I need to try and connect my MT300A to an IPSEC/L2TP server so that I can access secure internet. I don’t have the option of using OpenVPN unfortunately (which would be nice and easy!).
I have had a look at existing tutorials for adding StrongSwan, but I can’t figure out how to configure it to work. Is anyone aware of an easy way to add IPSec/L2TP support?
Hi alzhao, I’m not sure where I can set this up in Luci - I had a look but couldn’t see anywhere in the GUI. Could you post a brief walkthough so I can try it out please?
First, go to Network->Interfaces, then create a new interface
After you click “Submit”, you will then be able to configure it. You can choose L2tp, you will be asked to switch protocol.
Now You have a switch protocol button, after you click, you will be asked to install xl2tpd package. Just click it and follow the guide to install it. You may met two problem, first, it will tell you this package is not found. You can just click “update list” and then research this package. Second, after install it may tell you that there are 255 errors, just omit it.
Now, type you server, username and password. Then click “Save & Apply”
thank you for the guide. I have exactly the same problem, but I need IPSEC Xauth PSK protocol to connect to a Fritzbox. Should that work as well or would I need openswan for that? And if, how should I ideally install the necessary openswan package?
Ah, I see. So as far as I’ve learned, I’ll need strongswan-default (or -full), ip, djbdns-tools and maybe iptables-mod-nat-extra in case of overlapping IP subnets.
Could you give me some hint where to start with compilation of these for the MT300A? Will I have to build the whole system from scratch or can I somehow just build those 3-4 packages against your v2.20 as base. I’ve never set up an environment just to compile single packages later on, so I’m a bit lost on that…
i just got a router and am so glad i have this. But there is just one issue, i am new in openwrt and i need IPSec/ssl tls, just like cisco any connect.
Is there any guide i can use, to configure my router to act as VPN client.
@nomad, 2.23-5 is not backed with full repo so you may not be able to install kernel modules. 2.23-6 is compiled with full software repo and you will do this
@Jyoti, I got some request to support IPSec, pptp, l2tp etc. I will install these protocols in the new firmware and hope to get a guide for you later. Thanks!
I also need support for L2TP with preshared key. Any help would be appreciated. I tried installing strongswan, but this didn’t present any new configuration options in the GUI, so perhaps this must be configured manually via CLI?
Hi, just adding another voice for L2TP/IPsec with Pre Shared Key. No rush, but want you to know there is a need out there!
Am I correct in assuming from the above that you cannot use a VPN that uses Pre Shared Keys with L2TP (IPsec) with the current firmware. Or, is it just difficult to configure?
Update: I’m not a networking guy, but I chatted with some VPN Providers. I am being told that the lack of a shared key option indicates that only L2TP (and not IPsec) is implemented in the router. Apparently, IPsec is the encryption protocol, without which L2TP is ineffective for a VPN, as everything in L2TP will be sent clear text. So, a little more understanding (in my head), but still the same questions: 1) Is my understanding as stated correct? 2) Is IPsec completely missing/unavailable, or just difficult for the end user (me) to implement?
@lstevens, in GL.iNet download center we have new firmware added UI for l2tp. As you said there is something related to iPsec and preshared keys so L2tp is not working now. Hope to solve it soon.
