Hi all,
I can´t connect to eplus, error message is “sim is not registered”
I tried different APN and settings, still the same.
Maybe someone can help me and providing a profile?!
Cheers
Hi all,
Cheers
Does the SIM work when you put it into a mobile phone?
yes, no problem to connect.
PIN is deactivated
I also tried to connect automatic and manual.
Setting up an APN with AT command has no impact.
Can cards from other operators be recognized?
@mudifan: are you talking about O2 Prepaid? Have tried the apn: pinternet.interkom.de? www.o2apn.de
tried out, and no, same problem ![]()
yes, should be a general problem with the device or modem
Mon Jan 15 11:22:34 2024 daemon.notice pppd[21971]: pppd 2.4.9 started by root, uid 0
Mon Jan 15 11:22:35 2024 local2.info chat[22007]: abort on (BUSY)
Mon Jan 15 11:22:35 2024 local2.info chat[22007]: abort on (NO CARRIER)
Mon Jan 15 11:22:35 2024 local2.info chat[22007]: abort on (ERROR)
Mon Jan 15 11:22:35 2024 local2.info chat[22007]: report (CONNECT)
Mon Jan 15 11:22:35 2024 local2.info chat[22007]: timeout set to 10 seconds
Mon Jan 15 11:22:35 2024 local2.info chat[22007]: send (AT&F^M)
Mon Jan 15 11:22:35 2024 local2.info chat[22007]: expect (OK)
Mon Jan 15 11:22:35 2024 local2.info chat[22007]: ^M
Mon Jan 15 11:22:35 2024 local2.info chat[22007]: OK
Mon Jan 15 11:22:35 2024 local2.info chat[22007]: -- got it
Mon Jan 15 11:22:35 2024 local2.info chat[22007]: send (ATE1^M)
Mon Jan 15 11:22:35 2024 local2.info chat[22007]: ATE1^M^M
Mon Jan 15 11:22:35 2024 local2.info chat[22007]: send (AT+CGDCONT=1,"IP","pinternet.interkom.de"^M)
Mon Jan 15 11:22:35 2024 local2.info chat[22007]: timeout set to 30 seconds
Mon Jan 15 11:22:35 2024 local2.info chat[22007]: AT+CGDCONT=1,"IP","pinternet.interkom.de"^M^M
Mon Jan 15 11:22:35 2024 local2.info chat[22007]: send (ATD*99***1#^M)
Mon Jan 15 11:22:35 2024 local2.info chat[22007]: expect (CONNECT)
Mon Jan 15 11:22:35 2024 local2.info chat[22007]: ATD*99***1#^M^M
Mon Jan 15 11:22:35 2024 local2.info chat[22007]: CONNECT
Mon Jan 15 11:22:35 2024 local2.info chat[22007]: send ( ^M)
Mon Jan 15 11:22:35 2024 daemon.info pppd[21971]: Serial connection established.
Mon Jan 15 11:22:35 2024 daemon.info pppd[21971]: Renamed interface ppp0 to 3g-modem_1_1_2
Mon Jan 15 11:22:35 2024 daemon.info pppd[21971]: Using interface 3g-modem_1_1_2
Mon Jan 15 11:22:35 2024 daemon.notice pppd[21971]: Connect: 3g-modem_1_1_2 <--> /dev/ttyUSB3
Mon Jan 15 11:22:35 2024 kern.info kernel: [ 2373.537338] 3g-modem_1_1_2: renamed from ppp0
Mon Jan 15 11:22:36 2024 daemon.info pppd[21971]: CHAP authentication succeeded
Mon Jan 15 11:22:36 2024 daemon.notice pppd[21971]: CHAP authentication succeeded
Mon Jan 15 11:23:07 2024 daemon.warn pppd[21971]: IPV6CP: timeout sending Config-Requests
Mon Jan 15 11:23:18 2024 daemon.notice pppd[21971]: Modem hangup
Mon Jan 15 11:23:18 2024 daemon.notice pppd[21971]: Connection terminated.
Mon Jan 15 11:23:19 2024 daemon.info pppd[21971]: Exit.
