Hi my slate 7 - no cable detected
I have tried so many etherent cables all work with my M6 nighthawk BUT my slate 7 will not recognise any etherent cable when I plug one in .. it says no cable detected,.pls help…!
Hi again I have managed to connect my cable BUT the green etherent connected only shows green when the etherent is connected to WAN - I would like it to go green when it connects to the LAN also /.. anyway i can do this ? In the amdin panel it shows lan connected but not the green slate 7 display light on etherent.
Hi!
The Ethernet icon on the Slate 7 display is designed to indicate internet connectivity.
As a result, it lights up and turns green only when a WAN connection is detected.
If you would like the screen to also reflect the status of the individual Ethernet ports (WAN/LAN), we encourage you to complete the survey below. Your feedback will help our product team evaluate this for future updates.
It would take less than ten minutes in cwrit BUT gl i net hasnt allowed access to the led lights so the programme code cant be added…
Im really struggling to tether my phone and add an Ethernet (lan) cable from my encoder to my slate 7 - I just can't seem to get the settings for it to recognise the inputted Ethernet cable it keeps saying no cable detected BUT all cables are fine and work perfectly. Its driving me crazy...!
Could you clarify the issues you are encountering?
Based on your description, it appears you may be experiencing:
  1. The Slate 7 rebooting or crashing a few minutes after startup
  2. Mobile USB Tethering problems
  3. Ethernet connection issues
Please confirm whether this understanding is correct.
If so:
For Issue 1:
  1. Ensure you are using the original Slate 7 power adapter, or another adapter rated for 5V/3A, 9V/3A, or 12V/2.5A.
  2. Restore the device to factory settings following the provided tutorial, then observe whether the problem remains.
    Repair network or reset - GL.iNet Router Docs 4
For Issue 2:
Please refer to our Mobile USB Tethering tutorial to check whether the configuration matches the recommended steps.
Tethering - GL.iNet Router Docs 4
iPhone tethering failed - GL.iNet Router Docs 4
For Issue 3:
Could you share additional details?
  1. Does the issue occur on the WAN side, LAN side, or both?
  2. What devices and models are involved in the connection?
  3. At what point or in which pages do you see the “cable not detected” message?
