How to Setup Windscribe on GL.iNet GL-MT6000(Flint 2)
I saw request to add Windscribe VPN into the Gl-iNet Routers UI.
Adding Windscribe VPN to Router UI
It was more than 4 years ago.
I bought GL.iNet GL-MT6000(Flint 2) to get this advantage. and found that nothing was changed.
There still only AzireVPN and Mullvad.
Do you have instructions how to add Windscribe VPN into the list and setup connection, or better return the router back and change it on CUDY which has Windscribe VPN in their list?
Here are the instructions: WireGuard Client - GL.iNet Router Docs 4
Thank you for you quick reply, I missed link that I can add manually.
I already found and added - works perfect.
Windscribe VPN works with Flint 2. You need to login to your Windscribe account and download the Wireguard configuration for the exit node you want to use.
Is there any ways to set VPN individually on client or VPN will enable to all clients?
I have a CUDY R700, there switches to define which client will go thru vpn and which goes thru local network.
Please read the information about the proxy modes / routing policies here: VPN Dashboard - GL.iNet Router Docs 4
Amazing! I love this router more and more.
Thank you all for supporting newbies like me.