Mon Jan 15 11:23:19 2024 daemon.notice netifd: Interface 'modem_1_1_2' is now down
Mon Jan 15 11:23:19 2024 daemon.notice netifd: Interface 'modem_1_1_2' is setting up now
Mon Jan 15 11:23:20 2024 daemon.notice netifd: modem_1_1_2 (23135):
Mon Jan 15 11:23:20 2024 daemon.notice netifd: modem_1_1_2 (23135): ERROR
Mon Jan 15 11:23:21 2024 daemon.notice netifd: modem_1_1_2 (23135):
Mon Jan 15 11:23:21 2024 daemon.notice netifd: modem_1_1_2 (23135): OK
Mon Jan 15 11:23:21 2024 daemon.notice netifd: modem_1_1_2 (23135): Failed to parse message data
Mon Jan 15 11:23:22 2024 daemon.notice netifd: modem_1_1_2 (23135):
Mon Jan 15 11:23:22 2024 daemon.notice netifd: modem_1_1_2 (23135): ERROR
Mon Jan 15 11:23:22 2024 daemon.notice netifd: modem_1_1_2 (23135): OK
Mon Jan 15 11:23:23 2024 daemon.notice netifd: modem_1_1_2 (23135): cat: can't open '/proc/gl-hw-info/sim': No such file or directory
Mon Jan 15 11:23:25 2024 daemon.notice netifd: modem_1_1_2 (23135): cat: can't open '/tmp/modem.1-1/signal': No such file or directory
Mon Jan 15 11:23:25 2024 daemon.notice pppd[23660]: pppd 2.4.9 started by root, uid 0
Mon Jan 15 11:23:26 2024 local2.info chat[23662]: abort on (BUSY)
Mon Jan 15 11:23:26 2024 local2.info chat[23662]: abort on (NO CARRIER)
Mon Jan 15 11:23:26 2024 local2.info chat[23662]: abort on (ERROR)
Mon Jan 15 11:23:26 2024 local2.info chat[23662]: report (CONNECT)
Mon Jan 15 11:23:26 2024 local2.info chat[23662]: timeout set to 10 seconds
Mon Jan 15 11:23:26 2024 local2.info chat[23662]: send (AT&F^M)
Mon Jan 15 11:23:26 2024 local2.info chat[23662]: expect (OK)
Mon Jan 15 11:23:26 2024 local2.info chat[23662]: ^M
Mon Jan 15 11:23:26 2024 local2.info chat[23662]: OK
Mon Jan 15 11:23:26 2024 local2.info chat[23662]: -- got it
Mon Jan 15 11:23:26 2024 local2.info chat[23662]: send (ATE1^M)
Mon Jan 15 11:23:27 2024 local2.info chat[23662]: expect (OK)
Mon Jan 15 11:23:27 2024 local2.info chat[23662]: ^M
Mon Jan 15 11:23:27 2024 local2.info chat[23662]: ATE1^M^M
Mon Jan 15 11:23:27 2024 local2.info chat[23662]: OK
Mon Jan 15 11:23:27 2024 local2.info chat[23662]: -- got it
Mon Jan 15 11:23:27 2024 local2.info chat[23662]: send (AT+CGDCONT=1,"IP","pinternet.interkom.de"^M)
Mon Jan 15 11:23:27 2024 local2.info chat[23662]: timeout set to 30 seconds
Mon Jan 15 11:23:27 2024 local2.info chat[23662]: AT+CGDCONT=1,"IP","pinternet.interkom.de"^M^M
Mon Jan 15 11:23:27 2024 local2.info chat[23662]: send (ATD*99***1#^M)
Mon Jan 15 11:23:27 2024 local2.info chat[23662]: expect (CONNECT)
Mon Jan 15 11:23:27 2024 local2.info chat[23662]: ATD*99***1#^M^M
Mon Jan 15 11:23:27 2024 local2.info chat[23662]: CONNECT
Mon Jan 15 11:23:27 2024 local2.info chat[23662]: send ( ^M)
Mon Jan 15 11:23:27 2024 daemon.info pppd[23660]: Serial connection established.
Mon Jan 15 11:23:27 2024 kern.info kernel: [ 2425.325196] 3g-modem_1_1_2: renamed from ppp0
Mon Jan 15 11:23:27 2024 daemon.info pppd[23660]: Renamed interface ppp0 to 3g-modem_1_1_2
Mon Jan 15 11:23:27 2024 daemon.info pppd[23660]: Using interface 3g-modem_1_1_2
Mon Jan 15 11:23:27 2024 daemon.notice pppd[23660]: Connect: 3g-modem_1_1_2 <--> /dev/ttyUSB3
Mon Jan 15 11:23:28 2024 daemon.info pppd[23660]: CHAP authentication succeeded
Mon Jan 15 11:23:28 2024 daemon.notice pppd[23660]: CHAP authentication succeeded
Mon Jan 15 11:23:28 2024 daemon.notice pppd[23660]: Modem hangup
Mon Jan 15 11:23:28 2024 daemon.notice pppd[23660]: Connection terminated.
Mon Jan 15 11:23:29 2024 daemon.info pppd[23660]: Exit.
Mon Jan 15 11:23:30 2024 daemon.notice netifd: Interface 'modem_1_1_2' is now down
Mon Jan 15 11:23:30 2024 daemon.notice netifd: Interface 'modem_1_1_2' is setting up now
Mon Jan 15 11:23:31 2024 daemon.notice netifd: modem_1_1_2 (23800):
Mon Jan 15 11:23:31 2024 daemon.notice netifd: modem_1_1_2 (23800): ERROR
Mon Jan 15 11:23:32 2024 daemon.notice netifd: modem_1_1_2 (23800):
Mon Jan 15 11:23:32 2024 daemon.notice netifd: modem_1_1_2 (23800): ERROR
Mon Jan 15 11:23:32 2024 daemon.notice netifd: modem_1_1_2 (23800): OK
Copyright © 2023 GL.iNet. Alle Rechte vorbehalten
What about other Sim cards?
still the same problem with other sim/carrier
Have you 3g instead of QCM at apn? I see the modem is trying the 3g, which not exist anymore. Guess you already done modem reset
tried QCM
[01-15_13:00:20:491] QConnectManager_Linux_V1.6.3.1
Mon Jan 15 13:00:20 2024 daemon.notice netifd: Interface 'modem_1_1_2' is now up
Mon Jan 15 13:00:20 2024 daemon.notice netifd: Network device 'wwan0' link is up
Mon Jan 15 13:00:20 2024 daemon.notice netifd: Network alias 'wwan0' link is up
Mon Jan 15 13:00:20 2024 daemon.notice netifd: Interface 'modem_1_1_2_4' is enabled
Mon Jan 15 13:00:20 2024 daemon.notice netifd: Interface 'modem_1_1_2_4' has link connectivity
Mon Jan 15 13:00:20 2024 daemon.notice netifd: Interface 'modem_1_1_2_4' is setting up now
Mon Jan 15 13:00:21 2024 daemon.notice netifd: modem_1_1_2_4 (21103): udhcpc: started, v1.35.0
Mon Jan 15 13:00:21 2024 daemon.notice netifd: modem_1_1_2 (21068): [01-15_13:00:20:508] Find /sys/bus/usb/devices/1-1.2 idVendor=0x2c7c idProduct=0x30e, bus=0x001, dev=0x00a
Mon Jan 15 13:00:21 2024 daemon.notice netifd: modem_1_1_2 (21068): [01-15_13:00:20:511] Auto find qmichannel = /dev/cdc-wdm0
Mon Jan 15 13:00:21 2024 daemon.notice netifd: modem_1_1_2 (21068): [01-15_13:00:20:514] Auto find usbnet_adapter = wwan0
Mon Jan 15 13:00:21 2024 daemon.notice netifd: modem_1_1_2 (21068): [01-15_13:00:20:515] netcard driver = qmi_wwan, driver version = 5.10.176
Mon Jan 15 13:00:21 2024 daemon.notice netifd: modem_1_1_2 (21068): [01-15_13:00:20:516] Modem works in QMI mode
Mon Jan 15 13:00:21 2024 daemon.notice netifd: modem_1_1_2 (21068): [01-15_13:00:20:587] cdc_wdm_fd = 7
Mon Jan 15 13:00:21 2024 daemon.notice netifd: modem_1_1_2 (21068): [01-15_13:00:20:675] Get clientWDS = 6
Mon Jan 15 13:00:21 2024 daemon.notice netifd: modem_1_1_2 (21068): [01-15_13:00:20:707] Get clientWDS = 7
Mon Jan 15 13:00:21 2024 daemon.notice netifd: modem_1_1_2 (21068): [01-15_13:00:20:739] Get clientDMS = 1
Mon Jan 15 13:00:21 2024 daemon.notice netifd: modem_1_1_2 (21068): [01-15_13:00:20:771] Get clientNAS = 3
Mon Jan 15 13:00:21 2024 daemon.notice netifd: modem_1_1_2 (21068): [01-15_13:00:20:803] Get clientUIM = 3
Mon Jan 15 13:00:21 2024 daemon.notice netifd: modem_1_1_2 (21068): [01-15_13:00:20:835] Get clientWDA = 1
Mon Jan 15 13:00:21 2024 daemon.notice netifd: modem_1_1_2 (21068): [01-15_13:00:20:866] requestBaseBandVersion EM05GFAR07A07M1G
Mon Jan 15 13:00:21 2024 daemon.notice netifd: modem_1_1_2 (21068): [01-15_13:00:21:060] requestGetSIMStatus SIMStatus: SIM_READY
Mon Jan 15 13:00:21 2024 daemon.notice netifd: modem_1_1_2 (21068): [01-15_13:00:21:092] requestGetProfile[1] pinternet.interkom.de///0/IPV4V6
Mon Jan 15 13:00:21 2024 daemon.notice netifd: modem_1_1_2 (21068): [01-15_13:00:21:092] requestSetProfile[1] internet///0/IPV4V6
Mon Jan 15 13:00:21 2024 daemon.notice netifd: modem_1_1_2 (21068): [01-15_13:00:21:155] requestRegistrationState2 MCC: 262, MNC: 1, PS: Detached, DataCap: UNKNOW
Mon Jan 15 13:00:21 2024 daemon.notice netifd: modem_1_1_2_4 (21103): udhcpc: broadcasting discover
Mon Jan 15 13:00:23 2024 user.notice mwan3[21072]: Execute ifup event on interface modem_1_1_2 (wwan0)
Mon Jan 15 13:00:24 2024 daemon.notice netifd: modem_1_1_2_4 (21103): udhcpc: broadcasting discover
Mon Jan 15 13:00:27 2024 user.notice mwan3[21072]: Starting tracker on interface modem_1_1_2 (wwan0)
Mon Jan 15 13:00:27 2024 daemon.notice netifd: modem_1_1_2_4 (21103): udhcpc: broadcasting discover
Mon Jan 15 13:00:32 2024 user.info mwan3rtmon[5505]: Detect rtchange event.
Mon Jan 15 13:00:35 2024 user.notice firewall: Reloading firewall due to ifup of modem_1_1_2 (wwan0)
Mon Jan 15 13:01:10 2024 user.notice mwan3[22732]: Execute ifdown event on interface modem_1_1_2 (wwan0)
Mon Jan 15 13:01:13 2024 user.notice firewall: Reloading firewall due to ifdown of modem_1_1_2 (wwan0)
Mon Jan 15 13:01:18 2024 user.info mwan3track[21498]: Detect ifdown event on interface modem_1_1_2 (wwan0)
Mon Jan 15 13:01:23 2024 user.notice mwan3track[21498]: Interface modem_1_1_2 (wwan0) is offline
Mon Jan 15 13:01:50 2024 daemon.notice netifd: modem_1_1_2_4 (21103): udhcpc: received SIGTERM
Mon Jan 15 13:01:50 2024 daemon.notice netifd: modem_1_1_2_4 (21103): udhcpc: entering released state
Mon Jan 15 13:01:51 2024 daemon.notice netifd: modem_1_1_2_4 (21103): Command failed: ubus call network.interface notify_proto { "action": 0, "link-up": false, "keep": false, "interface": "modem_1_1_2_4" } (Permission denied)
Mon Jan 15 13:01:51 2024 daemon.notice netifd: Interface 'modem_1_1_2_4' is now down
Mon Jan 15 13:01:51 2024 daemon.notice netifd: Network alias '' link is down
Mon Jan 15 13:01:51 2024 daemon.notice netifd: Interface 'modem_1_1_2_4' has link connectivity loss
Mon Jan 15 13:01:51 2024 daemon.notice netifd: Interface 'modem_1_1_2_4' is disabled
Mon Jan 15 13:01:51 2024 daemon.notice netifd: modem_1_1_2 (24024): ./qcm.sh: eval: line 181: can't create : nonexistent directory
Mon Jan 15 13:01:52 2024 daemon.notice netifd: modem_1_1_2 (21068): [01-15_13:00:21:187] requestRegistrationState2 MCC: 262, MNC: 1, PS: Detached, DataCap: UNKNOW
Mon Jan 15 13:01:52 2024 daemon.notice netifd: modem_1_1_2 (21068): [01-15_13:00:21:218] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
Mon Jan 15 13:01:52 2024 daemon.notice netifd: modem_1_1_2 (21068): [01-15_13:00:21:251] requestQueryDataCall IPv6ConnectionStatus: DISCONNECTED
Mon Jan 15 13:01:52 2024 daemon.notice netifd: modem_1_1_2 (21068): [01-15_13:00:21:282] requestRegistrationState2 MCC: 262, MNC: 1, PS: Detached, DataCap: UNKNOW
Mon Jan 15 13:01:52 2024 daemon.notice netifd: modem_1_1_2 (21068): [01-15_13:00:36:323] requestRegistrationState2 MCC: 262, MNC: 1, PS: Detached, DataCap: UNKNOW
Mon Jan 15 13:01:52 2024 daemon.notice netifd: modem_1_1_2 (21068): [01-15_13:00:42:757] requestRegistrationState2 MCC: 262, MNC: 3, PS: Detached, DataCap: UNKNOW
