Heeeeelp USB wifi NIC
I bought a mango gli that's arriving tomorrow and i have a USB network adapter that is the following:
Nano adaptador USB Wi-Fi* 6 AX900 2,4 GHz y 5 GHz Stere can You tell me if it's compatible with the mini router? Or if i should just use it on My laptop instead of connecting it to the mango. Thanks
It seems that this is a WiFi adapter.
The Mango router comes with the WiFi feature, and your laptop can connect to it directly, either use your laptop's build-in adapater or this usb adapter.
And I think it may not compatible to connect it directly to Mango to increase its wireless capacity to AX900.
Did You click on the url to SEE it's característics?
At that price, it would have been a lot cheaper to get a router capable of 5gHz - maybe not quite as small though.
GL.iNet routers do not reliably support third-party USB WIFI adapters. Their engineers design firmware with only pre-tested WIFI devices in mind, and adding new adapters often breaks their scripts. Even when a USB WIFI adapter works with the current GL.iNet firmware, a future update will likely break it
Years ago I made a request for better support of USB WIFI adapters. Did not go far.
If you are trying to add USB WIFI adapters to a router, you are normally better off ditching the GL.iNet firmware and running generic OpenWRT.
