I encountered an issue using the GL.iNet GLKVM Comet (GL-RM1) on a Beckhoff C6915-0010 industrial PC. While video output and USB HID devices (keyboard/mouse) worked perfectly once Windows was fully loaded, there was no keyboard input available during POST or in the BIOS setup, even though the video signal was displayed correctly. Pressing DEL on the KVM to enter the BIOS had no effect, and even after entering the BIOS via a second external keyboard, the KVM inputs remained non-functional.
Troubleshooting steps confirmed that:
- The same GLKVM unit and USB cable worked without issues on other systems and servers.
- BIOS settings such as “USB Legacy Support” and “USB Keyboard Function” were enabled.
- The USB ports were tested individually, with no improvement.
Root Cause:
The Beckhoff BIOS would not initialize or recognize USB HID devices presented by the GLKVM when operating in High-Speed USB mode.
Solution:
In the BIOS, under “USB Device Settings,” we manually changed the “USB Operation Mode” from High Speed to Full/Low Speed. After saving and rebooting, keyboard and mouse input via the GLKVM Comet worked flawlessly in the BIOS and pre-boot environments.
Summary:
If you are using the GLKVM Comet with a Beckhoff C6915-0010 and cannot access or control the BIOS via the virtual keyboard or mouse, ensure the USB operation mode is explicitly set to Full/Low Speed in the BIOS. This allows the KVM’s HID emulation to be properly recognized by the embedded system firmware.
Tested Hardware:
- Beckhoff C6915-0010 (Award BIOS)
- GL.iNet GLKVM Comet (GL-RM1)
This workaround may apply to other industrial PCs with strict USB initialization behavior during POST.