Mon Jan 15 13:01:52 2024 daemon.notice netifd: modem_1_1_2 (21068): [01-15_13:00:57:795] requestRegistrationState2 MCC: 262, MNC: 3, PS: Detached, DataCap: UNKNOW
Mon Jan 15 13:01:52 2024 daemon.notice netifd: modem_1_1_2 (21068): [01-15_13:01:12:835] requestRegistrationState2 MCC: 262, MNC: 3, PS: Detached, DataCap: UNKNOW
Mon Jan 15 13:01:52 2024 daemon.notice netifd: modem_1_1_2 (21068): [01-15_13:01:14:307] requestRegistrationState2 MCC: 262, MNC: 1, PS: Detached, DataCap: UNKNOW
Mon Jan 15 13:01:52 2024 daemon.notice netifd: modem_1_1_2 (21068): [01-15_13:01:29:347] requestRegistrationState2 MCC: 262, MNC: 1, PS: Detached, DataCap: UNKNOW
Mon Jan 15 13:01:52 2024 daemon.notice netifd: modem_1_1_2 (21068): [01-15_13:01:44:387] requestRegistrationState2 MCC: 262, MNC: 1, PS: Detached, DataCap: UNKNOW
Mon Jan 15 13:01:52 2024 daemon.notice netifd: modem_1_1_2 (21068): [01-15_13:01:52:004] QmiWwanThread exit
Mon Jan 15 13:01:52 2024 daemon.notice netifd: modem_1_1_2 (21068): [01-15_13:01:52:005] qmi_main exit
Mon Jan 15 13:01:52 2024 daemon.notice netifd: Interface 'modem_1_1_2' is now down
Mon Jan 15 13:01:52 2024 user.notice mwan3[24022]: Execute ifdown event on interface modem_1_1_2 (unknown)
Mon Jan 15 13:01:53 2024 user.info mwan3track[21498]: Detect ifdown event on interface modem_1_1_2 (wwan0)
Mon Jan 15 13:01:54 2024 kern.info kernel: [ 4971.355478] usb 1-1.2: USB disconnect, device number 10
Mon Jan 15 13:01:54 2024 kern.info kernel: [ 4971.355964] option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
Mon Jan 15 13:01:54 2024 kern.info kernel: [ 4971.356130] option 1-1.2:1.0: device disconnected
Mon Jan 15 13:01:54 2024 kern.info kernel: [ 4971.356608] option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
Mon Jan 15 13:01:54 2024 kern.info kernel: [ 4971.356762] option 1-1.2:1.1: device disconnected
Mon Jan 15 13:01:54 2024 kern.info kernel: [ 4971.364401] option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
Mon Jan 15 13:01:54 2024 kern.info kernel: [ 4971.364531] option 1-1.2:1.2: device disconnected
Mon Jan 15 13:01:54 2024 kern.info kernel: [ 4971.364979] option1 ttyUSB3: GSM modem (1-port) converter now disconnected from ttyUSB3
Mon Jan 15 13:01:54 2024 kern.info kernel: [ 4971.365117] option 1-1.2:1.3: device disconnected
Mon Jan 15 13:01:54 2024 kern.info kernel: [ 4971.365423] qmi_wwan 1-1.2:1.4 wwan0: unregister 'qmi_wwan' usb-1b000000.usb-1.2, WWAN/QMI device
Mon Jan 15 13:01:55 2024 daemon.err modem_AT: (modem_AT.c:388) The /dev/ttyUSB2 does not open,continue to try.
Mon Jan 15 13:01:56 2024 daemon.err modem_AT: (modem_AT.c:388) The /dev/ttyUSB2 does not open,continue to try.
Mon Jan 15 13:01:57 2024 daemon.err modem_AT: (modem_AT.c:388) The /dev/ttyUSB2 does not open,continue to try.
Mon Jan 15 13:01:58 2024 user.notice mwan3track[21498]: Interface modem_1_1_2 (wwan0) is offline
Mon Jan 15 13:01:58 2024 daemon.err modem_AT: (modem_AT.c:388) The /dev/ttyUSB2 does not open,continue to try.
Mon Jan 15 13:01:59 2024 daemon.err modem_AT: (modem_AT.c:388) The /dev/ttyUSB2 does not open,continue to try.
Mon Jan 15 13:02:00 2024 daemon.info procd: Instance smstools3::instance1 pid 1043 not stopped on SIGTERM, sending SIGKILL instead
Mon Jan 15 13:02:00 2024 daemon.err modem_AT: (modem_AT.c:388) The /dev/ttyUSB2 does not open,continue to try.
