Hello GL.iNet Community,
I’m experiencing an issue with my GL-X3000 modem. Despite several attempts to connect to the Cellular network, the modem consistently shows the error: “SIM card not registered”. Here is what I’ve tried so far:
1. Changing IMEI: Following some forum suggestions, I have modified the IMEI number, but this did not resolve the issue.
2. Activating Filter Bands: I attempted to set up filter bands to ensure compatibility with my carrier’s frequencies, but this also didn’t help.
3. Applying Additional Commands**: I applied several commands suggested by other users. As a result:
• The port changed from /dev/QMC to /dev/cdc-wdm0.
• Protocol options such as qmi and 3g appeared in the modem settings.
Despite these changes, the modem still fails to register the SIM card and connect. I even performed a factory reset, but the port and protocol settings remained altered.
I am using a compatible SIM card that works perfectly fine on other devices, so I believe the issue might be specific to the modem or its configuration.
I’ve attached the connection logs and screenshots of my configuration settings for reference. Any guidance or suggestions from the community would be greatly appreciated. If anyone has experienced similar issues or has insights on other settings I might try, please let me know.
full Log URL : Unique Download Link | WeTransfer
