Hi, anyone knowns how config vpn policies to see hulu using nordvpn?
I need just route hulu na di need keep the others withoout
I tryed but no working properly
Regards
Regards
You need to find its all domain, and add them to VPN routing policy.
Did you see this thread VPN policy quick guide and feedback?
Tryed are cloud Amazon so I cannot route All. I need all subnet but the best would to application policies.
Anyone done something?
Thks
thks, the problem is that with hulu no working…
teh only solution could be move all in vopn and make an exclusion for netflix (italy)
no working…if a make netflix see the proxy detection…so no working vpn policies correcly
If you want only hulu trough VPN you have to put all hulu ip in the list “use vpn for”…
yes , but also using ip info i alsways find others ip…anyone done with hulu?
Regards
How much ip of hulu do you have find? For Netflix I founded 147 ip…
CAN YOU SEND ME THE LINK FROM IP?
for netflix 150 for holu really…too less
tHKS
Hi, i tryed but are not complete IP
hulu use a lot amazon cloud so it’s really difficoult…
i keep for now vpn policies just for hulu.com
Regards