Mon Jan 15 13:02:01 2024 daemon.err modem_AT: (modem_AT.c:388) The /dev/ttyUSB2 does not open,continue to try.
Mon Jan 15 13:02:02 2024 daemon.err modem_AT: (modem_AT.c:388) The /dev/ttyUSB2 does not open,continue to try.
Mon Jan 15 13:02:03 2024 daemon.err modem_AT: (modem_AT.c:388) The /dev/ttyUSB2 does not open,continue to try.
Mon Jan 15 13:02:04 2024 user.notice firewall: Reloading firewall due to ifdown of modem_1_1_2 ()
Mon Jan 15 13:02:04 2024 daemon.err modem_AT: (modem_AT.c:388) The /dev/ttyUSB2 does not open,continue to try.
Mon Jan 15 13:02:05 2024 daemon.err modem_AT: (modem_AT.c:388) The /dev/ttyUSB2 does not open,continue to try.
Mon Jan 15 13:02:06 2024 kern.info kernel: [ 4983.167094] usb 1-1.2: new high-speed USB device number 11 using ehci-platform
Mon Jan 15 13:02:06 2024 kern.info kernel: [ 4983.340370] option 1-1.2:1.0: GSM modem (1-port) converter detected
Mon Jan 15 13:02:06 2024 kern.info kernel: [ 4983.340717] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB0
Mon Jan 15 13:02:06 2024 kern.info kernel: [ 4983.341338] option 1-1.2:1.1: GSM modem (1-port) converter detected
Mon Jan 15 13:02:06 2024 kern.info kernel: [ 4983.341614] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB1
Mon Jan 15 13:02:06 2024 kern.info kernel: [ 4983.342267] option 1-1.2:1.2: GSM modem (1-port) converter detected
Mon Jan 15 13:02:06 2024 kern.info kernel: [ 4983.342604] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB2
Mon Jan 15 13:02:06 2024 kern.info kernel: [ 4983.343260] option 1-1.2:1.3: GSM modem (1-port) converter detected
Mon Jan 15 13:02:06 2024 kern.info kernel: [ 4983.343538] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB3
Mon Jan 15 13:02:06 2024 kern.info kernel: [ 4983.397534] qmi_wwan 1-1.2:1.4: cdc-wdm0: USB WDM device
Mon Jan 15 13:02:06 2024 kern.info kernel: [ 4983.398253] qmi_wwan 1-1.2:1.4: QuectelEC25&EC21&EG91&EG95&EG06&EP06&EM06&BG96&AG35 qmi wwan detected
Mon Jan 15 13:02:06 2024 kern.info kernel: [ 4983.399346] qmi_wwan 1-1.2:1.4 wwan0: register 'qmi_wwan' at usb-1b000000.usb-1.2, WWAN/QMI device, 06:ee:54:77:26:3d
Mon Jan 15 13:05:23 2024 daemon.notice netifd: Interface 'modem_1_1_2' is setting up now
Mon Jan 15 13:05:28 2024 daemon.notice netifd: modem_1_1_2 (31652):
Mon Jan 15 13:05:28 2024 daemon.notice netifd: modem_1_1_2 (31652): ERROR
Mon Jan 15 13:05:29 2024 daemon.notice netifd: modem_1_1_2 (31652):
Mon Jan 15 13:05:29 2024 daemon.notice netifd: modem_1_1_2 (31652): OK
Mon Jan 15 13:05:29 2024 daemon.notice netifd: modem_1_1_2 (31652): Failed to parse message data
Mon Jan 15 13:05:29 2024 daemon.notice netifd: modem_1_1_2 (31652): ERROR
Mon Jan 15 13:05:30 2024 daemon.notice netifd: modem_1_1_2 (31652):
Mon Jan 15 13:05:30 2024 daemon.notice netifd: modem_1_1_2 (31652): ERROR
Mon Jan 15 13:05:30 2024 daemon.notice netifd: modem_1_1_2 (31652): OK
Mon Jan 15 13:05:30 2024 daemon.notice netifd: modem_1_1_2 (31652): cat: can't open '/proc/gl-hw-info/sim': No such file or directory
Mon Jan 15 13:05:32 2024 daemon.notice netifd: modem_1_1_2 (32099): [01-15_13:05:32:580] QConnectManager_Linux_V1.6.3.1
Mon Jan 15 13:05:32 2024 daemon.notice netifd: Interface 'modem_1_1_2' is now up
Mon Jan 15 13:05:32 2024 daemon.notice netifd: Network device 'wwan0' link is up
Mon Jan 15 13:05:32 2024 daemon.notice netifd: Network alias 'wwan0' link is up
Mon Jan 15 13:05:32 2024 daemon.notice netifd: Interface 'modem_1_1_2_4' is enabled
Mon Jan 15 13:05:32 2024 daemon.notice netifd: Interface 'modem_1_1_2_4' has link connectivity
Mon Jan 15 13:05:32 2024 daemon.notice netifd: Interface 'modem_1_1_2_4' is setting up now
Mon Jan 15 13:05:33 2024 daemon.notice netifd: modem_1_1_2 (32099): [01-15_13:05:32:616] Find /sys/bus/usb/devices/1-1.2 idVendor=0x2c7c idProduct=0x30e, bus=0x001, dev=0x00b
Mon Jan 15 13:05:33 2024 daemon.notice netifd: modem_1_1_2 (32099): [01-15_13:05:32:626] Auto find qmichannel = /dev/cdc-wdm0
Mon Jan 15 13:05:33 2024 daemon.notice netifd: modem_1_1_2 (32099): [01-15_13:05:32:627] Auto find usbnet_adapter = wwan0
Mon Jan 15 13:05:33 2024 daemon.notice netifd: modem_1_1_2 (32099): [01-15_13:05:32:630] netcard driver = qmi_wwan, driver version = 5.10.176
Mon Jan 15 13:05:33 2024 daemon.notice netifd: modem_1_1_2 (32099): [01-15_13:05:32:632] Modem works in QMI mode
Mon Jan 15 13:05:33 2024 daemon.notice netifd: modem_1_1_2 (32099): [01-15_13:05:32:723] cdc_wdm_fd = 7
Mon Jan 15 13:05:33 2024 daemon.notice netifd: modem_1_1_2 (32099): [01-15_13:05:32:805] Get clientWDS = 6
Mon Jan 15 13:05:33 2024 daemon.notice netifd: modem_1_1_2 (32099): [01-15_13:05:32:837] Get clientWDS = 7
Mon Jan 15 13:05:33 2024 daemon.notice netifd: modem_1_1_2 (32099): [01-15_13:05:32:869] Get clientDMS = 1
Mon Jan 15 13:05:33 2024 daemon.notice netifd: modem_1_1_2 (32099): [01-15_13:05:32:901] Get clientNAS = 3
Mon Jan 15 13:05:33 2024 daemon.notice netifd: modem_1_1_2 (32099): [01-15_13:05:32:933] Get clientUIM = 3
Mon Jan 15 13:05:33 2024 daemon.notice netifd: modem_1_1_2 (32099): [01-15_13:05:32:965] Get clientWDA = 1
Mon Jan 15 13:05:33 2024 daemon.notice netifd: modem_1_1_2 (32099): [01-15_13:05:32:998] requestBaseBandVersion EM05GFAR07A07M1G
Mon Jan 15 13:05:33 2024 daemon.notice netifd: modem_1_1_2 (32099): [01-15_13:05:33:157] requestGetSIMStatus SIMStatus: SIM_READY
Mon Jan 15 13:05:33 2024 daemon.notice netifd: modem_1_1_2 (32099): [01-15_13:05:33:189] requestGetProfile[1] internet///0/IPV4V6
Mon Jan 15 13:05:33 2024 daemon.notice netifd: modem_1_1_2 (32099): [01-15_13:05:33:190] requestSetProfile[1] internet///0/IPV4V6
Mon Jan 15 13:05:33 2024 daemon.notice netifd: modem_1_1_2 (32099): [01-15_13:05:33:190] no need to set skip the rest
Mon Jan 15 13:05:33 2024 daemon.notice netifd: modem_1_1_2 (32099): [01-15_13:05:33:221] requestRegistrationState2 MCC: 262, MNC: 1, PS: Detached, DataCap: UNKNOW
Mon Jan 15 13:05:33 2024 daemon.notice netifd: modem_1_1_2_4 (32136): udhcpc: started, v1.35.0
Mon Jan 15 13:05:33 2024 daemon.notice netifd: modem_1_1_2_4 (32136): udhcpc: broadcasting discover
Mon Jan 15 13:05:35 2024 user.notice mwan3[32103]: Execute ifup event on interface modem_1_1_2 (wwan0)
Mon Jan 15 13:05:36 2024 daemon.notice netifd: modem_1_1_2_4 (32136): udhcpc: broadcasting discover
Mon Jan 15 13:05:38 2024 user.notice mwan3[32103]: Starting tracker on interface modem_1_1_2 (wwan0)
Mon Jan 15 13:05:39 2024 daemon.notice netifd: modem_1_1_2_4 (32136): udhcpc: broadcasting discover
Mon Jan 15 13:05:43 2024 user.info mwan3rtmon[5505]: Detect rtchange event.
