Gl-sft1200
Here you go. Download easytether OpenWrt 19.07.3+ Extract the zip, look for the folder {mvebu} open it, look for the folder {cortexa9} open it, this is the driver that works on all three routers. The Linksys Wrt1900ac, Wrt1900acs & the Wrt3200acm. Regardless of the firmware update on these Linksys Routers, this EasyTether Driver still works great.
What also makes it work better is a 3.0 usb cable from the phone to the router. Make sure you have a decent amount of high-speed data on your plan.
Thank You, Tukufu42!
No problem. I tried to make it as easy as possible for you to understand how to get the correct driver. Now, as for setting it up to work, your on your own. I have it down packed. So far the routers I was able to get EasyTether to work flawlessly on, is, The GL-MT1300 Beryl, GL-750S Slate, WRT1900ac, WRT1900acs, & the WRT3200acm. Just wish the GL-SFT1200 (Opal), & the new GL-AX1800 (Flint) had a EasyTether Driver. Seems like theres no luck at the moment. Let me know if you find the correct easytether driver for these in the future.
Thanks Tukufu42,
I Finally got an WR3200ACM router. I followed the same procedure from GLiNet Docs which worked for my GL-AR300M16. But got the following error message when opkg install the easytether driver to the router:
Unknown package ‘easytether-usb-openssl’.
Collected errors:
  • pkg_hash_check_unresolved: cannot find dependency kmod-tun for easytether-usb-openssl
  • pkg_hash_check_unresolved: cannot find dependency libopenssl1.1 for easytether-usb-openssl
  • pkg_hash_fetch_best_installation_candidate: Packages for easytether-usb-openssl found, but incompatible with the architectures configured
  • opkg_install_cmd: Cannot install package easytether-usb-openssl.
The Oopenwrt-21.02.3 is the one I flashed to the router if that matters.
Really appreciate if you can shed some light on this.
Never mind, it works now. Shouldn’t skip “opkg update”. That was optional for AR300M16.
Thats right. Thats the first thing on the menu…:blush:
Thank you, Tukufu42. Following your step to make my AR750 working. Fw 3.216 and tiny.
But the last part, I’m not sure…apply tethering at wan ?
Its been a while since Ive tinkered with that model. Im gonna tell you another way you can achieve this without all the extra know how. Just sent you a picture of a ethernet to USB C adapter, plug that into your phone get a small internet cable and plug that into the WAN of the router, also get a short usb a cable to keep the device charged while using it. You could do this on any router without even using Easy Tether…:sunglasses:
