2022 kern.info kernel: [ 2532.946554] lb-fmac 11000000.wifi-lb wlan-sta: Add key for sta 33 (b8:69:f4:30:1e:f7)
Sat Dec 31 01:23:55 2022 daemon.notice wpa_supplicant[19643]: wlan-sta: WPA: Key negotiation completed with b8:69:f4:30:1e:f7 [PTK=CCMP GTK=CCMP]
Sat Dec 31 01:23:55 2022 kern.info kernel: [ 2532.955823] lb-fmac 11000000.wifi-lb wlan-sta: Add key for vif(0), key index : 2
Sat Dec 31 01:23:55 2022 daemon.notice wpa_supplicant[19643]: wlan-sta: CTRL-EVENT-CONNECTED - Connection to b8:69:f4:30:1e:f7 completed [id=0 id_str=]
Sat Dec 31 01:23:55 2022 daemon.notice netifd: wwan (10776): udhcpc: started, v1.29.3
Sat Dec 31 01:23:55 2022 daemon.notice netifd: wwan (10776): udhcpc: sending discover
Sat Dec 31 01:23:55 2022 daemon.notice netifd: wwan (10776): udhcpc: sending select for 192.168.5.74
Sat Dec 31 01:23:56 2022 daemon.notice netifd: wwan (10776): udhcpc: lease of 192.168.5.74 obtained, lease time 600
Sat Dec 31 01:23:56 2022 daemon.warn dnsmasq[2872]: no servers found in /tmp/resolv.conf.auto, will retry
Sat Dec 31 01:23:56 2022 daemon.notice netifd: Interface ‘wwan’ is now up
Looks like problem is here. MSDU - agreation method for service data. This method performed in hardware.
@dxf can you have a check of this log?
What are you asking for? I can’t realize!
