Hello. Just need some guidance on how to setup stunnel from client (Beryl router) to home server running Pfsense as OpenVPN server. Currently everything works as is, but I may be travelling to countries where this may be blocked if I don’t obfuscate with stunnel. I’m not seeing a clear cut step by step documentation on how to do do this. Any assistance would be appreciated. Thanks.
So it works without obfuscate right?
The router does not support obfuscate at present.
Hello…thanks for your response…yes it is working without any SSL wrapper like stunnel. You mentioned it is not supported. I saw this post where it mentions you can download the stunnel package using Luci and set it up…not complete step by step however (How to set up Stunnel?)
