Hi All, i am trying to add the Holafly esim and getting the following error does anyone else faced issue recently ? i previously added other esims from holafly and it worked ok
Device start download profile
Download profile: 30%
Download profile fail: maybe this profile has been downloaded repeatedly by other devices or the current device, please check it or use other esim profile to test, if you confirm this is first time download, you can copy this logs to contact GL.iNet support get help.
It is very frustrating - I tried Holafly and Orange eSIM (non-physical SIM) this week while travelling to Italy. I specifically purchased the Spitz Plus (GL-X2000) router two weeks ago for its advertised eSIM compatibility, so this issue is very disappointing. The eSIM partners of Gl.iNet are more expensive, and the download speed is inferior to that of competitive phone operators (e.g. Lebara) in roaming mode. If a solution cannot be provided promptly, I will have no choice but to return the modem and seek a refund. This is the kind of error message i get with orange (similar to holafly): Device start connect internet
Internet connect success
Download profile: 50%
Thanks, Cathy. All antennas are connected properly. The APN config is aligned with the recommended EIOTCLUB APN (only 1 configuration is possible for Europe). Band masking has not helped at all. In the end,I had to use my mobile phone instead of the Spitz Plus (GL-X2000) router with both Holafly and Orage eSIM (France) while travelling. The EIOTCLUB eSIM I purchased, which was recommended as compatible with my router, uses Wind and offers up to 2 Mbps in download speeds. However, this is quite frustrating for most applications, as it's slower than my phone's data roaming speed.
Ok I could not install Holafly and Orage eSIM (France). I could install an eSIM from easySIM.global, which installed without error. However, now the router says that my physical eSIM is not registered. I tried rebooting, removing and re-inserting the eSIM card. Nothing works. What shall I do?
Regarding the slow speed, if you are using wifi, try to modify the wifi setting of the router, such as the wifi channel or wifi bandwidth, then see if it's better
To set up the easySIM.global:
ensure the esim profile is enabled
stop the cellular connection, reboot the modem and reconnect.
I’ve found this topic after purchasing Orange eSIM for 42 EUR and spent 2 hours debugging (google has not indexed this forum well). Have the same error 2 months later, is it that hard to publish a compatibility list for eSIM providers?