Mon Jan 15 13:05:46 2024 user.notice firewall: Reloading firewall due to ifup of modem_1_1_2 (wwan0)
Mon Jan 15 13:06:21 2024 user.notice mwan3[1228]: Execute ifdown event on interface modem_1_1_2 (wwan0)
Mon Jan 15 13:06:24 2024 user.notice firewall: Reloading firewall due to ifdown of modem_1_1_2 (wwan0)
Mon Jan 15 13:06:29 2024 user.info mwan3track[32547]: Detect ifdown event on interface modem_1_1_2 (wwan0)
Mon Jan 15 13:06:34 2024 user.notice mwan3track[32547]: Interface modem_1_1_2 (wwan0) is offline
Mon Jan 15 13:07:48 2024 daemon.notice netifd: modem_1_1_2 (32099): [01-15_13:05:33:253] requestRegistrationState2 MCC: 262, MNC: 1, PS: Detached, DataCap: UNKNOW
Mon Jan 15 13:07:48 2024 daemon.notice netifd: modem_1_1_2 (32099): [01-15_13:05:33:286] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
Mon Jan 15 13:07:48 2024 daemon.notice netifd: modem_1_1_2 (32099): [01-15_13:05:33:317] requestQueryDataCall IPv6ConnectionStatus: DISCONNECTED
Mon Jan 15 13:07:48 2024 daemon.notice netifd: modem_1_1_2 (32099): [01-15_13:05:48:358] requestRegistrationState2 MCC: 262, MNC: 1, PS: Detached, DataCap: UNKNOW
Mon Jan 15 13:07:48 2024 daemon.notice netifd: modem_1_1_2 (32099): [01-15_13:06:03:397] requestRegistrationState2 MCC: 262, MNC: 1, PS: Detached, DataCap: UNKNOW
Mon Jan 15 13:07:48 2024 daemon.notice netifd: modem_1_1_2 (32099): [01-15_13:06:18:437] requestRegistrationState2 MCC: 262, MNC: 1, PS: Detached, DataCap: UNKNOW
Mon Jan 15 13:07:48 2024 daemon.notice netifd: modem_1_1_2 (32099): [01-15_13:06:33:477] requestRegistrationState2 MCC: 262, MNC: 1, PS: Detached, DataCap: UNKNOW
Mon Jan 15 13:07:48 2024 daemon.notice netifd: modem_1_1_2 (32099): [01-15_13:06:48:516] requestRegistrationState2 MCC: 262, MNC: 1, PS: Detached, DataCap: UNKNOW
Mon Jan 15 13:07:48 2024 daemon.notice netifd: modem_1_1_2 (32099): [01-15_13:07:03:557] requestRegistrationState2 MCC: 262, MNC: 1, PS: Detached, DataCap: UNKNOW
Mon Jan 15 13:07:48 2024 daemon.notice netifd: modem_1_1_2 (32099): [01-15_13:07:18:597] requestRegistrationState2 MCC: 262, MNC: 1, PS: Detached, DataCap: UNKNOW
Mon Jan 15 13:07:48 2024 daemon.notice netifd: modem_1_1_2 (32099): [01-15_13:07:33:637] requestRegistrationState2 MCC: 262, MNC: 1, PS: Detached, DataCap: UNKNOW
this is terrible, trying since hours
For O2 prepaid I used without problems the apn from atached picture,
It’s Ay Yildiz.
I tried your setup already
We operate a large number of Mudi v1 across Europe. The sim is not registered message is something we encounter almost every month on several devices. Over the years we have not been able to find out the reason and not even with support. It happens quite often when changing sim. Sometimes a few reboots sometimes a factory reset helps. Sometimes only inserting a sim from another operator. But it’s definitely not the sim or apn settings. We had identical routers after a format where in one sim worked and in the other it didn’t and yes the apn settings were the same. We were betting a lot on the modem problem only it was doing it with another modem. Apparently Glinet won’t solve this even in the GLE750V2 version sadly.
You could execute this AT command first then set it up from scratch to try: AT+QMBNCFG=“deactivate”
sometimes it works sometimes it doesn’t
Thanks for your advise, unfortunately it’s still not working ![]()
I never thought that I will experience such problems with it. How easy it is to run every SIM in a cheap handy.
You can insert the card and relay a wifi network
Log in to the cloud platform again and share the device to this account gl.inet_support?
Not sure, do you mean the system logs?
And not sure how to share the device to the support, I will try to open a ticket.
Thank you, then please open a ticket to our support team. You don’t need to describe the issue again, just post this forum link is ok.
