Iphone Tethering
Hi everyone,
I would like use personal hotspot of my iPhone with USB cable for stability.
I have the message trust but not connection is possible.
I use the latest firmware.
It’s possible or not of use tethering USB iPhone connection ?
Thanks a lot !
Akintosh
It is possible, here is a guide:
Internet - GL.iNet Docs.
Could your router recognize the iPhone?
I found it worked more reliable by fully disabling (not just disconnecting via the control center) WiFi and Bluetooth and then selecting ‘USB only’ for the tethering option.
You need to trust the router when you connect to it also.
I think the first time you connect it needs a little time to create the ‘TETHERING’ interface but the experience is more reliable afterwards.
This guide is not complete.
