Hi, I have a GL-X300B Collie in the UK which works well with Tesco (O2) and Lebara (Vodaphone) SIMs but I can’t get it to work with a LycaMobile (EE) SIM. I activated the LycaMobile SIM in my Android phone successfully and copied the APN settings to the GL-X300B (where applicable) but with no success. LycaMobile say they only provide APN settings for iPhone & Android. Has anyone got an idea on how to get LycaMobile or EE SIMs working with the GL-X300B ?
EE SIMs, from my experience, work automatically.
Lycamobile, if I remember correctly, do no offer data SIMs. They prevent non-phone use (tethering) and even then, throttle aggressively.
You can try using EE’s own APN (everywhere?) and changing the TTL to 65.
The problem now is that you have to manually enter these AT commands every time you power up the router.
I’ll investigate how you automate this with gl_modem in a shell script via SSH by trawling through other posts. Any pointers on how to execute the script on power up and where to put the script gratefully received.
I’m using MVNO SIMs because I want to assess which networks offer the best reception in the rural location where the router is to be deployed (battery powered, in a barn in a field) Lycamobile and Lebara etc. have cheap 30 day offerings. The Lycamobile APN details I copied from my Android phone after registration actually were EE settings with the MVNO settings blank.
I now have a partial solution using AT commands, thanks for your input.
