GL-X3000: SIM Card Not Registered Issue
I recently purchased a GL-X3000 from one of GLiNet company’s partners, and I’m facing an issue similar to the one described in this link:
https://forum.gl-inet.com/t/gl-x3000-sim-card-not-registered-issue-need-assistance/49749
I’m trying to connect. When I check, the device connects to different bands, but I keep getting the “SIM card not registered” error.
I also updated the firmware, but it didn’t fix the issue.
Additionally, I changed the IMEI, but that didn’t help either.
I also connected the WAN and got internet access to try connecting to the cloud service and open a ticket, but I wasn’t successful.
Please guide me, thank you.
And how can I restore the original IMEI again? Resetting the device was not successful.
We noticed that you have already reached out to us by email regarding this issue.
Please continue working with our support team through the ticket system so we can assist you more effectively.
This post will remain open in case other users wish to share additional suggestions.
I have MT3000 and I have come across a bug in /usr/bin/gl_modem. When connect-auto is called the __common_get_sim_iccid() call gets the iccid from the sim but expects a 20 digit iccid. This length requirement is hard coded in the binary and fails sim cards that only return 19 digits.
Basically you have to patch gl_modem to be happy with a 19 digit iccid.
Thank you for your report.
To help us investigate further, could you please confirm:
  1. What firmware version is your MT3000 currently running?
  2. If the program is not patched, what user-facing issue do you observe? For example:
    • Mobile data does not connect
    • The ICCID is missing/incorrect on certain pages
Based on our initial review, the impacted code path appears to only write to a specific temporary file and should not affect cellular connectivity or how the ICCID is displayed in the UI.
If you’re seeing different behavior, please let us know—especially which page(s) show the issue and what the expected vs. actual output is.
At the moment we don’t have a SIM with a 19-digit ICCID available to reproduce this on our side, so any additional details (screenshots, steps to reproduce, logs) would be very helpful.
Thank you for your cooperation and patience.
Hi there,
Hey thanks for your reply.
FW version: 4.8.1 release8
OpenWrt 21.02-SNAPSHOT / LuCI openwrt-21.02 branch git-22.297.57860-ebcfdda
Yes indeed, in that function __common_get_sim_iccid() that’s all it does but if it fails and returns an error code then functions like connect-auto also fail and the modem is constantly redialled.
it also means that gl_modem -B 1-1 connect-auto always fails and never builds a profile in /etc/config/network - it all has to be done manually.
Eg:
Thu Dec 18 01:58:18 2025 daemon.info gl_modem: (modem_cm.c:1324) Enter the dialing process
Thu Dec 18 01:58:18 2025 daemon.err gl_modem: (modem_cm.c:1343) Failed to get iccid, maybe PIN code is locked,please check!
The iccid file is also a placeholder to determine if the simcard has “changed” by other function calls.
The only fix (other than patching the binary :wink: ) is to manually complete the config for the interface in /etc/config/network:
config interface 'modem_1_1'
option apn 'giffgaff.com'
option dialnumber '*99#'
option proto 'ncm'
option username 'gg'
option password 'p'
option metric '40'
option device '/dev/ttyUSB2'
option mode 'preferlte'
option pdptype 'IP'
option ipv6 'auto'
option delay '5'
option disabled '0'
option iccid '89xxxxxxxxxxxxxxxx5' # so that modem_network_recover_detection.sh works which isn’t sensitive to iccid length..
option ip_type 'IP' # for kmwan which doesn’t use “option pdptype”
Largely academic anyway as my MT3000 doesn’t recognise giffgaff or my modem (E3372-320) either.
If I can help further please let me know.
Thanks,
Andy.
Thank you very much for providing such detailed information.
We have requested our R&D team to further investigate and resolve this issue.
Hello Andy,
Thank you for your guidance.
Support told me that because I’m using this in Iran, the service is not available for Iran.
However, I believe there must be a way to make it work, and I would appreciate your help if possible.
I’m even in a city where Baku operators are accessible.
My Baku SIM card works perfectly on my phone, but when I insert the SIM card into my router (X3000NR), I still get the error:
I even lock the operator to Baku operators, but the issue remains.
Now I’m not sure whether the problem persists because Iranian operators are also detected alongside Baku operators, or if there is another underlying issue.
Important: I checked via LuCI under
Network → Interfaces,
and for modem_0001 it shows the error:
Unsupported type
I even updated the router firmware, but the problem was not resolved.
If I understood correctly, in
/etc/config/network
the type is set to
qmci.
I also installed modemmanager, but I was not successful.
If you know any solution, I would really appreciate your help.
Hi there,
What modem are you using? It may not support qmi mode. Try ncm mode instead.
Here are my notes I made for myself to get an E3372h working on MT3000 with a giffgaff SIM.
Andy.
Also check out:
And this may help with the errors:
and:
Scroll down to “Errors in the logs and what they probably mean”
Merry Christmas!
Andy.
