GL1-RM1PE with Dell Optiplex 3000 and Virtual Media enabled no HDMI Signal
When using the GL1-RM1PE with Dell Optiplex 3000 and just enabled virtual media (without mounting an ISO) i very often get no signal no HDMI signal. Tried with two Dell Optiplex 3000 machines. Latest Bios on the Dell. 1.7.1 release 1 on the KVM…..
Often shutdown PC, disconnect cabels, reboot KVM. Looks like disable Virtual Media and then reboot works. Tried with several EID’s…
Connecting a monitor just works on the Dell Optilex machines
If convenient, please try different controlled devices (not different Dell Optiplex 3000s) to see if the problem is resolved.
If the problem persists, could you please export the logs to my email (flora.wan@gl-inet.com)?
Does your Dell computer enable sleep? I want to confirm if it's an issue where it can't wake up after sleeping.
The dell wasnt sleeping, does support it. But was after a fresh powered up
Did send you both logs, the working one and the non working one.
I did not receive your email and log. Could you please send me another email?
Or you can click on my profile picture and select "Message" to send me the Logs.
