I have a AX1800 running 4.1.0. It has a public IP address connected directly to my modem- passed straight through.
I have the VPN client connected to AirVPN.
I want to use the VPN server function to allow for remote access. I have been using OpenVPN for both connections.
I am using port 52000 for the OpenVPN server connection (assigned by VPN provider). I have this port forwarded with the VPN provider.
When the VPN client is disconnected I am able to successfully connect to the VPN server via my ISP assigned IP address.
When I initiate the VPN client connection, I am unable to connect to the VPN server.
I have tried to connect to the VPN server with both my ISP provided IP, and my VPN static IP, neither work when the VPN client is connected.
I would like to connect to the VPN server with the VPN client active. I would be ok connecting to it via the ISP IP, or the VPN client IP address.
I have be told different things, but I am pretty sure that only Brume 2 has VPN Cascading in the GUI which allows for both a openvpn client and server to be running at the same time. I believe you can have a openvpn client/server or a wireguard client/server, on different protocals running at the sametime.
So you can leave the airVPN client connected and create a wireguard sever, or switch. I do not work for and I am not directly associated with GL.iNet
