When I was using pressure 4.8.3op24, I was able to create a tunnel in which I did not select any VPN, and so I could specifically do a specific bypass for a Mac address, without decreasing security.
Since both the specific kill switch of each tunnel and the enhanced kill switch were still activated.
I'm trying to do the same 4.9.1op25 but without success. I couldn't do it on 4.9.0op24 either, so I think it's not a matter of the OpeWrt version
I was wondering if someone could please tell me if it is possible to create a wireguard profile for the "non vpn tunnel"
Set the VPN tunnel to Exclude specific devices mode, set the MAC address, and then enable Kill switch for the tunnel. The bypassed device will not use the VPN
Starting from firmware v4.9, the VPN subsystem has been redesigned. The previous Not Use VPN mode conflicts with the VPN design logic introduced in v4.9. As a result, this mode was removed from the GUI.
To configure a “Not Use VPN” policy on firmware v4.9.1, please refer to the following KB article and follow Method 1, which is the recommended method:
