b_9
June 24, 2024, 8:47pm
Are the only ways to use my custom/encrypted NextDNS set up on my Flint 2 currently:
waiting for custom DNS to be added
installing the NextDNS CLI somehow
using LuCi (don't even know what that is really lol)
setting it as an upstream server in AdGuard Home
Ideally I just want to just the GL UI (or AGH UI less ideally) and not have to do any command line or router/network wizardry.
j2zero
June 24, 2024, 8:56pm
2
Manual DNS
Or if you are using encrypted DNS / want more DNS control then use adguard home and just add your DNS to the upstream DNS inside adguard home settings page.
b_9
June 24, 2024, 9:22pm
3
Ideally custom encrypted DNS would be natively supported (I know it is coming eventually) but if I have sadly use AGH in the mean time, what do I set these settings to?
I will check out AGH's docs too but I wanted to ask here too.
What the f is a Bootstrap DNS server?
b_9
June 24, 2024, 9:24pm
4
Thanks for responding.
Definitely using encrypted DNS. I guess I will have use AGH for now sadly.
We really need custom encrypted DNS in the GL UI!
alzhao
June 25, 2024, 5:55am
5
Isn't NextDNS there already?
DNS over TLS is encrypted DNS, no?
b_9
June 25, 2024, 10:47pm
6
Yes DoT is encrypted DNS, I was meaning DoH, I should have specified that in the post. Ideally I want to use DoH.
NextDNS is in the DoH server list but no has info on what server it is using and I cannot add my custom ID like I just learned I can with DoT.
I will use DoT with my NextDNS ID until custom DoH is added.
alzhao
June 26, 2024, 3:52am
7
DoH for NextDNS is there also.
b_9
June 26, 2024, 3:57am
8
But I can't add my NextDNS ID. That is just the basic NextDNS DoH server (I assume). I want to use my custom NextDNS set up like I can with DoH.
And @yuxin.zou just shared this - so custom DNS is coming.
