How to actually launch/use downloaded plugins
I get this error
Ok, 1 by 1:
  1. Connect via SSH (Putty!) to your router
  2. Run tcpdump -i eth2 -w debug.pcap
  3. Let it run for 1 minute
  4. Press CTRL+C
  5. Close Putty
  6. Open WinSCP and connect to router
  7. Navigate to the folder /root/on right side.
  8. Download the debug.pcap file.
will the router's kernel log be of help instead?, pcap method is not successful
I have read the kernel log before and found that there are data packets coming in from your eth2 interface, so I need to capture the packets to see what type of data packets they are.
Thank you for your patience. I've followed the steps and managed to get the file. I will dm you shortly
Please DM @_zhang - he needs them :wink:
I have dmed the pcap file. Thanks in advance
Thanks, I have sent to @_zhang too :smiley:
I've noticed that with depleted data, despite not having access to the general internet, I can access the carrier default website. Could this restricted access be what's deceiving the Flint 2?
Issue detected to be with 'low data mode' setting. Carried over to a dedicated thread with an appropriate topic.
